AKA SCT Red Inserts - Require pre-mount break-in or Cutting? >
Old 10-12-2016, 09:04 AM
Default AKA SCT Red Inserts - Require pre-mount break-in or Cutting?
I have only used JC and Pro-Line Inserts on my sc5m for the part year and purchased AKA chainlinks with their Red Inserts.
Very firm and fill out the tire too much resulting in poor traction.
Should I have dremeled cross ribs in the inserts or something ?
Anything I can do to soften them up? Have about 5 packs on them.
thanks.
hsp-sandiego is offline
Old 10-12-2016, 10:41 AM
bdyche's Avatar
Several of us locally have had good success using a punch to put holes in the insert. We are putting holes all the way around both of the circumferential ribs, at every other support rib. That translates to 20 total holes and a perfect insert. We are doing the same with stadium truck inserts, too.
bdyche is offline
Old 10-12-2016, 12:18 PM
okay, thanks. makes sense. wish i did this before mounting up the tires. will have to wait for them to break in further.
Old 10-12-2016, 12:42 PM
bdyche's Avatar
Just use a fresh hobby knife blade and cut the inside of the tire using the rim as a guide. Pull the insert, punch it, put it back in and re-glue. Same method I've used to replace dead foams in good tires for ages.
bdyche is offline
Old 10-12-2016, 06:35 PM
R/C Tech Elite Member
thecman26's Avatar
Trader Rating: 112 (100%+)
http://www.rctech.net/forum/electric...formation.html
thecman26 is offline
