Team Associated RC10B64 Thread
#1486
I went from 100k to 200k on indoor dirt/clay medium bite new layout and the car got so much better. After a few laps I had to pull over and let other b64 owners try it. I was amazed at the increase in consistency and speed through corners.
#1488
Tires?
Which Swaybars F & R?
What springs F&R?
#1489
I've only put 3 packs through it, so very much a work in progress. I'd like to try different rear bars and possibly go up on the shock fluids.
#1490
some carpet/astro pointers:
long links front and rear (inside on tower)
slipper or gear diff with 500k to 1M
7 deg caster blocks
1.6 front bar
1.8 rear bar
16-17mm ride height
2x1.6 with 37.5 and purple spring front
2x1.8 with 30 and grey spring rear
front and rear arms shimmed back on inner chord length
7 deg caster blocks
1.6 front bar
1.8 rear bar
16-17mm ride height
#1492
7 deg caster blocks
1.6 front bar
1.8 rear bar
16-17mm ride height
7 deg caster blocks
1.6 front bar
1.8 rear bar
16-17mm ride height
Nice dude, thanks for the tips!
Just to confirm, When you talk about shimming the arms back on inner chord, are you talking about the spacers on the inner hinge pins? Basically putting the inner hinge pin spacers towards the front on both F/R arms?
#1493
Thanks for sharing your setups Scott R and AE Stig.
Very helpful. Pardon my ignorance, but I'm not quite sure what you mean by this "front and rear arms shimmed back on inner chord length"?
#1495
7 deg caster blocks
1.6 front bar
1.8 rear bar
16-17mm ride height
7 deg caster blocks
1.6 front bar
1.8 rear bar
16-17mm ride height
#1497
Don't know if it's been mentioned, I was told by an AE driver to shim the center diff forward. I did and no side to side play. Some may be having an issue with the spur possibly hitting the chassis it seems? I believe I used 4 shims.
#1498
Hello,
Quick background. I race 1/5th scale. Have a couple local tracks that race 1/10 and 1/8th. One track just opened that's indoor carpet. Figured I'd find some smaller scale stuff to get more trigger time and learn more about setups at that local indoor track. My brother gave me his old TC4 and I can screw around with it. I'd like to add a 1/10 4wd buggy as well. 1/8 is too big for the indoor track. I'd prefer shaft driven as opposed to belt. I'm looking at getting one soon, so I guess my question is, is there still a 2nd version of this buggy planned? Or did it get scrapped?
#1499
I had a toe to toe battle with an Xray driver that I have lot of respect for. in the end the difference was he traction rolled in one corner and I didn't. that was the first night out for this car.
Its impressive as hell. Great Job AE.
#1500
Underwhelmed? can you explain how this is possible? was it just not a curvy body or something? I watched this car immediately battle the newest Losi with the best drivers at our club and this car set the lap record first night out. that's against a losi with a dialed in setup. This car is impressive.
So he didn't actually Drive one and maybe doesn't even own one. At our local track several of the hotshot's had them and all were quite impressed. One of them threw it down for the first heat race and set TQ for the night.
