Xray XT2 2WD Stadium Truck Thread >
Like Tree104Likes
Old 11-11-2016, 11:50 AM
  #196
Hi,
I'm planning to buy an XT2 but witch servo would be the best for running mainly on hight grip carpet?
It must be reliable one because i don't want to buy twice.
Thank You in advance.
Claude
toroloco is offline
Old 11-11-2016, 11:51 AM
  #197
Trader Rating: 68 (100%+)
Has anyone tried using longer front springs?
todb is offline
Old 11-12-2016, 09:05 PM
  #198
Thanks bent!!
worked like a champ!! The truck is dialed!!!p.s. I added a rear sway bars as well. Worked very well on our carpet track.
hyperdive08 is offline
Old 11-12-2016, 10:13 PM
  #199
Trader Rating: 33 (100%+)
I haven't found any hard enough. Think buggy rears would work. But the rates aren't high enough
dgrobe2112 is offline
Old 11-12-2016, 10:26 PM
  #200
I have some avid frent truck Springs that will get tested tomorrow.
todb is offline
Old 11-12-2016, 10:55 PM
  #201
FYI: http://site.petitrc.com/setup/xray/S...tsXrayXT2.html
Arn0 is offline
Old 11-13-2016, 05:29 PM
  #202
whats a good starting pinion with a 7.5 motor on a tight indoor track
billsharp34 is offline
Old 11-13-2016, 05:47 PM
  #203
JAE
Trader Rating: 30 (100%+)
Dgrobe - do you have as much traction on clay as you xb2 CE or de out of the box? What are the tricks with this one? Thx
Originally Posted by dgrobe2112
I haven't found any any enough. Think buggy rears would work. But the rates aren't high enough
JAE is offline
Old 11-13-2016, 08:43 PM
  #204
Trader Rating: 24 (100%+)
18-19
xray lover is offline
Old 11-13-2016, 10:07 PM
  #205
Yes. As much. Maybe more. Not slick at all. No tweeks needed. Just a tad stiffer on the front shocks. Ride height is 19 front and rear. Definitely need to do the front steering link fix.
Old 11-13-2016, 10:29 PM
  #206
JAE
You running 3 gear laydown with ball or gear diff?
JAE is offline
Old 11-14-2016, 05:14 AM
  #207
Mine get stolen last week :'(
If someonet see it... tell me (m4rmot at free . fr)
m4rmot is offline
Old 11-14-2016, 06:11 AM
  #208
right now, yes.. 3 gear laydown.. i have tried both ball and gear.. gear diff for my high bite track.. with 5k.. when the traction drops some.. i will lower the diff oil.. track i ran on recently.. lot less traction.. didnt get to race there due to truck turnout.. but the ball diff is the one to go with.
Old 11-14-2016, 10:54 AM
  #209
S0 no recommendations for a good servo to put in the truck?
Claude
toroloco is offline
Old 11-14-2016, 11:26 AM
  #210
i run a KO rsx.. full size servo.. what are you wanting as an answer.. run the servo of your choice i would assume..
