Xray XT2 2WD Stadium Truck Thread
#871
#872
So I finally built my XT2. I had gotten some 2.2" DE wheels that I thought were stadium truck wheels but it seems that the axles on the XT2 are too short to work with those wheels. Did I get the wrong wheels or something? I don't have the DE packaging anymore so I'm not sure exactly which model they are, but I thought stadium truck wheels were all pretty standard. Its like the offset is wrong or something. The axle doesn't stick out of the front of the wheel to be able to put a nut on.
Edit: I found the wheels I bought: DE Racing "Speedline" 2.2" 1/10 Stadium Truck Hex Wheels - That should fit, but it doesn't...
#874
#875
#876
Building my 21 Carpet-truck now.
Box setup with the 0 bushings shows Toe-in 4, but in the other pic in the manual says it 3.
Which one is correct? (3?)
Link to manual: https://teamxray.com/downloads/81/xray_xt2_2021_manual_low.pdf (Page 15)
#877
Servo mount
I bought a used 19 XT2 roller. I was putting it together this week and noticed I didnt have the servo mounts XRA366202. Everywhere I look online in US and Canada are backordered. Is there an aftermarkerlt or alternate part that will work for this?
#878
https://www.avidrc.com/product/5/acc...cessories.html
Actually just noticed they seem to show out of stock but maybe you could find some if you search
#879
Maybe this will work? I know they do look nice
I ended up with this
https://www.amainhobbies.com/revolut...29-ora/p665740
it worked fine as well
#880
#882
Anyone used the schumacer stadium wheels?
#884
Wouldn´t it be time to update this threads first post ?
#885
Stand up transmission
I have a 2019 xt2 and it comes with the laydown and layback transmission. Just wondering if there is a way to fit a 3 or 4 gear stand up transmission on it? If so where can I find one and what needs to be done to fit it. Our local tracks are low traction and standup transmissions seem tonwork best. I will be able to make it work with layback but just looking at my options.
