TLR SCTE 3.0 Thread
#916
The manual list the rod as 5/40. Any hobby shop should be able to help you find a substitute rod or bolt that will fit. Many model airplanes use standard rods for controls as most clevis and links use standard size rods. Should be very easy to locate a size that will work from a local hardware source. Will not matter if it comes from a toaster oven, tea pot or Associated RC car. Just take the rod end with you to a hardware store and match it to a size off the shelf that fits.
Hope you enjoy the new truck!
#917
Thx, yeah it was 5/40 rod as in manual. Serves me rite for opening pressy before boxing day lol
#919
After reading through the forums I just ordered this truck as opposed to the Tekno. Having previously owned the original Scte that is heavily modded and upgraded its good to see now it comes with lots of FT parts.
Does anyone knows if a HW Xerun V2.1 120A ESC is enough to handle a 5T 550 2 poles or a 540 4 poles 4500kv motor?
#920
Mine did too. My build was horrible. Every bag was labeled wrong except 1. But the truck drives great..first step #1 is wrong. They send a 5/8 Instead of 7/8. Email Horizon and tell them.... they need to be aware of these issues so they can fix them.
#921
The only motors that are truly legal from track to track ARE 550 2 pole motors or 540 4 pole motors. If any sort of roar racing is in the future those are your choices. The Pro 4 4600 is money ...
If in fact your tracks don't have motor rules , then the 545 and 550 4 pole motors are an option. They may not be legal everywhere you go though. (none of my tracks care , but we do have a ROAR race come through once a year )
#922
Yeah Hobbywing needs to get a ROAR can produced at some point. That is the only thing I wish they would do. As for their 545 cans, they are hard to beat. I run two 4700's, one in my SCTE and the other in a 410.3. They run as hard as any motor I have seen and stay cool to boot.
But on that note, ROAR rules are sometime unreasonable and ridiculous to. Their SCT 2S and motor size rule is no exception. I hate it. Everyone knows these are 1/8 scale vehicles with 1/8 scale weights and power demands. ROAR needs their heads inspected for these reasons and expect to much from 1/10 systems.
#923
#925
start with the box set up, it's pretty good outdoors.
keep checking your ride height. had problem with my shock springs sagging.
would not hold the right ride height.
esc as fare forward as you can go and battery right up against the esc. in front.
#926
tlr scte 3.0 rear ride height problem
I just put the 3.0 together and was doing the basic set up in the book. The book states purple Springs in the front red in the back.I have the ride height at 26 in the front but can only get 23 in the back and that is with the shock collars all the way down. I took the shocks off and checked the rebound and everything is fine 1/2 inche of rebound checked the a arms everything is good , I reinstalled the shocks and still can only get a height of 23 in the back and that is maxed out on the shocks red Springs. Can someone help me with this.scte 3.0
#927
It's fine. Buy 22 series Orange rears and Silver Rear Springs and tune with them. The reds are WAY too soft
#928
#929
http://www.rctech.net/forum/14739098-post738.html
#930
We know what the rules are and both agree the rules are not the best way to go about things.
Maybe it's me, but I have never been one to go along with a thing that confounds common sense or logic without consistent questioning of it.
This is a case that I am guilty of my own hypocrisy in the effect I continue to run the class and abide by the rules. However, don't confuse the fact I think it's mildly stupid to over stress a limited system to do a thing that could be done much better on 3S for little to no extra cost.
3S systems would run longer, cooler, more powerful, and less expensive batteries could be used significantly lowering the risk of blowing one up.
I don't know how things are at your tracks, but more people blow up SCT stuff than any other class around here. Running over abundant IR stat electrical systems is a large reason why IMO.
