Old 12-30-2005, 05:08 PM   #1
LosiSuperTruck's Avatar
Trader Rating: 18 (100%+)
Default MF2 Setup help
I have a slight to mild push\tight condition when taking tight turns. I am loosing a ton of speed because of this. I would like to keep a little throttle through the entire corner, but doing so gives me the push. I know it can be done as I see some of the "fast guys" take the turns on power. I have to completely go off-power, then get at least 3/4 through the corner before I can gas it without the push.
Some of my setup is:
35wt oil front
30wt rear
red springs front
pink springs rear
middle top shock tower postiions on top front and rear
outside pivot positions on lower arms
I have pink tappers in rear, pink directions in front.
LosiSuperTruck is offline   Reply With Quote
Old 12-30-2005, 05:27 PM   #2
rcgen's Avatar
Check out page 4 of the mf/bk tread. Its AD setup and Aaron's suggesting using 35 wt and 210 springs. I just built mine so I am not real sure. I am using this setup since most of all my Losi all way pushed LOL.
rcgen is offline   Reply With Quote
Old 12-30-2005, 06:27 PM   #3
Send a message via AIM to LC
Try 25weight all around with orange springs in front and pinks in back. Leave your camber links alone. This is what I run and you can't make it push. I drove assoc forever and this setup has more steering than any assoc. I ever drove. If track is not real rough and has large jumps you can go to 27.5 weight. Hope this helps.
LC is offline   Reply With Quote
Old 12-30-2005, 06:50 PM   #4
OutlawPro3's Avatar
I would suggest 25 wt. oil in front with red springs with the long arm setup, shocks in center top and bottom.
hope it helps.
Revo 3.3 Platinum Edition
OutlawPro3 is offline   Reply With Quote
Old 12-30-2005, 09:31 PM   #5
For front ball stud washers, how many does .050 mean? Is that just one stock ball stud washer?
and What\where is the pivot support shim? is this anti squat? if not anti squat, what should I set that to?
Team Integy Setup Station 2 w Case and setup board - complete olhipster1 R/C Items: For Sale/Trade 4 11-02-2007 07:21 PM
WTT Mamba 6800 Setup for Tekin Mini Rage Setup Rc guy R/C Items: Wanted to Buy 0 08-07-2007 08:57 PM
XRay T2 Rubber setup, RC 10L4, 1/10 on road setup station jsmax R/C Items: For Sale/Trade 36 04-16-2007 07:56 PM
Integy Setup Station 2 TC w Case and Setup Board rezenclowd3 R/C Items: For Sale/Trade 10 02-24-2007 09:27 PM
almost prospec mbx5 f/t with engine for nitro touring setup or electric setup tony montana R/C Items: For Sale/Trade 13 02-03-2006 11:42 AM
SEO by vBSEO 3.5.0
