Like Tree59Likes
Old 12-19-2016, 10:05 AM   #901
ta_man's Avatar
Trader Rating: 151 (100%+)
Default CVD Bones Comparison
Originally Posted by Thunder Trail View Post
How do you know if you have the updated CVD bones? The New one has a flat spot on the diff cup end. Old one is rounded. They provide for sharper turning because the bone is smaller under the CVD ball end where it would rub the inside of the stub axle. Small change = improved steering.
Could someone post a picture showing a comparison of the new ones (CVD Bones) and the old ones?
ta_man is offline   Reply With Quote
Old 12-19-2016, 01:04 PM   #902
Trader Rating: 65 (100%+)
Easy to spot. Flat on ball end of bone on diff cup side.
Thunder Trail is offline   Reply With Quote
Old 12-20-2016, 08:41 PM   #903
Barillms's Avatar
Originally Posted by Josh L View Post
At least until the 410.4 releases!
Still won't stand a chance. This truck practically drives itself. The Teknos are heavy bricks, you have to baby them. This truck you can drive as hard an an 1/8 scale buggy and it eats it up. I'm running faster lap times than most 1/8 scales. This truck is the real deal.
Barillms is offline   Reply With Quote
Old 12-20-2016, 10:50 PM   #904
Barillms's Avatar
Default Lunsford standoffs
Does anyone know if the titanium standoffs Lunsford makes for the SCTE or 22 will work for the 3.0?? The SCTE ones they make look really nice but I have a feeling they're designed for a bigger shock.
Any help would be great.
Old 12-21-2016, 01:19 PM   #905
Casper's Avatar
Trader Rating: 33 (100%+)
The 3.0 standoffs are unique due to them accepting the 22 style shocks.
TLR/Losi Team Driver
TLR/Losi | Tekin | DE Racing | Spektrum | Exotek | JBRL | Kolor Koncepts | OC/RC |Sticky Kicks | Imagine It Graphics | Casper-RC.com
TLR 22 3.0, TLR 22SCT 2.0, TLR 22-4 2.0, TLR Ten-SCTE 3.0, Spektrum DX6R
WWW.CASPER-RC.COM TLR and Tekin setups
Casper is offline   Reply With Quote
Old 12-22-2016, 09:31 AM   #906
iroczcec's Avatar
Trader Rating: 105 (100%+)
do anyone no if the 3.0 center drive shaft stuff works on a 2.0 scte i am tire of snapping the pins
tekno eb48.2 and et48
hot bodies d413 tekin hitec smc
big dog rc-dailey tire racing
iroczcec is offline   Reply With Quote
Old 12-22-2016, 09:35 AM   #907
Casper's Avatar
Yes you can run the entire 3.0 drive train on the 2.0
Old 12-22-2016, 10:27 AM   #908
iroczcec's Avatar
Originally Posted by Casper View Post
Yes you can run the entire 3.0 drive train on the 3.0
on the 2.0 scte right?
Old 12-22-2016, 10:55 AM   #909
Casper's Avatar
Sorry fixed. The major drive train update on the 3.0 was the tilted center diff. we were already running dog bones and all that with the 2.0 as all that was released as an update to the 2.0
Old 12-22-2016, 02:32 PM   #910
ASA
ASA's Avatar
I saw those on Amain, i am going to upgrade to the dogbones on my 2.0 when the CVD's give up the ghost(no pun intended Casper..haha)
TLR Ten-SCTE 2.0 - Hobbywing
TLR 8ight 4.0 ep conversion - Hobbywing
Serpent Cobra 811b 2.0 - Alpha
Tamiya Lunchbox
...SANWA...
ASA is offline   Reply With Quote
Old 12-23-2016, 05:39 AM   #911
sykemike's Avatar
Default Down south
Anybody running outdoors have a setup sheet they can share besides the stock box? I know it's winter time so I'm assuming down south would be the only place running outdoors. Thanks in advance.
sykemike is offline   Reply With Quote
Old 12-23-2016, 06:59 AM   #912
DoogieLee's Avatar
Trader Rating: 42 (100%+)
I've been using Maifieds E Nats setup on mine and its been great.
http://http://www.tlracing.com/Produ...008#prodSetups
DoogieLee is offline   Reply With Quote
Old 12-23-2016, 09:37 AM   #913
Suffered a hiccup right off the bat building my new 3.0
The very first step requires a 7/8" threaded rod for steering arm but my bag only came with a shorter 1/2" one. I brought it in Australia, who should I contact?
Part No. LOSA6045
thx!
zzztech is offline   Reply With Quote
Old 12-23-2016, 10:20 PM   #914
Part No. LOSA6045
thx!
I would not wait. Use anything off the shelf and move on. Even a long bolt close to the 5-40 size will work. Cut the head off, clean the threads up and thread the ends on. Being that you don't have local parts, there is no reason to let a simple thing like this hold you back from enjoying your new truck.
Old 12-24-2016, 01:00 AM   #915
Is 4/40 close to any metric sized rods?
