Xray XT2 2WD Stadium Truck Thread
#931
But a more serious question, are there any immediate upgrades or easily broken parts you'd recommend for day 1? I figure since I'd have to order online I might as well get everything I need at once.
#932
I'm new to the area and just stopped by the track today. I used to run 4wd SCT about 7 years ago, and was just starting to get into stadium truck when life got busy. While down at the track today I heard the stadium truck class doesn't have the best showing here, and some people suggested buggy might be a better choice. I'm 99% certain I'm going stadium truck and torn between an XT2 and T6.2. Have you had an issues with parts breaking and/or availability? Seeing old threads I've seen people complain about the older models of the XT2, but I'm hoping they've all been solved.
The XT2 is awesome, but to be fair the AE is the more prevalent chassis with the most racers to bounce ideas off.
If you go with the XT2, aluminum steering components help making the steering more precise: bell cranks, steering link or servo horn (in no particular order and you don't need all 3 at once).
Other than that, the truck never breaks!
Enjoy.
#933
awesome, I'm really glad to hear it. I was on the fence, but ended up getting the XT2C'21. The AE seems more common, bit also seems like it needs a bit of work to be solid for carpet. I'm planning to just use the basic carpet setup from the XRay websote and see how it does for me. Im so rusty I'll likely end up in novice open class for a bit, haha.
Most of my stuff comes in middle of next week so I'm hoping to be on the track in a couple weeks.
#934
PDX is the friendliest track, feel free to ask for support from anyone. Also, Jimmy and Kenny are the top Xray drivers and always willing to lend a hand.
Most importantly.... Drive and enjoy!
#935
Brass blocks for ‘21
Are there brass c and d blocks available for the ‘21s? Found this but the c block is a different screw pattern (‘18?). Am running loose dirt. TIA
#936
Check the manual. Option parts like this are listed with the stock parts in the manual.
#937
#938
Usually with Xray, everything that fits, is mentioned in the manual. Rarely there are parts coming for other or later models that fit previous models.
#940
I've just ordered an XT2C 21 and I'm reading through the manual, does the manual specify where to use threadlock, I can't see it but want to check I'm not missing something? Any tips for building Xray kits? I run Schumacher 1/10th and Associated 1/8th but this was too good a deal to pass up. Looking forward to trying a new brand.
#941
#942
You can swap the servo mount for a yeah racing alloy adjustable pillar variety, which requires shorter flathead screws for the chassis attachment, to more easily fit some LP servos without dremeling the kit plastic servo mount. From memory that addition plus the diff is literally the only threadlock I've used in my XT2 D '21.
#943
Thanks, as you say the lack of metal to metal means you don't use it often. Found the little icon in the legend. This is just going to be a fun car for me as we don't have a regular stadium class at the nearby tracks, looking forward to the build.
#944
#945
Nearly finished my XT2, has anyone found the inside wheel rubs the steering link at full lock when using Xray wheels? I'm trying to follow this setup, but even before I add the bumper steer washers it rubbing.
https://site.petitrc.com/setup/xray/...ghton20220724/
