Anyone use the Hudy Setup System for 1/10 off-road?
#32
Super Moderator
Trader Rating: 31 (100%+)
This isn't a sales forum. PM each other.
#33
I used my setup again this weekend and it's just dead nuts accurate. I was anywhere from .5-1.5* off doing it with regular gauges and by eye. No more and I can feel my car handles more consistent.
The biggest key factor is having blocks under the car for a consistent measuring point, and the repeatable nature of the setup system measurements. It just is a lot more accurate and consistent. I'm very happy with my purchase and I can see myself using this thing much more than on initial build or setup.
I change my setup between different tracks, also sometimes I notice my car has tweaked a bit and I just can't get to the bottom of it. Now I will be able to spot tweaks and maintain them properly. I can see this being a good maintenance and reference tool as well.
#34
I ordered the 1/10 Hudy Setup station from RCAmerica. I heard I needed aluminum wheel nuts and hudy "droop blocks" which is how they referred to them. Do I need these add-ons and are there cheaper ones? EX: they mentioned they were 20mm. I'm sure i want ride heights between 19-23/24mm. Do I need to order another option.What else do I need to order? thanks all
#35
R/C Tech Elite Member
#36
Thx -2 of these to rest the buggy on desired ride height, correct?
#38
Sucks - I sometimes have 18mm ride height on hi bite and 22mm outdoor. Anything cover these ranges so I don't need to buy 4? Thank you very much!
#39
Has anyone tried using a yoga foam block, where you trace out your chassis and then cut the block to the same footprint? Would this have the same effect as blocks?
#40
Only if you measured the foam block height wise and cut it to 20mm or your ride height.
#41
You can always have somebody with a 3d printer, make you some blocks. I had 2 sets made. One at buggy and 1 at SCT heights
#42
Great idea! Any links online?
Edit-ended up buying 1 15-20mm ghea ride height guage, 1 20-30mm, and 1 raw speed 22mm-24-mm cube. That will allow me to set the ride height at 20mm and 22mm on the setup board, and still be able to check 18mm ride height. Didn't want to have to buy 4 ghea ride height guages. May get another 15mm-20mm but at least can get away with 2 or 3 and not having to buy 4... Also, arrow max makes aluminum nuts that are 4mm. Ordered those to try since they are $8 instead of the expensive Hudy ones. Hope they fit. Thx
#43
#44
yeah, figured that. Just wanted ones i could tighten by hand since i'll be doing all 3 buggies at once and taking them off and on several times. thx
#45
