Like Tree59Likes
Old 08-01-2016, 12:33 PM   #76
Casper's Avatar
Trader Rating: 33 (100%+)
Never had an issue with nose down on this truck. I have always been able to control with throttle input. This could be solved with revised front arms and change the wheel base on the front similar to the rear hub adjustment but this will not be done on the 3.0 as the truck is in production and on it's way. TLR uses the inserts to change the kickup/Caster adjustments. SCTE has always jumped better then the tekno from what I have seen some may disagree with me on that but my personal observation. The truck will tend to be nose down however I have never had it be an issue even on massive jumps outdoor or indoor. I don't see this change being added to the SCTE anytime soon but I don't make those decisions. That change would require a revised front end.
TLR/Losi Team Driver
TLR/Losi | Tekin | DE Racing | Spektrum | Exotek | JBRL | Kolor Koncepts | OC/RC |Sticky Kicks | Imagine It Graphics | Casper-RC.com
TLR 22 3.0, TLR 22SCT 2.0, TLR 22-4 2.0, TLR Ten-SCTE 3.0, Spektrum DX6R
WWW.CASPER-RC.COM TLR and Tekin setups
Casper is offline   Reply With Quote
Old 08-01-2016, 12:41 PM   #77
Casper,
I thought the change would be as simple as modifying the front inserts to be able to shift the pins in or out (as well as up or down). If there is an issue with clearance between the arms and the diff casing, I can see your point.
Thank you,
Glenn
glennmathias is offline   Reply With Quote
Old 08-01-2016, 01:02 PM   #78
Casper's Avatar
The inserts are up and down. You would need different mounting blocks to change the direction of the inserts. I am not sure what kind of clearance there is to angle the arms as well as front end width issues that might result. There is more to look at then just the insert issue.
Old 08-01-2016, 02:10 PM   #79
Trader Rating: 32 (100%+)
Originally Posted by Casper View Post
Why do you want to do this? You want to adjust the front arms like we sweep the rear arms for toe in adjustment?
The front end is already setup to adjust kickup. I suppose in theory you could change a pivot to make one of them adjust front toe but that is what the steering link can be used for. Not sure what you are trying to accomplish here.
Casper,
Any set up recommendation medium track blue groove.
My local track is this.
http://youtu.be/aTLDKw3Wb_k
raved007 is offline   Reply With Quote
Old 08-01-2016, 02:12 PM   #80
Casper's Avatar
Originally Posted by raved007 View Post
Casper,
https://youtu.be/NLZuT_mMwMw
http://casper-rc.com/images/TEN_SCTE...02_reduced.pdf
Old 08-01-2016, 03:30 PM   #81
Any video's of Mayfield racing nat's with scte 3.0
sgtlt is offline   Reply With Quote
Old 08-01-2016, 03:56 PM   #82
TLRacing
Frank Root's Avatar
Trader Rating: 25 (100%+)
I just looked and I couldn't find any. The LiveRC video feed was awesome, but it doesn't look like they converted any to videos you can watch post-race.
Frank Root -- TLR Project Manager
Twitter - @FrankRoot FB - facebook.com/FrankRootTLR
Team Losi Racing (TLR) - Team Orion - Spektrum - JConcepts - Horizon Hobby - Stick It 1 - Sticky Kicks - Bradley's Fine Line Designs - liverc.com - OCRC Raceway - Tuning Haus - Pacific Coast Hobbies - RIP
Frank Root is offline   Reply With Quote
Old 08-01-2016, 06:21 PM   #83
Casper thanks for set up.
Old 08-01-2016, 06:42 PM   #84
Thanks for looking Frank.
Old 08-02-2016, 01:58 PM   #85
Default springs?
Just pre-ordered my SCTE 3.0!!!!!!
Will this truck share the same shocks as any other TLR vehicles? If so, which one? I'd like to purchase some different shock springs and components ahead of time. Thanks!
Also a bit off topic, if anyone would like to recommend a motor combo and steering servo feel free to PM me
Deton8er is offline   Reply With Quote
Old 08-02-2016, 03:05 PM   #86
It uses 22 shocks so almost all main stream shock springs fit for a 10th scale SCT or stadium truck. We recommend our 22SCt springs.
-Ryan Dunford
Horizon Hobby Spektrum Product Manager
TLR--Spektrum--Horizon Hobby--Tekin--Venom--Pro-Line--Sticky Kicks--Bradley FLD--ImagineIt Graphics--Casper-RC.com
TLR 22 3.0, TLR 22T 2.0, TLR 22SCT 2.0, TLR TEN-SCTE 2.0, TLR 8ight-E 4.0, DX6R
hacker07 is offline   Reply With Quote
Old 08-02-2016, 06:26 PM   #87
Thanks for the info. Who do you mean by "our"?
Old 08-02-2016, 06:28 PM   #88
Mr Dunford (Hacker07) works for Losi
www.bumpsandjumpsrc.com
www.lcrcraceway.com
www.miponline.com
www.serpentamerica.com
Lovell's Lids
wicker9 is offline   Reply With Quote
Old 08-02-2016, 08:03 PM   #89
Casper's Avatar
Yes he means the TLR spring sets.
Old 08-04-2016, 04:44 PM   #90
Frank how many packages of the aluminum 5 - 40 lock nuts does it take for the 3.0 truck if my count is right I can get away with just two packages
r schowengerdt is offline   Reply With Quote
