Like Tree59Likes
Old 11-25-2016, 01:42 PM   #781
Trader Rating: 32 (100%+)
Originally Posted by Barillms View Post
I ordered the Rear super hard Orange X Gear Kyosho big bore springs 4 days ago. They were $8 on Amazon. Man... 28mm is high. Im not sure ive ever ran over 26mm. Normally i run 25mm indoors.
I know 28mm ride height too high the owner of our local track is recommended all SCT minimum is 28mm ride height we can't do nothing.
raved007 is online now   Reply With Quote
Old 11-25-2016, 01:48 PM   #782
Originally Posted by Thunder Trail View Post
Great race footage! Truck looked good. Are you running the lipo front or rear? I thought it was pushing at times in the 180 corners? It looked good at the end of the straightaway though. Those kyosho springs rub the shock body any? Thanks for sharing the race video!
I was able to turn a lot of laps at indoor track yesterday. Using the aluminum shock collar adapters and the 2.0 TLR tuning springs worked out great. I had too much steering after being setup for outdoor track with less traction. Still only .4 off the fastest lap on the the current layout held by local pro with Tekno. I was burning laps to learn the layout and test springs. Black front and Red rear worked great and I plan to test others. Any adjustments I make to take some steering out will only improve my lap times.
I used box setup but with lipo up front using middle screw holes on lipo holder. The 2.0 TLR tuning springs are night and day better than the kit springs. Suspension action looks good on the track and truck doesn't bottom out easy. Ride height holding at 25mm using slightly smaller tire, Barcode.
The Kyosho spring is same size with SCTE 3.0 no rubbing at all. I'm running the battery in front moved all the way in front and ESC orion r10.1 is in rear with 20 grams under the ESC because the motor side is heavier than battery side. Also the battery is move closed to chassis brace.
Old 11-26-2016, 03:47 AM   #783
Josh L's Avatar
That is a ridiculous rule that violates the point of having all the adjustments these expensive vehicles offer. I would highly protest the rule, or I'd run somewhere else. Who ever heard of such nonsense.
So what happens when someone's springs start to sag? They DQ you?
Josh L is offline   Reply With Quote
Old 11-26-2016, 04:50 AM   #784
sykemike's Avatar
Lol
sykemike is offline   Reply With Quote
Old 11-26-2016, 05:10 AM   #785
I know a lot of racers SCT complaining because of that radiculous ride height. Well i set my ride height 30mm i know it going to sag and if you can't pass your ride height you may disqualify for the race.
Old 11-26-2016, 05:19 AM   #786
Josh L's Avatar
From what I understand it is a ROAR approved track. File a complaint with ROAR, because I don't think they can do that under that sanction for point events. It's total BS
Old 11-26-2016, 05:44 PM   #787
Barillms's Avatar
That's the stupidest rule ive ever heard.
Barillms is offline   Reply With Quote
Old 11-26-2016, 05:49 PM   #788
Casper's Avatar
Trader Rating: 33 (100%+)
A lot of carpet astro tracks have ride height restrictions to try and keep cars from tearing up the surface but that is a little over the top.
TLR/Losi Team Driver
TLR/Losi | Tekin | DE Racing | Spektrum | Exotek | JBRL | Kolor Koncepts | OC/RC |Sticky Kicks | Imagine It Graphics | Casper-RC.com
TLR 22 3.0, TLR 22SCT 2.0, TLR 22-4 2.0, TLR Ten-SCTE 3.0, Spektrum DX6R
WWW.CASPER-RC.COM TLR and Tekin setups
Casper is offline   Reply With Quote
Old 11-26-2016, 08:26 PM   #789
sykemike's Avatar
Default Front shock tower
Hey dudes, is the 3.0 front shocktower the same as the 2.0 shock tower?
Old 11-26-2016, 08:56 PM   #790
fordohio is offline   Reply With Quote
Old 11-26-2016, 09:07 PM   #791
Casper's Avatar
The front tower is the same. The rear tower changed for the 22 shocks.
Old 11-27-2016, 04:52 AM   #792
sykemike's Avatar
Thank you very much.
Old 11-27-2016, 08:26 AM   #793
How's the durability and slop compared to the previous iterations?
Really interested having owned SCTE 1.0 with every aftermarkets upgrade under the sun...
zzztech is offline   Reply With Quote
Old 11-27-2016, 10:12 AM   #794
Casper's Avatar
This truck never really developed a lot of slop IMO other then in the steering rack. The new ball bearing steering helps reduce that.
Old 11-27-2016, 12:13 PM   #795
Trader Rating: 65 (100%+)
Slop in rod ends is no longer a concern on the 3.0 truck. I have had to squeeze my rod ends and use dry lube to keep them moving free. Best rod end fit we have ever seen on any version of this truck. Ball bearing ackerman plate comes standard and finishes off the steering slop to zero. Both of these areas have finally reached a point of perfection for me. The older sloppy parts we used in the past will soon be a faded memory.
Ring gear and pinion mesh does require more shims or it does on the newer trucks I have seen with updated gears. They are so much better than the older gears and once set for minimum backlash they are great. So smooth after a few laps.
Thunder Trail is offline   Reply With Quote
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
GNCC407
