Like Tree62Likes
Old 01-11-2017, 08:51 PM   #1021
InARush's Avatar
Thumbs up
Originally Posted by raved007 View Post
Yup it will fit that i've been running that in my 3.0 with out any problem better than stock.
Thank you very much sir. Good to go!
Keep up or keepoff I'm in a rush!!
InARush is offline   Reply With Quote
Old 01-11-2017, 10:07 PM   #1022
Trader Rating: 65 (100%+)
Default Best Lipo Holder for SCTE
I use the 2.0 thumb screws and graphite strap on my 3.0 truck because it holds the lipo better for my modified lipo position. After moving the lipo towards the outside rail for balance the strap on the lipo is off center and looses some holding leverage. The graphite strap covers more of the battery and with thumb screws it gets that holding power back and then some.
You can use BRP Locking Body Clips without spending much money.
http://www3.towerhobbies.com/cgi-bin...EwoaAhCl8P8HAQ
I use the stock 3.0 lipo holder with clips on my 2.0 without any problems. I don't see an easy way for the clips to come off. They fit very tight with the foam I added to take all slop out of the mount. Even so, anything is possible in a racing environment. A hard hit from the side, a turn marshall getting a hand in the wrong spot flipping truck over or a bumper intruding in there and pulling the clip..
One thing is for sure, the thumb screw mount with graphite strap is as bulletproof as it gets. That's why I also use the pro-line screw down body mounts. No missing clips during or after a race and my body is not rattling and flopping around the track. It works!
Thunder Trail is offline   Reply With Quote
Old 01-12-2017, 01:11 AM   #1023
ahawk65's Avatar
Part# TLR331006 for the graphite battery straps
Hyper 7 PBS | LST2 | RC10GT | Baja 5B | T-Maxx 3.3 | RC18T | Brushless E-Revo
ahawk65 is offline   Reply With Quote
Old 01-12-2017, 07:01 AM   #1024
InARush's Avatar
Thumbs up
I'm already using the graphite battery strap and proline body mount system. I just need the posts and thumb screws. To bad I can't get them in time for this Friday's race. Thanks for the insight though.
Old 01-12-2017, 07:45 AM   #1025
hahah, you ladies must have petite hands. the body clips are way quicker and easier.
the thumb screws are a pain. wait till you loose one and you will loose them.
floyd2810 is offline   Reply With Quote
Old 01-12-2017, 09:07 AM   #1026
Casper's Avatar
Trader Rating: 34 (100%+)
I have been using the thumb screws since before the 2.0 was out. Have not lost one yet but I did buy and extra set just in case. I only remove one. The other I spaced up properly with plastic spacers and thread locked into place. I just take the back on off and swing the brace out of the way. A single thumb screw get the battery in and out. Easy and fast.
TLR/Losi Team Driver
TLR/Losi | Tekin | DE Racing | Spektrum | Exotek | JBRL | Kolor Koncepts | OC/RC |Sticky Kicks | Imagine It Graphics | Casper-RC.com
TLR 22 4.0 SR, TLR 22SCT 3.0, TLR 22-4 2.0, TLR Ten-SCTE 3.0, Spektrum DX6R
WWW.CASPER-RC.COM TLR and Tekin setups
Casper is offline   Reply With Quote
Old 01-12-2017, 10:40 AM   #1027
thats a good idea. quicker with only 1 screw for sure.
the thumb screws are hard for my big fingers to handle.
the pins are easier for me probably because i have done the pin thing
a 100,000 thousand times or so in my life.
Old 01-12-2017, 10:56 AM   #1028
Casper's Avatar
The SCTE thumb screws are pretty big really. I have others that are much smaller. Look into it. That and the CF strap and you should never lose a battery.
Old 01-12-2017, 11:30 AM   #1029
i have never lost a battery yet (knock on wood). yes they are biggest thumb screws
i' have seen or used for sure. i really liked the 1.0 with the velcro strips. i will look into
the cf strip, thanks.
Old 01-12-2017, 02:25 PM   #1030
Originally Posted by Washout View Post
Thanks,
I know on my track with my 4WD buggy that if I run pins on the front I will traction roll in every corner. I was kinda worried about the same reaction with my SCTE 3.0. Have you tried staggers before? Or are they more of a 2WD short course tire?
I tried Staggers on my Tekno but they sucked badly losing drive out of corners and very unstable on turn in. On 2WD SCT, they are great but only there I would say.
cutting42 is offline   Reply With Quote
Old 01-14-2017, 03:42 PM   #1031
Trader Rating: 25 (100%+)
which is good 2s battery packs for losi sct 3. 0 4wd truck ?
taztal3 is offline   Reply With Quote
Old 01-14-2017, 03:59 PM   #1032
Casper's Avatar
Venom 7200mah 100C. Love these batteries.
Old 01-14-2017, 07:15 PM   #1033
Barillms's Avatar
RCJuice.com
HobbyStar 8000mah 100c. Fastest 2s batteries ive ever ran. And they're $50
Barillms is offline   Reply With Quote
Old 01-14-2017, 09:14 PM   #1034
Barillms's Avatar
Originally Posted by Josh L View Post
Start with a 15-16t. From there you should find a good medium till you know if you need more grunt or top end.
I run the HW 4700 in my trucks and I generally stay within 15t there, but I run a taller gear than most people do to soften acceleration.
With a 4300 and a 15t pinion, you should have a torque monster
I run a 4300kv with a 14 tooth pinion. Its perfect
Old 01-15-2017, 08:28 PM   #1035
Trader Rating: 32 (100%+)
Guys do you know what size the differential black o-ring? The stock o-ring seems not good it started leaking center differential and rear differential already empty oil only 4 race. I upgrade x-ray washer still leaking came from driveshaft. I think the silicone clear seems good but don't know what the size.
raved007 is offline   Reply With Quote
