Like Tree27Likes
Old 12-13-2016, 11:22 AM   #46
Frank,
Any updates on the truck's availability? Still looking like the first of the year? Also what shock springs come in the kit?
thanks
fantomdude is online now   Reply With Quote
Old 12-13-2016, 11:38 AM   #47
TLRacing
Frank Root's Avatar
Trader Rating: 25 (100%+)
Originally Posted by fantomdude View Post
Frank,
thanks
Best date I have is 12/23. Kit springs are blue front and yellow rear.
Frank Root -- TLR Project Manager
Twitter - @FrankRoot FB - facebook.com/FrankRootTLR
Team Losi Racing (TLR) - Team Orion - Spektrum - JConcepts - Horizon Hobby - Stick It 1 - Sticky Kicks - Bradley's Fine Line Designs - liverc.com - OCRC Raceway - Tuning Haus - Pacific Coast Hobbies - RIP
Frank Root is offline   Reply With Quote
Old 12-17-2016, 08:01 AM   #48
Heathen's Avatar
Anyone know if the body mounts are in the same location as the 2.0?
Addicted since 1995!!
VBC D07, VBC D08, MTS FF Pro, Calandra 1/12 XTi, SCMT Warpath, AE RC8B3e
Heathen is offline   Reply With Quote
Old 12-17-2016, 11:59 AM   #49
TLRacing
Frank Root's Avatar
The front it, the rear has moved a little.
Old 12-19-2016, 08:20 AM   #50
VOODOO+'s Avatar
Send a message via AIM to VOODOO+
Originally Posted by Team Pink View Post
Yes it will be similar in design to the 22-4 diffs so it will be planetary. As for advantages over a bevel gear diff I'm not 100% positive if there is. I will leave that question to Frank.
From what I understand, you have to run a thicker oil to get the same effect. Obviously that's neither an advantage nor disadvantage. I'm assuming there has to be an advantage of some sort.
The one that's similar on the 22-4 2.0 is narrow, in designing them for the narrow pivots of the 22-4 they must have discovered something that works better that they standard gear diff.
Hopefully they'll get the pictures taken of it this week so it can be announced and therefore can be pre-ordered. I'm also curious to see what exactly it's going to look like.
VOODOO+ is offline   Reply With Quote
Old 12-19-2016, 10:18 PM   #51
bubbaslash's Avatar
That is correct. 40 and 50K is not uncommon on a planetary diff. I'm wondering if strength is a factor...final drives in heavy equipment are often planetary design
X-Factory SCX-61....the ultimate multi-surface missile!
Made in USA!
bubbaslash is offline   Reply With Quote
Old 12-19-2016, 11:23 PM   #52
Casper's Avatar
Trader Rating: 34 (100%+)
We are running 50K in our 22-4 diffs. I would expect to be higher in this car when it comes out. I was running 50K in a 2 gear setup running the losi gear diff.
TLR/Losi Team Driver
TLR/Losi | Tekin | DE Racing | Spektrum | Exotek | JBRL | Kolor Koncepts | OC/RC |Sticky Kicks | Imagine It Graphics | Casper-RC.com
TLR 22 4.0 SR, TLR 22T 3.0 (laydown), TLR 22-4 2.0, Spektrum DX6R
WWW.CASPER-RC.COM TLR and Tekin setups
Casper is online now   Reply With Quote
Old 12-20-2016, 10:32 PM   #53
Heathen's Avatar
Has anyone built up the production kit yet?
I am wondering how the fitment is? If I remember correctly the 22 3.0 first run had some front-end fitment issues.
Old 12-21-2016, 09:05 AM   #54
TLRacing
Frank Root's Avatar
These haven't quite shipped yet. Should be any day.
Old 12-21-2016, 09:10 AM   #55
Im sticking with my 2.0. I don't like shorties. Not enough capacity or MAH in those.
Sure it makes it lighter weight but I'm so used to having a higher MAH like 7000 or more.
Mid motor is a problem for me because I race outdoors a lot so mid motor isn't good for me.
Associated B6 "Dirt Version" latemodel, Team Losi Racing 22T 2.0 Bomber Truck.
Team Losi Racing 22 2.0 2wd Short Course Truck,Duratrax 835e Brushless 8th scale Buggy,
Stock Slash, B4.1 latemodel(retired), T4.2 Factory Team BOMBER CAR
Castle Creations( Since April 2016)
bmag5000 is offline   Reply With Quote
Old 12-21-2016, 01:01 PM   #56
You can run a brick pack. For more weight and higher mah.
I used to have the same opinion about mm cars on low grip tracks.
This latest generation of Tlr cars produce so much more rear bite than previous models. And then Bolt On the 4-gear Trans.
Good to go for low grip.
ChrisUU is offline   Reply With Quote
Old 12-21-2016, 02:19 PM   #57
Casper's Avatar
They have brass rear pivot block to add more rear weight in low traction conditions as well.
This truck produces series rear traction from what I have seen so far.
Old 12-21-2016, 03:15 PM   #58
Jack Bonhomme's Avatar
I plan to run a brick pack in mine when I get it. I use a brick pack in my mid motored 22T 2.0 with the 3 gear tranny conversion, along with the 35g rear brass weight and my truck drives GREAT in both high AND low traction track conditions.
YouTube Page: JackBonhommeVideos
Sponsors: FTM Grip, Redline Hobbies, Garcia Graphix
Tracks:Barnstormers, 46RC, R/C Madness
Jack Bonhomme is offline   Reply With Quote
Old 12-21-2016, 04:30 PM   #59
Trader Rating: 38 (100%+)
Looking forward to the release of this truck myself.
Lynne7399 is offline   Reply With Quote
Old 12-22-2016, 08:23 AM   #60
TLRacing
Frank Root's Avatar
Shipping from Horizon Today!!!
TLR 22 3.0 Race Kit Thread! Frank Root Electric Off-Road 4654 Today 12:11 PM
TLR SCTE 3.0 Thread Frank Root Electric Off-Road 1634 Today 10:42 AM
Tekno SCT410 Thread Matthew_Armeni Electric Off-Road 26674 10-23-2017 10:55 AM
TLR 22SCT 2.0 Race Kit: 1/10 2WD SCT thread goehm Electric Off-Road 2702 09-14-2017 02:36 PM
TLR/Losi SCTE 3.0 NEW? Thunder Trail Electric Off-Road 110 07-24-2016 06:09 PM
