Team Associated RC10B64 Thread
#2431
Also the rear hub inserts have also been a weak spot for me before I picked up a set of aluminum inserts, far more so on the wheeler than the b6, if you don't think you'll go for the full aluminum route.
#2434
Was doing some searching to try and see what the advantage of the team kit is over the club racer version.
From what I can see:
-club has graphite shock towers vs carbon on the team
-club kit has plastic diff gears vs metal on team
-club does not include a front anti roll bar whereas the team kit does
Reason I ask is that tower has a $20 gift card with the club kit right now...
#2435
#2436
#2437
#2438
If I understand it right:
The YZ4 front wheels are the same offset
The 22-4 front wheels end up 1mm wider offset per side
Is this correct?
Brace yourselves, carpet season cometh.......
#2442
Seems wheels are hard to find for the front.
So the yokomo yz4 wheels are a direct fit but the 22-4 are 1mm wider per side. Would there be a disadvantage to the wider front track? Or could you use narrower hexes on the front and fit 22-4 wheels giving the same offset as associated wheels?
#2443
#2444
