Like Tree59Likes
Old 07-25-2016, 02:09 PM   #46
Trader Rating: 65 (100%+)
Originally Posted by Frank Root View Post
He's definitely not running 2.0 shocks. See below... straight of the track from his Q4 TQ run text to me by Jason Ruona....
What are the chances of getting his setup sheets posted?
Thunder Trail is offline   Reply With Quote
Old 07-25-2016, 02:54 PM   #47
TLRacing
Frank Root's Avatar
Trader Rating: 25 (100%+)
I'll definitely try, he's out racing again this week so it might not be for a couple of weeks. I'll make sure it is up before the SCTE 3.0 ships though.
Frank Root -- TLR Project Manager
Twitter - @FrankRoot FB - facebook.com/FrankRootTLR
Team Losi Racing (TLR) - Team Orion - Spektrum - JConcepts - Horizon Hobby - Stick It 1 - Sticky Kicks - Bradley's Fine Line Designs - liverc.com - OCRC Raceway - Tuning Haus - Pacific Coast Hobbies - RIP
Frank Root is offline   Reply With Quote
Old 07-25-2016, 03:17 PM   #48
I was at Nationals this weekend and watched Mayfield destroy the field. Lutz put up a good fight but in the end Mayfield's truck was dialed.
As for the weight conversation I tend to agree that a little heavier works best outdoors......this didn't play out. No grip at the event and Ryan was dialed.
BTW, I currently run a Mugen MBX7R I created. It was 3070 grams. While once I got it correct it still wasn't as fast.
I will echo someone's comment that you can add weight where you want it later.
Lastly I watch Dakoda last year jump a huge double at "The Track" in MI. No issue. Landed it like a boss every time.
That's my observation.
I'd have to go back and look at fast laps from this weekend. Lutz was fast but Mayfield was too.
Hot Bodies D815 | HW SCT ESC | HW Motors |
Mugen MBX7R SCT | HW SCT ESC |
HB D413 | | Airtronics ESC |
Support: Sparks Park Raceway | DE Racing | VRP Racing
Victory is offline   Reply With Quote
Old 07-25-2016, 04:29 PM   #49
I'm on to you now!!!
No one is faster than Maifield in 4x SCT. No one.
www.bumpsandjumpsrc.com
www.lcrcraceway.com
www.miponline.com
www.serpentamerica.com
Lovell's Lids
wicker9 is offline   Reply With Quote
Old 07-25-2016, 06:11 PM   #50
They badly need to make truck specific springs like ae does, those shock collars are hanging on for dear life to keep that truck up.
Ready, fire, aim!
RC8.2e- 150a 2200kv HW + 1283sg
rcbuggies is offline   Reply With Quote
Old 07-25-2016, 06:47 PM   #51
I saw that as well, I was just curious as to who's truck Pillars was working on.
JPMRC is offline   Reply With Quote
Old 07-25-2016, 10:16 PM   #52
TLRacing
Frank Root's Avatar
I'm not sure, I wasn't there.
Old 07-26-2016, 07:58 AM   #53
DoogieLee's Avatar
Trader Rating: 42 (100%+)
I'm guessing that those of us with 2.0's can get the new 3.0 chassis and be able to have the adjustable motor/diff setup? Or would that require additional parts? I planned on getting it to be able to swap the battery and esc around, but wouldnt mind messing with the motor and diff angles some.
Kevin 'Doogie' Lee
\m/ SCTE 3.0*XB8e\m/
Qualifiers are just organized practice...
DoogieLee is offline   Reply With Quote
Old 07-26-2016, 08:14 AM   #54
TLRacing
Frank Root's Avatar
You'll also have to have the dog bone center drive and the 3.0 chassis braces.
Old 07-26-2016, 09:18 AM   #55
Casper's Avatar
Trader Rating: 33 (100%+)
3.0 braces are good but not "required" The 2.0 rods will work. The 3.0 chassis braces stiffen up the chassis a little more as they contact the chassis better and I would recommend them but not "required"
TLR/Losi Team Driver
TLR/Losi | Tekin | DE Racing | Spektrum | Exotek | JBRL | Kolor Koncepts | OC/RC |Sticky Kicks | Imagine It Graphics | Casper-RC.com
TLR 22 3.0, TLR 22SCT 2.0, TLR 22-4 2.0, TLR Ten-SCTE 3.0, Spektrum DX6R
WWW.CASPER-RC.COM TLR and Tekin setups
Casper is offline   Reply With Quote
Old 07-26-2016, 10:17 AM   #56
TLRacing
Frank Root's Avatar
The 3.0 braces are built to properly hold the side of the battery, they really are part of the battery compartment. From a durability point of view, I wouldn't recommend running the 3.0 with out them.
Old 07-26-2016, 04:20 PM   #57
Trader Rating: 31 (100%+)
My SCTE 2.0 relocate Battery drill on chassis since the new SCTE 3.0 chassis not available.
raved007 is online now   Reply With Quote
Old 07-26-2016, 04:32 PM   #58
Josh L's Avatar
Is this because you guys omitted the battery thumb screws?
I don't really get what your saying here, because my battery never moved an ounce on the 2.0. I can understand that it might be a helper for the cheaper pin holds on the 3.0 kit, but for us 2.0 guys with the clamping knobs I can't see how it would be any different when it comes to rigidity. I would venture to say the fact the chassis is 3mm shorter will automatically make things more rigid.
Also, I am confused by this anyhow. I recall a lot of people taking the braces off the rear to increase flexion to help with impact traction off a jump. But now everyone is after the opposite.
Josh L is offline   Reply With Quote
Old 07-26-2016, 04:33 PM   #59
Josh L's Avatar
I was doing this mod about 5 months ago. It did help with the loose tracks having more weight up front.
In this picture the ESC was mounted up on a carbon plate for testing a heavier back weight, but I later drilled the front holes and shifted the whole battery forward like they are doing now, so I could set the ESC all the way down on the pan.
Old 07-26-2016, 04:37 PM   #60
TLRacing
Frank Root's Avatar
The battery mounts are flipped on the 3.0, the chassis is wider. So the battery mount holds the 'outside' of the battery now. The chassis braces hold the 'inside' of the battery. On the 2.0, the battery mounts held the inside of the battery and the mud guard held the outside of the battery.
Also, if you removed the rear chassis brace on the 2.0, you'd pop out the rear center driveshaft, and probably bend the chassis. I've never seen or heard of anyone doing this.
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
raved007
