Like Tree22Likes
Old 08-08-2017, 07:08 PM   #466
Originally Posted by anthonyscardina View Post
Who makes these rear stiffeners? Maybe I missed it on the exotek site?
https://www.dms-racing.com/index.php...612&Itemid=533 is were you order them . I paypaled them $ 11.02 for the stiffeners and then they sent me a shipping bill 2 days later for $ 6.43 to ship it to idaho .. I actually got them today .. It took 8 days to get them from watford , hertz , u.k.
Xb4 Rc10b6 Rc8b3e
carpetburner is offline   Reply With Quote
Old 08-10-2017, 03:14 PM   #467
Installed the exotek laydown today. Everything looks great except for the battery hold down, which seems to be about 2mm too long. I can get it to close, but it requires a lot of force and tweaks everything backwards...the spacing on the holes is fine, I used the template and a battery fits just fine.
anthonyscardina is offline   Reply With Quote
Old 08-16-2017, 07:17 AM   #468
Default Laydown conversion
Is there a list somewhere of everything that is needed for a carpet laydown conversion?
Maynard46_2 is offline   Reply With Quote
Old 08-16-2017, 10:11 AM   #469
Originally Posted by cutting42 View Post
Hiya
I and my team all run the 22 SCT 3.0 in laydown in the UK national shortcourse series. We all use the Exotec laydown but the TLR version will work as well.
We started with this setup as a base.
For the laydown you will need the following parts.
Rear body mount:
Transmission Braces
Maynard, this is basically all the stuff (plus the exotek laydown set) to do a laydown. You could probably do it without the exotek body mounts but they are nice to have.
Old 08-16-2017, 10:22 AM   #470
Casper's Avatar
Trader Rating: 33 (100%+)
I have done it without the brace and use the body mounts. The body mounts also allow you to move the shocks to the front if you so choose.
TLR/Losi Team Driver
TLR/Losi | Tekin | DE Racing | Spektrum | Exotek | JBRL | Kolor Koncepts | OC/RC |Sticky Kicks | Imagine It Graphics | Casper-RC.com
TLR 22 3.0, TLR 22SCT 2.0, TLR 22-4 2.0, TLR Ten-SCTE 3.0, Spektrum DX6R
WWW.CASPER-RC.COM TLR and Tekin setups
Casper is offline   Reply With Quote
Old 08-16-2017, 12:45 PM   #471
Trader Rating: 21 (100%+)
I run the exotek mounts on mine and do not use the upper trans brace. I also ran stand up and still only used the exotek mounts.
Thanks to pops
TLR, Fantom, Horizon, Spektrum, Trackside
Brian L is offline   Reply With Quote
Old 08-17-2017, 04:22 AM   #472
Thanks everyone! Has anyone ran the laydown conversion and the standup on carpet? If so, which one is preferred? The season doesn't start for about another month and I would like to have a descent base setup ready when it starts. I have not driven anything other than a Slash, on carpet, in the past. Eventually, I will try out both transmissions, but was just curious which one people recommended to start with.
Old 08-17-2017, 10:38 AM   #473
Has any one tried a carpet setup like the 22 4.0 using front high roll center block, 3.5mm rear hubs, a laydown tranny, and shocks in the front of the arm(sway bars are a given). My track switched from clay to carpet and I have my 2wd buggy and 4wd buggy carpet ready and now the SC is next. I think all the changes I mentioned would make for hooked up SC truck. I really like the changes on the 2wd buggy.
fantomdude is offline   Reply With Quote
Old 08-20-2017, 07:10 PM   #474
Just got a new set of arms and they now have shock mount holes on both sides for those that are interested in moving the shocks to the front of the arm. No drilling holes needed.
Thanks to pops
Old 08-23-2017, 08:51 AM   #475
Who did you buy them from?
Old 08-23-2017, 12:07 PM   #476
I got them from Horizon. All their stock now should have the updated ones as they were out before latest shipment
Thanks to pops
Old 08-23-2017, 10:54 PM   #477
This has been our standard setup on the truck in the uk for astro tracks (although we modded the front block as the 22 4.0 wasn't available back then)
Works everywhere - all we ever really change these days is the springs and the tyres to suit. I even used that setup on the dirt track with laydown and it was still good to drive and finished second overall with that at the national.
losi8lunie is offline   Reply With Quote
Old Yesterday, 10:09 AM   #478
So can I use the TLR 22 4.0 laydown gearbox and motor plate, along with the above parts listed, to convert my SCT 3.0 or do I have to buy the tlr (or Exotek) laydown conversion kit?
I'm going to take my SCT 3.0 apart this weekend and see if the holes and everything line up (I have a spare 4.0 laydown gearbox and laydown motor plate already), just trying to get some input on it first. I'm a little worried about how/if the rear shock tower will mount to the 4.0 laydown gearbox and also, if the rear bumper mount and body mount that go on top of the stand-up gearbox will mount.
Old Yesterday, 10:14 AM   #479
Casper's Avatar
The Exo will be the easiest to covert as it has the template for the extra water fall holes. The TLR 3.0 laydown will work but need to figure out how to make 3 new holes for that conversion. Two for the new waterfall location and one for the motor mount screw hole. I have not looked at what it would take to the 4.0 conversion however rear towers will be an issue with that.
Official TLR 22 3.0 Race Kit Thread! Frank Root Electric Off-Road 4633 09-21-2017 10:28 PM
TLR SCTE 3.0 Thread Frank Root Electric Off-Road 1591 09-16-2017 03:36 AM
TLR 22SCT 2.0 Race Kit: 1/10 2WD SCT thread goehm Electric Off-Road 2702 09-14-2017 01:36 PM
Tekno SCT410 Thread Matthew_Armeni Electric Off-Road 26651 06-08-2017 10:12 PM
TLR/Losi SCTE 3.0 NEW? Thunder Trail Electric Off-Road 110 07-24-2016 05:09 PM
