    Hide Wikipost
Old 08-01-2017, 03:20 PM   -   Wikipost
R/C Tech Forums Thread Wiki: Team Associated RC10B64 Thread
Last edit by: RCBuddha
Welcome to the B64 Wiki!
Quick links to all the sections on the first page!
Petit RC Page
B64D Manual
Aftermarket Upgrades
Petit RC Page
B64D Manual
Aftermarket parts
Helpful Tips and Videos
How to properly Shim the B64 Diffs
B64 Club Racer video
Print Wikipost
Like Tree459Likes
Old 11-29-2016, 05:59 PM   #241
Trader Rating: 139 (100%+)
Originally Posted by QDRHRSE View Post
Controlled Chaos Raceway
16th St W
Palmdale, CA 93551
http://www.controlledchaosraceway.com/
Controlled chaos raceway on Facebook
We just celebrated our 6th anniversary. To keep this thread on message I'd like to say that we are very excited that 4 wheel buggy is making a resurgence. We're equally excited about the B64. I genuinely hope the new Associated car is really good so that I can run one instead of a TLR or XRay. We have a thriving 4x4 class. Its unlimited but almost nobody runs anything other than a 13.5. Since we are outdoors and its getting cold out, race nights are getting seasonally thin. If you live anywhere nearby its a great place to run Wednesday, Friday, and Sunday.
My mom lives near there, Have never been, what tires you run?
TLR 22T 3.0 (Retired), XRAY XB4 '18, 2X Yokomo YZ-2 DTM, YZ-4 SF (please hurry), Mugen MBX7R Eco, Hobbywing, Futaba, LRH Hobbies, Amain Hobbies, iCharger.
jpcopeland1 is offline   Reply With Quote
Old 11-29-2016, 06:36 PM   #242
Trader Rating: 488 (100%+)
If its dry Pro-Line X2 compound suburbs/scrubs. Wet is always Hole Shots. Late Spring-Fall anything will work but X2 compound is usually the best....red or orange JConcepts stuff is ok when its over 75 degrees.
Now that I've discovered the ignore list I plan to use it.....17 and counting!
QDRHRSE is offline   Reply With Quote
Old 11-29-2016, 06:58 PM   #243
Logi Maker's Avatar
Trader Rating: 49 (100%+)
Originally Posted by Finalist View Post
Schelle confirmed the B6 Schelle aluminum hubs will work on the b64. I'm definitely getting a pair given the forces a heavy mod wheeler can put down.
They worked great on my .3.....
Kyle Predmore
FB AE Fanboy/Insta @ae_fanboy
Sticky Kicks RC\Prolevel RC\MIP\Schelle
Logi Maker is offline   Reply With Quote
Old 11-30-2016, 12:48 AM   #244
patiofurniture's Avatar
Originally Posted by Sizzlechest View Post
Does anyone think/know if we'd be able to use the small hex on the front? I have a couple pairs of new tires mounted up that I don't want to go to waste.
If you want to use 10mm front hexes, the B44 hex is the same width/ offset and just needs to be drilled out to 5mm and you'll be good to go.
While the B6 aluminum rear hubs will technically work, the B64 actually uses a differnt rear hub than the B6. The outer bearing is moved in to narrow the rear end, otherwise you are very likely to end up with a rear end that is an 'illegal' width. Which is also why the rear end uses a 5mm hex, to keep the rear end legal width ( even when the pivot width is wide).
Tim Tunnermann
Team Associated | Reedy | JConcepts | LiveRC |
patiofurniture is offline   Reply With Quote
Old 11-30-2016, 06:31 AM   #245
Sizzlechest's Avatar
Trader Rating: 16 (100%+)
Thanks for the info Patio!
Sizzlechest is offline   Reply With Quote
Old 11-30-2016, 08:51 AM   #246
suby723's Avatar
Trader Rating: 21 (100%+)
I haven't seen this covered but will kyosho zx6 offset front wheels be a close fit or will the wheels be b64 specific?
suby723 is offline   Reply With Quote
Old 11-30-2016, 09:40 AM   #247
Jmuck69's Avatar
Trader Rating: 14 (100%+)
Should be the B44.3 front wheels and others that use the same offset.
B6D | B64D
Schelle Racing Concepts - www.schelleracing.com
Amain Hobbies - www.amain.com
Jmuck69 is offline   Reply With Quote
Old 11-30-2016, 10:10 AM   #248
Trader Rating: 24 (100%+)
B44.3 wheels have 10mm hex
Associated B6 x2
Associated B64D
Associated B64
Associated T5M
Scott R is online now   Reply With Quote
Old 11-30-2016, 10:35 AM   #249
Jmuck69's Avatar
the 2.4 (61mm) wheels have 12mm hex and i'm sure the new wheeler will have 2.2 wheels with 12mm hex.
B6D | B64D
Old 11-30-2016, 11:11 AM   #250
mxnickj's Avatar
Trader Rating: 51 (100%+)
The info all says 12mm hex but from the looks of the spec sheet on the AE site no wheels will be included so I think most people are wondering if existing wheels will fit from other cars or are we at the mercy or AE/Jconcepts/Proline to come out with wheels specific to this car. I know that's my question anyway
Nick Johnson
AE SC5M - AE B6D
Bumps & Jumps RC - LCRC
mxnickj is offline   Reply With Quote
Old 11-30-2016, 11:54 AM   #251
suby723's Avatar
Yeah I would really like to know because I want to glue up some sets to be ready to go.
Old 11-30-2016, 06:24 PM   #252
There will be a 61mm and 2.2" wheel that will be available. The 61mm is the existing wheel, the 2.2" is new to accommodate a 12mm hex.
As mentioned before. If you really want to use a 10mm hex wheel you can, just drill a B44 hex out to 5mm for the axle and rock it. This method was used for early testing.
Tim Tunnermann
Old 12-01-2016, 06:10 AM   #253
mxnickj's Avatar
Any idea when they will be available? I know a lot of people, myself included, would like to get some wheels & tires ready to go before the kits get here
Also, will any of the existing 2.2 wheels for TLR cars or anything fit?
Nick Johnson
AE SC5M - AE B6D
Old 12-01-2016, 07:15 AM   #254
Logi Maker's Avatar
What side will the diff screw face? I'd like to get that figured out before my kit gets here...
Kyle Predmore
Old 12-01-2016, 07:25 AM   #255
suby723's Avatar
Really man? Your going to start crap because people want to know if any existing wheels will fit. Way to take it over the top.. congrats
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
WallyRC
