Team Associated RC10B64 Thread >
Like Tree710Likes
    Hide Wikipost
Old 08-01-2017, 03:20 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Team Associated RC10B64 Thread
Last edit by: RCBuddha
Welcome to the B64 Wiki!
Quick links to all the sections on the first page!
Petit RC Page
B64D Manual
Aftermarket Upgrades
Petit RC Page
B64D Manual
Aftermarket parts
Helpful Tips and Videos
How to properly Shim the B64 Diffs
B64 Club Racer video
Print Wikipost
Old 11-23-2017, 10:42 PM
  #2881
Originally Posted by madness
Reading the post, does this car needs so many upgrades and/or modifications in order for it to perform right? I don't get it.
Not at all, coming from a Yokomo YZ-4, to the B64D, what I liked about it the most, was apart from the alloy steering link, mine was pretty much a mix of the two kits.
Basically, cos I run on astroturf, I had a D, with different springs, roll bars and the slipper, from the non d kit.
John Myall is offline
Old 11-23-2017, 11:57 PM
  #2882
Like the previous poster, the only thing required is the aluminium steering rack. Not sure what other upgrades/mods you may be talking about.
Im sure alot of mods/upgrades are available, companies will try to get on the gravy train in an effort to make momey. This is a popular car after all. Are they needed? No.
Look at the national results, Neil Cragg places second with some wins with the car with just the aluminium steering rack. He chooses not to even use associated alluminium rear hubs.
Im not sure there is another model which is as competetive which is as box stock.
Piles is offline
Old 11-25-2017, 01:27 PM
  #2883
On the Schelle hubs I know the 1mm washer is equivalent to upper row on the stock hub. What's the equivalent of on the black piece that makes the link longer and shorter. Is the inside hole without washers the inside hole on the stock piece. And the outside hole on the black piece without washers is equivalent to the middle hole on the stock piece
Bubonic-X is offline
Old 11-26-2017, 12:27 AM
  #2884
I've just bought a B64 and am on the hunt for some wheels. I use j concept mono rears on my B6, are these okay to use on the B64?
I'd like to stick with the monos for the front. I understand the b44 fronts aren't suitable as they're 10mm hex, are the TLR 22-4 fronts a good fit for the B64?
2hundy is offline
Old 11-26-2017, 06:44 AM
  #2885
Davidka's Avatar
Trader Rating: 86 (100%+)
B6 & B64 rears are the same. TLR wheels have a different offset. Kyosho ZX6 wheels work and Jconcepts makes mono wheels for them.
Davidka is offline
Old 11-26-2017, 12:51 PM
  #2886
Sounds like they are going to release a new 4wheel again some.
Kakenballs is offline
Old 11-26-2017, 03:29 PM
  #2887
Any info to share on that? Just seems too early for them compared to their history of time between releases.
Robbob is online now
Old 11-26-2017, 03:35 PM
  #2888
Fabulous's Avatar
Trader Rating: 42 (100%+)
I've switched from TLR 22-4 to the B64. I'm using all my front and rear TLR wheels with no issues.
Fabulous is offline
Old 11-26-2017, 03:45 PM
  #2889
Super Moderator
Kraig's Avatar
Trader Rating: 81 (100%+)
As Fabulous pointed out you can use front/rear wheels from both cars, 22-4 & b64. With the front wheels, the off-set might make the car to wide or to narrow. If you are racing and the track follows strict rules and if the car is to wide they may make you change it. Otherwise, throw them on and have fun!
Kraig is offline
Old 11-26-2017, 04:29 PM
  #2890
Krio's Avatar
Trader Rating: 159 (99%+)
TLR fronts push the width just shy of the ROAR maximum, so no worries there.
Krio is offline
Old 11-27-2017, 01:34 PM
  #2891
Are the machined shock spacers a worthwhile upgrade over the stock parts?
2hundy is offline
Old 11-27-2017, 02:26 PM
  #2892
IMHO, the machined bits are a better upgrade for your shocks than the Kashima bodies. The rings fit slightly better with the machined parts since they removed some material on one of the spacers.
mgers75 is offline
Old 11-27-2017, 03:02 PM
  #2893
Trader Rating: 21 (100%+)
Yes. For both performance and durability.
MX304 is offline
Old 11-27-2017, 06:36 PM
  #2894
j concepts makes the mono for the 64
https://www.facebook.com/JConcepts.I...XXXw7o&fref=nf
jl34 is offline
Old 11-28-2017, 04:04 PM
  #2895
Anyone using the Schelle top deck on astro or is it only for lower grip surfaces?
MX304 is offline
