Tire selection ?¿
Tire selection ?¿
Been running my b44.3 outdoors .. was gonna try some new tires for outdoors.. I run on mainly dry conditions .. loose then turns into grove some times. What are some good tires to try?!
aka impacts 1st choice. 2nd choice proline blockades.
impacts are a little smaller lugs. either one will work.
Super Moderator
Trader Rating: 31 (100%+)
I would give proline blockades a try, they give good grip on a wide range of track conditions.
1st suggestion: Whatever the people that are winning are using.
2nd suggestion: holeshots
Super Moderator
Ahh. but then you would be testing said tires on the track and not asking in a thread on RCT..
Super Moderator
The standard answer to the OP's question...results in a question... "What is everyone else running at YOUR track?"
Answer, run what they're running. They're running those tires because they work. If you want to try something different, fine. But most likely you'll find the same basic tread design from every brand is going to work.
Super Moderator
If I posted my track conditions and asked for a tire recommendation. I would spend a thousand dollars trying them all vs. going to the track spending 5 minutes with the track owner and the locals.
The absolute very last place you want to get a tire choice for your track from.....is the internet.
