Xray XT2 2WD Stadium Truck Thread
#676
Started running the 17 truck a few weeks ago. Been running on indoor turf off road track. Mine has a ton of steering. Almost to much. The biggest issue I am having is the rear end on landing. It wants to bounce up a lot and cause the truck to lose control. Kit is setup as box stock. Any suggestions on how to fix it?
#677
#678
Wanted to freshen up my 2018 XT2 ball diff for indoor clay track. Any recommendation of what brand balls to use or what type? I also heard of guys using Associated spring for ball diff is that still the case for the 2018?
#679
Until they update the drive shafts to longer and use the 2.5 pin so you can run the newer diff, yes run the AE spring, and I also ended up putting a light amount of CA onto the diff ring to keep it from slipping on the out drive. It's too smooth and the ring slides on it. Just a really bad design, that's been fixed, just not carried over yet.
#680
Steering servo arm
Anyone know if any other brand servo arm works,as far as height for this truck?
#681
So I got distracted building my shocks. I *might have put the 650 cst in the rear and 500 in the front. Of course the kit only supplies enough to fill the shocks once. So I looked on the Associated conversion and 650 = 50wt for the front. That seems like it would be really stiff. Does anyone have a good source for XRay oils?
Thanks in advance,
Bruce
Thanks in advance,
Bruce
#683
#686
Source: Euro Offroad Series » Image Gallery
#688
Forgive me I have searched and I can't find anything about forward mounting the rear shocks. Has anyone tried it? How does it handle on carpet? What do you do to get the shocks mounted in the right position with enough clearance and keep the rear body post in the same location ?
Thanks Mark
Thanks Mark
#689
Looking forward to the truck!
#690
Thanks Mark
Thanks Mark
