TLR SCTE 3.0 Thread
#1381
The other thing you need in order to get the most steering angle is the updated 3.0 dogbone. Kep this mind if you upgrade later or just need to replace them. It has been redesigned to provide full lock to lock without binding. You can tell if you are buying the 3.0 bone by looking at the ball end that fits into the diff drive cup or outdrive. It will have a flat spot on the end if it is the upgraded 3.0 part. The rounded ball is the older design.
#1382
I may look into this for my 2.0. Now my question is, are the updated 3.0 ones a different part number? I just did some quick research and found that the front and rear driveshafts for the 3.0 are the SAME as the 1.0 and 2.0. LOSB3564 covers all 3 SCTE's and other SCTE based platforms.
#1383
#1384
Thinks of buying SCTE 3.0. Any issues ? Is there issue with springs? Why are people going to Kyosho springs? Do you need any upgrades?
#1385
Is the flat spot on the ball at the drive cup just to save weight? Is the newer axle harden more in some way? I ask because they seem more durable than olders units.
No matter what, thanks for updating these parts.
#1386
We just had the first round of the UK Shortcourse National Series on Sunday at Eden Park Raceway near London. The track is a mixed surface but mainly astroturf and quite bumpy with a few bomb-holes and jumps.
The Tekno 410.3 has dominated the UK truck scene for a couple of years but the XfactoryUK/Team Corally switched to the TLR SCTE 3.0 for this year and this was its first major outing. We were not too sure how we would compare as there had been no direct head to head races but the TLR felt great in testing with a few tweaks mainly around shock oils and springs.
Qual started really well in the first round with the top 5 positions taken by our 5 team trucks. Final qual for the A main was TLR 1,2,3,5 and 6 and that is how the finals finished up with team leader Darren Boyle taking the TQ and win and doubling up with a TQ and win in 2WD with the TLR SCT 3.0 with a laydown gearbox mod.
Thanks to TLR for an awesome truck, it was so nimble and yet carried high speed well whilst soaking up the bumps. Hopefully we will see the results continue on the other tracks this year.
#1389
2WD
Hi all,
I'd like to try to run the truck in 2wd configuration, is there any aftermath part allowing to block the center diff?
Cheers
Cheers
#1394
Here is my conversion of the SCTE 3.0 shocks to the 2.0 hop up springs.
I took the necessary parts from the Associated big bore spring cups set and I used the medium (rear) and long (front) neck version on the lower spring side.
I dremeled out the hub section of the super short spring cup and used them as spring collar adapters for the top. Now using the long neck spring cups, no dremeling of the front A arm is required and the spring length still works well for me.
#1395
500K will work if you leave the front driveshaft in, but if you want it to be truly 2wd you'll have to remove it, and even with 500K I would think you'll bleed power from the rear wheels.
