Like Tree59Likes
Old 11-08-2016, 07:56 AM   #646
Casper's Avatar
Trader Rating: 33 (100%+)
Originally Posted by sykemike View Post
For those who glue tires to rims, what's the best and easiest to apply pro-
tire glue these days? Also what brand please. Thanks in advance.
I have always had great success with Losi glue indoor and outdoor. Some work great cool weather others better for warm so you get different opinions that way as well. Some don't like certain rubbers. I have always had good luck with losi glue. Only tricky tires for me have been JC gold and those need to be cleaned well.
Originally Posted by winstonite View Post
Those of you who have had a chance to weigh your SCTE 3.0's...is this about right?
you can take off the side nerf bars and remove more of the rear bumper if you are concerned with weight. Just offering low hanging fruit if you are looking to put her on a diet.
TLR/Losi Team Driver
TLR/Losi | Tekin | DE Racing | Spektrum | Exotek | JBRL | Kolor Koncepts | OC/RC |Sticky Kicks | Imagine It Graphics | Casper-RC.com
TLR 22 3.0, TLR 22SCT 2.0, TLR 22-4 2.0, TLR Ten-SCTE 3.0, Spektrum DX6R
WWW.CASPER-RC.COM TLR and Tekin setups
Casper is offline   Reply With Quote
Old 11-08-2016, 09:28 AM   #647
Trader Rating: 65 (100%+)
Thanks for the feedback Thunder Trail My previous SCTE was a 1.0, I like the idea of the 2.0 screw on the lipo holder that you mentioned, gonna look it up. As for the mount, it's a: Jammin-Products-TEN-SCTE-2-0-Carbon-Center-Top-Plate-amp-Transponder-Mount. Appreciate the info!
The 2.0 screw down system with graphite strap is the most secure. It also works best if modifying the lipo stops to slide lipo over.
I might make a holder like that one you use for transponder, but I want it for my receiver. Would like to get the receiver off chassis to keep dirt out. A mount like that would allow room under it to cover receiver with a balloon. It would fit like a sock over mount, receiver and wires exit out the front side. Also would allow easy install of Vet tape, or gauze tape. Its an idea I have kicked around a while. I tried a box, but I don't want to add that much wt to the heavy side of truck.
Another idea others have used is a lexan cover or shield. I don't think it would work as well, but anything is better than leaving it out in the open to fill with dirt shoveled in from the right front tire during right hand turns on throttle.
Currently use some tape, but it only helps so much do to location. Any ideas from others who have 2.0 or 3.0 besides adding a box?
Thunder Trail is offline   Reply With Quote
Old 11-08-2016, 10:54 AM   #648
they make little rubber rx plugs for empty spots if you have any... other than that the rx should be sealed and dirt shouldn't be an issue...
| XRAY XB8E 16' | XRAY XB4 16' | XRAY XB2 CE 17' |
| New England | RCE | RCM |
lyons238 is offline   Reply With Quote
Old 11-08-2016, 12:14 PM   #649
Casper's Avatar
Spektrum makes a water proof receiver as well if this is of concern to you.
http://www.spektrumrc.com/Products/D...odID=SPMMR4000
Basically seals it all off but you have some other wigglies to deal with.
Never had an issue with an exposed receiver. I normally run on a "clean" clay track but have run on "dirt" and never an an issue.
Old 11-08-2016, 12:19 PM   #650
Josh L's Avatar
I always just stretched a small water balloon around my Rx to keep it sealed from dirt
Works great
Josh L is offline   Reply With Quote
Old 11-08-2016, 01:39 PM   #651
mo
mo's Avatar
I made my own server mount with receiver box for mine. Also allows me to easily take the servo out, just lifting straight up.
TLR SCTE 3.0 Thread-scte-rec-box-top.jpg   TLR SCTE 3.0 Thread-scte-rec-box.jpg
thirtydaZe likes this.
TLR, Spektrum, Tekin, SMC, MO-GRIP, www.factory-rc.com https://www.shapeways.com/shops/MPP
mo is offline   Reply With Quote
Old 11-08-2016, 01:52 PM   #652
Josh L's Avatar
Server Mount?!!! Is it connected to the cloud?
All joking aside that looks great. I was thinking of doing some similar things for the battery mounts. Since the truck is 70ish grams heavier on the motor side, I think it be great to make a set that kicks the packs to the outside against the side plastics.
What are you using for print media, PLA, or ABS?
I'd like to see another picture of all the stuff you've made on there as well. Whats that to the left of the diff top with the pin?
Old 11-08-2016, 01:56 PM   #653
Trader Rating: 32 (100%+)
Interesting would you sell that I'm interested to buy
raved007 is offline   Reply With Quote
Old 11-08-2016, 02:24 PM   #654
mo
mo's Avatar
Josh L: Those are all printed from shapeways.com. I have a printer at home that I used to make prototypes from abs. For the SCTE I also made a wire guide that goes on top of the center diff mount a a mountable dean's plug holder so they can't come unplugged or flop around. See my signature for a link to all my designs.
For whoever just ordered one of the servo mounts on shapeways, Please be aware that the description says the box top is a separate item. You just orded the bottom part and did not create a user account so i cannot contact you directly.
TLR SCTE 3.0 Thread-scte-wire-guide.jpg   TLR SCTE 3.0 Thread-deans-lock-1.jpg   TLR SCTE 3.0 Thread-deans-lock-2.jpg
Old 11-08-2016, 04:09 PM   #655
Originally Posted by rccars4scott View Post
Question for guys already running the 3.0. On my 2.0 I used the Kings Head Center diff mount and motor mount. Early on I was told it helped with bearing failures. I see that Kings Head now offers the motor mount for the 3.0. Has the "issue" been resolved in the 3.0 or is the aftermarket mount advisable? Thanks guys.
On the 2.0 the kingheadz double bearing partially covered the outdrives. Which in turn help keep the outdrives from wobbling. I personally don't like wobbling so i had one. And the wobble would allow the diffs to leak. It has a bigger motor mount bolt. I prefer this size to the stock bolt. Also had an extra bolt if you used the kingheadz chassis.
On the 3.0 with the dogbones, the outdrives are smaller in diameter. So the extra bearing doesnt support the outdrive. It does nothing but add weight. It still has the larger motor bolt. And they removed the extra bolt because it would hit the 3.0 chassis brace.
fordohio is offline   Reply With Quote
Old 11-08-2016, 07:06 PM   #656
ASA
ASA's Avatar
What size pinion would you guys recomend on this truck?...it uses Mod1 pitch? will be raced on outdoor med grip, Med size track, mostly tightish and techy, running a 4000kv motor
cheers Aaron
TLR Ten-SCTE 2.0 - Hobbywing
TLR 8ight 4.0 ep conversion - Hobbywing
Serpent Cobra 811b 2.0 - Alpha
Tamiya Lunchbox
...SANWA...
ASA is offline   Reply With Quote
Old 11-08-2016, 07:07 PM   #657
Works great
This is the best idea. With a little ledge to sit it on would be easy to cover.
This is eye candy for sure! I'm sure it functions well, but I cant add this much weight to the heavy side so far out to the edge. It might work if the box was behind the servo with aluminum screws holding the top on.
My issue: Think about silt, the smallest debris like dust getting down into the case through the plug the servo wires are in. Then you have a fan and 2 wire transponder leaving a hole for dirt to enter. If you ever looked at coco powder used to make hot chocolate you can see how it gets into everything. Nothing can escape this stuff. Few times a year I take my Airtronics receivers and RX8 apart to find powder dirt 1/8 inch thick.
Old 11-08-2016, 07:11 PM   #658
cheers Aaron
I'm using 14-16T pinion on the 4000k. Yes Mod1
Old 11-08-2016, 07:44 PM   #659
ASA
ASA's Avatar
Cheers mate
Tamiya Lunchbox
...SANWA...
Old 11-08-2016, 09:35 PM   #660
Trader Rating: 42 (100%+)
Great explanation, thanks a bunch!!!
Scott
QUOTE=fordohio;14729917]On the 2.0 the kingheadz double bearing partially covered the outdrives. Which in turn help keep the outdrives from wobbling. I personally don't like wobbling so i had one. And the wobble would allow the diffs to leak. It has a bigger motor mount bolt. I prefer this size to the stock bolt. Also had an extra bolt if you used the kingheadz chassis.
On the 3.0 with the dogbones, the outdrives are smaller in diameter. So the extra bearing doesnt support the outdrive. It does nothing but add weight. It still has the larger motor bolt. And they removed the extra bolt because it would hit the 3.0 chassis brace.[/QUOTE]
rccars4scott is offline   Reply With Quote
