Like Tree59Likes
Old 11-09-2016, 03:33 PM   #676
Barillms's Avatar
15 is a good pinion size for outdoors. For a big indoor track, a 13t is more than adequate. Throw a fan on your motor and go down to a 13t and your temp should be fine. Check your ESC settings and make sure you don't have timing added to the motor.
Also... Make sure your pinion mesh isn't too tight. There's gotta be play between the two gears. A tight pinion mesh will cause it to run hot.
Also, when "Testing" outside... you don't want to run thru the grass wide open. Or run wide open spinning tires & sliding... this isnt a accurate test. Anything run wide open thru grass or run wide open is going to get very hot.
Run it on a track for 5 minute, then temp it. You temps will probably be significantly lower.
RC Juice
Dialed RC Hobbies
HobbyStar
Savox Servos
HRP - Hobby & Recreation Products
Barillms is offline   Reply With Quote
Old 11-09-2016, 03:35 PM   #677
sykemike's Avatar
Originally Posted by Barillms View Post
15 is a good pinion size for outdoors. For a big indoor track, a 13t is more than adequate. Throw a fan on your motor and go down to a 13t aand your temp should be fine. Check your ESC settings and make sure you don't have timing added to the motor.
Also... Make sure your pinion mesh isn't too tight. There's gotta be play between the two gears. Tight pinion meshbwill casus it to run hot.
OK, thank you very much. That was a big help.
sykemike is offline   Reply With Quote
Old 11-09-2016, 03:38 PM   #678
sykemike's Avatar
What is a good measurement in gear mesh? I have a .10 piece of paper and a .13 piece of paper?
Old 11-09-2016, 03:40 PM   #679
Barillms's Avatar
Default Diff fluid black
This is 1 race day.
Check out tthe photo attached.
Frank Root??? What is causing the diff oil to get so black after one race??
RC Juice
Dialed RC Hobbies
HobbyStar
Savox Servos
Old 11-09-2016, 03:43 PM   #680
Barillms's Avatar
You don't need to use paper. Just set the gear mesh up so you can rock the gears back and forth a tiny bit. There has to be a bit of movement and space in the gear mesh. Just a tiny bit lol
RC Juice
Dialed RC Hobbies
HobbyStar
Savox Servos
Old 11-09-2016, 03:44 PM   #681
sykemike's Avatar
Old 11-09-2016, 04:43 PM   #682
Casper's Avatar
Trader Rating: 33 (100%+)
What have I done? I have a 15 tooth pinion gear with stock 40 tooth spur and took it out on the road and front yard to get temp reDings and time it. Big mistake. I got 9 minutes and 22 seconds at a 202 degree temp reading. The race track I'm racing on is this Sunday and this is my first race with it. Should I go down a pinion tooth or things will be different on the small outdoor track? Thanks in advance.
Running full speed up and down the street for 9 min is not a good representation for how you run on a track. Actually full pin runs are actually not all that good on your electronics.
202 is warm but should not damage anything. Also I found (not exactly sure why) but BL motors some times break in and after the first few runs I will see a small temp drop. Bearings working? If the truck is not you have parts wearing in in the drive train as well.
This is 1 race day.
This is very normal. nothing to worry about. Ever gear diff I have ever built on any car big or small turned the oil black.
TLR/Losi Team Driver
TLR/Losi | Tekin | DE Racing | Spektrum | Exotek | JBRL | Kolor Koncepts | OC/RC |Sticky Kicks | Imagine It Graphics | Casper-RC.com
TLR 22 3.0, TLR 22SCT 2.0, TLR 22-4 2.0, TLR Ten-SCTE 3.0, Spektrum DX6R
WWW.CASPER-RC.COM TLR and Tekin setups
Casper is offline   Reply With Quote
Old 11-10-2016, 12:58 AM   #683
TLRacing
Frank Root's Avatar
Trader Rating: 25 (100%+)
This is 1 race day.
The black grease you put on the o-rings, and cleaning some of the gears too.
It doesn't affect performance, so I wouldn't worry about it too much.
Frank Root -- TLR Project Manager
Twitter - @FrankRoot FB - facebook.com/FrankRootTLR
Team Losi Racing (TLR) - Team Orion - Spektrum - JConcepts - Horizon Hobby - Stick It 1 - Sticky Kicks - Bradley's Fine Line Designs - liverc.com - OCRC Raceway - Tuning Haus - Pacific Coast Hobbies - RIP
Frank Root is offline   Reply With Quote
Old 11-10-2016, 06:23 AM   #684
sykemike's Avatar
Default Weight?
I weight the truck at work on digital. It said 6.8. I don't know if that is 6 pounds and 8 ounces or 6 pounds and 8 grams.
Old 11-10-2016, 06:30 AM   #685
sykemike's Avatar
Default Charger advice
Any personal opinion on quad multi lipos chargers? I'm running two vehicles in different classes at the same race. I have 10 lipo batteries. I know they cost and that's not the problem. Just need some experience advice on people use them in racing. What brand and model. Like to have all in one unit. Thanks in advance.
Old 11-10-2016, 06:33 AM   #686
wittyname's Avatar
the .8 will not be grams . Its either oz or .8 of a pound which is 12.8 oz
IF the scale is a digital postal scale its in oz . So 6lb 8oz
Josh W.
Don't forget ... Have fun , talk sh*$ with your buddies, and have fun.
I race so I can have people flip my car over ....
wittyname is offline   Reply With Quote
Old 11-10-2016, 06:39 AM   #687
sykemike's Avatar
Thank you. It's on the floor. Like a 2'x2' square that we measure large florescent light bulbs in for Hazard waste.
Old 11-10-2016, 08:43 AM   #688
Casper's Avatar
Venom has a great quad charger
https://www.venompower.com/products/...ance-charger-1
independent PS for each channel with 100W per channel is plenty for any 2S-4S application. It is vertically designed to minimize foot space impact in your pit space. Ryan has the quad and I have the duo and both love them.
Old 11-10-2016, 10:58 AM   #689
sykemike's Avatar
Perfect, thank you for chiming in. Ordering now.
Old 11-10-2016, 11:06 AM   #690
Trader Rating: 65 (100%+)
I have always liked the Venom software on their chargers. The balance charge cycle takes long than some, but thats because it does a great job and puts extra effort in this process.
Ebay is the place to buy one at the right price.
Thunder Trail is offline   Reply With Quote
