Team Associated RC10B64 Thread
#1306
I think it's because it's a brand new kit, and everyone is in the build phase right now. Two weeks from now everyone will be talking setups and aftermarket parts.
#1307
The kit's been out a week. Most folks probably haven't put it together yet.
And unless you're using box stock set up on your vehicles, of course it's going to take some practice and time behind the wheel for most people to tweak the set up to their liking. Everyone I've talked to so far say that out of the box it's light years above the B44 so I'm thinking it will be a decent performer.
#1308
I'm followed this thread since day1 and it seems like there are more people experiencing problems with the car than are actually praising it.
Anyone who has hit a race with the car have anything to say? Experiences? Comparisons?
I read one person compare it to his b44.3 and say (something like) 'it's gonna be good when I get the setup down'
I got my car late in the week and didn't have time to build for last weekend racing. The build went great but you can't post reviews of how it drives til you drive it...
#1309
I have posted a couple times already saying how great the car is compared to the B44. You need to read every single post if you are looking for a particular answer.
I have posted about the build and driving it as well. I am not complaining (yet) about the car one bit.
Now today I went and ran a few packs through the car and do do some testing, but instead I snapped the L/F arm twice on the same part of the track. I want to say it was my driving as I usually drive pretty hard through this section and over a double I bounced it off the wall, but I have bounced my SC5M, my B6D and my T5m off the same part of the wall plenty of times without breaking anything. So I will not say that is the cars fault. I did crash it. But before that I was looking for a little more rear grip as traction was phenomenal today and the front had a ton of grip so I dropped the rear shock oil down to 27.5 and ended up removing the rear sway bar. I also moved the battery all the way back, which I am probably gonna end up putting it back to where it was as I feel it made the back of the car want to swing a bit much. All in all the car is getting better every time I put it down.
#1310
Anyone know what the contents of bag 2.3 are? looks like I am missing it Unless they put everything into 2.1 and 2.2. It looks like I have everything needed to build 3 diffs, 2.1 has 2 smaller bags inside it with gears, shims and gaskets along with diff cases and spur gear and bag 2.2 has the other half of the diff cases along with the out drives and a bag of screws.
/facepalm. Shock oil bag is 2.3... thanks to my wife for pointing that one out.
#1311
I think i have posted a few times about how much I love this buggy. From the second i first pulled the trigger on its maiden voyage I was very impressed and was turning laps with it like i had been running it for a while. I started with a mix of the kit setup and changed a few things from what I saw from the setup sheets posted on rc10.com. I did start with the green rear springs and immediately went up to the white spring then the grey spring a few packs later. I have not tried removing the front sway bar yet which seems to be the trend but not sure if that was for the conditions and tire choice for the reedy race. I started with 10k/200k/10k in the diffs. I did break a front gear box but my track is a bit hard on cars and was not upset one bit because the car still finished an awesome race between a fellow racer and myself, the kind of race that makes this hobby so great. I went down to 7k in the rear and replaced the front gear box and replaced the front diff fluid with some fresh 10k as i figured it may have gotten dirty fast with everything being new.
#1312
#1313
My car still needs more steering but I made a few changes I have yet to try that should increase mechanical steering.
Even with the car pushing I won mod wheeler I just didn't have blistering fast laps
#1314
I want to try the red spring as well but I also feel i could use a bit more steering more so at lower speed tighter sections. I may need to try a shorter link in the rear to get it to rotate more, I am running the outer hole (d) with the insert in the down position (cav setup sheet) so i may run the c hole with the insert in the up position to shorten it ever so slightly. But everywhere else on the track I cant really complain so it may be in my best interest to leave it where it is but i will of coarse test it at some point to find out, may even try it tomorrow.
#1315
Dude... Anafon... the B64 is really good.
Easier to drive, felt more plush, lands nice. I went a bit off kit setup, perhaps too much for a first drive... but the car was solid. Can't wait to tune and dial it in so I can push it more. The setup I threw on had a load of grip up front. Looking forward to locking in the rear now on my next time out... unfortunately a solid week or 10 days away.
Great build and car AE! Nice to get a few extra misc spare parts, full bottles of oils, Xrings.
P.S. I have no idea how to install the center diff w/o totally removing the front plastic center diff mount along with the front chassis top brace. I was so perplexed trying to install and finally said screw it and started removing parts.
I managed to cut up and partially mangle an old B44.2 body to fit with velcro, as I ran out of time to paint. I wouldn't recommend, but it got me through the night and was able to run 4 packs before my vacation.
Jesse
Jesse
#1317
I managed it with unscrewing the steering link connected to the servo at the servohorn. In my case the front dogbone was in the way so the bone couldn't be lifted enough - after loosening the servo link I had enough space.
#1319
I ran into the steering blocks being tight on the caster block bushings. Had to sand a little material off the block to free them up. Also the rear arm shims. to free the rear hubs.
Weird, B5M and T5M they built without having to do anything like this.
#1320
Adrian
