Rc10b4.2 rtr problem new to the sport
My car is making a knocking type noise while I'm running the car I checked the gear mesh and it's all good just can't figure it out
Probably need to shim the gear diff.
I don't know how to or what it is exactly I'm trying to learn as fast as I can lol
Did you hold the spur and spins the wheels to check the diff action. Good way to help narrow it down. Then dissemble down to the diff spinning each step till you find the culprit. I would first remove the pinion and spin the tranny to see if the clicking goes way too to eliminate the motor.
Thanks for all the help guys,I just ran the car like 20 min ago and wanted to ask what part of the car controls the brake? Because I've noticed the car knocks more hitting the brake I didn't know if that can help figuring it out?
Braking is done by the esc. Check the spur and pinion for damage to the teeth or dirt in the teeth. I sometimes use an hobby knife to clean the teeth out or replace if too bad.
Dumb question but the two rods that spin to turn the rear wheels have seems like they have alot of play in them could that be the reason ?
Being an RTR it problably came with dogbones for driveshafts. A good upgrade is going to cvd or cva style driveshafts like comes in the kit versions.
https://www.rcplanet.com/MIP_C_CVD_K...m?Click=119058
These should also add some traction underpower.
Not side to side play but I can 1/4 turn it before the wheel starts turning is that normal or loose? It's frustrating not knowing and I'm like scared to take the thing apart lol
look at the outdrives and see if the slots are worn. It should look straight. If it has been notched out you will have replace the outdrives which means a diff rebuild. Same with the dogbones if they are badly worn and not round they also need replacing. Pics would help a lot.
