Anyone use the Hudy Setup System for 1/10 off-road?
I just purchased the Hudy 1/10 off-road Setup System.
Does anyone else use this for 1/10 off-road? How useful do you find it?
Does anyone have any tips when using it? Do you use the 20mm blocks and the Hudy droop gauge, or do you use the GHEA blocks to setup with your exact ride height on the system?
I ordered the GHEA ride height blocks instead of the Hudy 20mm blocks to set with my exact ride height. But that makes me wonder how to measure droop if the Hudy droop gauge is based off of the 20mm blocks?
I use mine for new builds, major overhauls, or when doing major setup changes. It's nice but defiantly not necessary. I also use a pair of the Ghea blocks so I can use the specified ride height as my reference when comparing setups. Only issue with the Ghea blocks is I need 2 of the 20-30 and 2 of the 15-20 because the ride height ranges on the cars I use it for.
I leave mine at home on the bench, don't take it to the track. For verification of my setup while at the track I just use a camber gauge and large metal ruler.
Note that for stadium truck you will need the 1/8th off-road top plate.
i plan to bring my setup system to the track even, do you use setup wheels insead at the track or>
i find after a big crash or a setup change at the track sometimes it's tough to get everything all square and accurate, im thinking the hudy system will be the ticket
what case? do you know which hudy case will fit the 1/10 off road version? theres no 1/10 off road specified carrying case like there is for the touring car or the 1/8 off and on road..
https://flic.kr/p/K4iy6R
1/10th scale and 1/8th scale offroad have too much slop in them to be at all accurate.
And seriously, are you going to rescale the car every time you make a change like ride height?
BTW, the 110% ride height gauge is the best out there - it doesn't require you to reach under the car like the ghea and rawspeed do.
I do agree about slop ... Reason I usually add +/-0.5 tolerance... Just like any other adjustments.. You try it out and see the difference... Until you get that sweet spot of adjustment . It's like using the subtrim instead of the trim in your radio.... IMHO.
Sorry, but I have found the set-up station to be a huge benefit. I couldn't believe the difference it made. In both 1/10 and 1/8. I have a RPM and Serpent camber gauge. I use a AE ride height gauge. But nothing compares to the Hudy when setting up a Buggy. I also used one for touring car.
you actually use the setup station and change everything at the same time.... You do it only once. Aid you want to do it every run... Then that's your choice.
.5mm is a huge change.
And remember, every ride height change means you need to check camber and toe.
So if you change ride height, you'll need to assemble your setup station to make these same adjustments.
But again, you can't be scientific about this, because of my main point; 1/10th scale offroad cars have too much slop to be at all accurate.
.5mm is HUGE, especially when the car can slop .2-.5 mm each way. This means you could have an almost 1mm change in something. That's more than 1 degree of camber and toe.
Please, tell me more about something I already know all about. The responses are genious.
I spent $150 on the Hudy setup station.
It was a giant waste.
For 1/12th scale, 1/10th scale TC, it makes complete sense. But I'm obnviously still a little bitter about that waste.
Ironically enough, the products I've regretted the most have all come from Hudy/xray.
Sorry if I came off personal.
