Like Tree59Likes
Old 08-05-2016, 07:40 AM   #91
Originally Posted by r schowengerdt View Post
Frank how many packages of the aluminum 5 - 40 lock nuts does it take for the 3.0 truck if my count is right I can get away with just two packages
Yes Sir, 2 packages will be plenty.
-Ryan Dunford
Horizon Hobby Spektrum Product Manager
TLR--Spektrum--Horizon Hobby--Tekin--Venom--Pro-Line--Sticky Kicks--Bradley FLD--ImagineIt Graphics--Casper-RC.com
TLR 22 3.0, TLR 22T 2.0, TLR 22SCT 2.0, TLR TEN-SCTE 2.0, TLR 8ight-E 4.0, DX6R
hacker07 is offline   Reply With Quote
Old 08-05-2016, 09:01 AM   #92
Thank you and I enjoyed talking to you about the new 3.0 truck at the last JBRL race a rainman's Hobby in Bakersfield
r schowengerdt is offline   Reply With Quote
Old 08-05-2016, 08:13 PM   #93
Are there any common parts to replace on this truck right away? Most likely to break first parts? Id like to have replacements ready to go before I hit the track.
Also, in the 3.0 manual I see a part number for 3 sets of front springs(HARD) Is there a rear kit like this?
Deton8er is offline   Reply With Quote
Old 08-05-2016, 11:51 PM   #94
TLRacing
Frank Root's Avatar
Trader Rating: 25 (100%+)
These things are tanks, not much breaks. I think I'd go for an aluminum servo horn first, then maybe spare front/rear arms, and rear hubs. Maybe a spur gear... but that's about it. I haven't broken any parts during testing except a front arm, but we fixed that and not one broken one since, not even dropping it 7' on to concrete...
Frank Root -- TLR Project Manager
Twitter - @FrankRoot FB - facebook.com/FrankRootTLR
Team Losi Racing (TLR) - Team Orion - Spektrum - JConcepts - Horizon Hobby - Stick It 1 - Sticky Kicks - Bradley's Fine Line Designs - liverc.com - OCRC Raceway - Tuning Haus - Pacific Coast Hobbies - RIP
Frank Root is offline   Reply With Quote
Old 08-06-2016, 06:30 AM   #95
dtr
dtr's Avatar
I suggest a set of clamping wheel hexes, part numbers are in Frank's post.
You wont lose any drive pins with them.
dtr is offline   Reply With Quote
Old 08-06-2016, 07:41 AM   #96
You will wear out parts more than break stuff.
As mentioned a spur is a good idea, 30 mph abrupt stops can make a motor move.... not the trucks fault.
In 4 years I think I've broken one arm. Inside hinge pins can bend....
If you run a lot, diff cases are a good idea.... if you blow a bearing where the pinion (ring and pinion) shaft comes out of the case it often totals the plastic around the bearing....
www.bumpsandjumpsrc.com
www.lcrcraceway.com
www.miponline.com
www.serpentamerica.com
Lovell's Lids
wicker9 is offline   Reply With Quote
Old 08-06-2016, 07:49 AM   #97
Why do people bag on the 2.0 version of this truck saying that the outdrives and dog bones are always wearing out quickly, and this wears out and that wears out quickly and you're constantly replacing parts. Other manufacturers trucks never break or wear out parts, blah blah blah. I've never owned a Losi 4x4 truck, so I'm just going on hearsay. I do have the tlr 22sct 2.0, and I have yet to wear out or break a part on that.
MaX-D is offline   Reply With Quote
Old 08-06-2016, 08:49 AM   #98
If you are referring to my post, I didn't mean to imply quickly. I run the truck almost every week. It's a beast, but things do wear. In the big picture, they aren't as beefy as 1/8 based vehicles, but are subjected to similar loads, so maintenance is a requirement.
www.lcrcraceway.com
www.miponline.com
Lovell's Lids
Old 08-06-2016, 09:40 AM   #99
No I wasn't referring to your post at all. But it did make me think about what people have said online, or even the guys that drive the 2.0 at my local track. The main drawback to the 1/8 scale based trucks in my opinion is the weight.
Old 08-06-2016, 01:53 PM   #100
Thanks for all the input guys!!! I can't wait to get this freaking truck! Last truck was a XXXT....just getting back into racing.
On a side note. Does anyone know when the preorders will ship from Horizon Hobby?
Old 08-06-2016, 03:32 PM   #101
Trader Rating: 19 (100%+)
Just pre-ordered my SCTE 3.0!!!!!!
Will this truck share the same shocks as any other TLR vehicles? If so, which one? I'd like to purchase some different shock springs and components ahead of time. Thanks!
Also a bit off topic, if anyone would like to recommend a motor combo and steering servo feel free to PM me
Rx8 gen2 and HobbyWing 4000kv. .. Butter
Brandon Powell is offline   Reply With Quote
Old 08-06-2016, 03:38 PM   #102
EJ2civic's Avatar
With the right turn 550 2 pole, the truck will be just as fast if not faster.
LOSI TEN SCTE*TLR SCTE 2.0*2017 XRAY XB4*HOBBYWING*PRO-MATCH RACING*SMC*Wild Turbo Fans*BACH Racing*MRH Racing*AbsoluteHobbyz
EJ2civic is offline   Reply With Quote
Old 08-06-2016, 04:20 PM   #103
Why a 2 pole and not 4 pole? What will the 2 pole do for the truck?
Old 08-06-2016, 08:46 PM   #104
Trader Rating: 32 (100%+)
Originally Posted by Casper View Post
Wow thanks Casper for the tip set up. First race today my local track i got 20's laps compare to my tekno SCT410.3 22's laps been almost two years running tekno but the SCTE 2.0 is better for my driving skills. FYI, i MOD the ESC rear with 15 grams lead under ESC.
raved007 is offline   Reply With Quote
Old 08-06-2016, 08:54 PM   #105
Casper's Avatar
Trader Rating: 33 (100%+)
Glad it worked for you.
TLR/Losi Team Driver
TLR/Losi | Tekin | DE Racing | Spektrum | Exotek | JBRL | Kolor Koncepts | OC/RC |Sticky Kicks | Imagine It Graphics | Casper-RC.com
TLR 22 3.0, TLR 22SCT 2.0, TLR 22-4 2.0, TLR Ten-SCTE 3.0, Spektrum DX6R
WWW.CASPER-RC.COM TLR and Tekin setups
Casper is offline   Reply With Quote
