Like Tree59Likes
Old 07-22-2016, 07:08 PM   #31
I think Maifield is running a standard 2.0 shock setup. I was browsing one of ROAR's photo galleries on facebook for the seeding rounds, and saw Joe Pillars working on a 3.0 (Probably Maifield's) with regular 2.0 shocks.
I can't post links yet as this is only my 3rd post.
JPMRC is offline   Reply With Quote
Old 07-22-2016, 07:38 PM   #32
JEFFs SC10's Avatar
Trader Rating: 14 (94%+)
who's faster in SCTE, JR or Maifield?
XRAY 2017 T4
CRC Gen X SE- 17.5 GT
Xray X12-17' GT12
check out the new 12th scale GT class! https://www.facebook.com/groups/148391312353349/
support your local tracks- Beachline Raceway-386-Full Throttle Raceway
JEFFs SC10 is offline   Reply With Quote
Old 07-22-2016, 07:42 PM   #33
I'd have to think that Maifield is the faster one
Old 07-22-2016, 08:56 PM   #34
Trader Rating: 65 (100%+)
Originally Posted by dtr View Post
Good luck Dakotah!
This is what I mean by wind
+ YouTube Video
That's got to be the best example of what cross wind can do to a truck, any truck. I don't think a heavy truck is enough to prevent that effect. It would be less though.
Thunder Trail is offline   Reply With Quote
Old 07-22-2016, 09:48 PM   #35
Originally Posted by Frank Root View Post
If the suspension is dialed in for the weight, I can't think of one form of racing that prefers a heavier car to a lighter one.
Most of the time I feel you are spot on. However, this less wt theory has been dismissed many times. Less weight is not always the right tool for the job. The heavy rigs push you around in the corners and you can't do anything about it. Being so light also effects how well they fly on long jumps before getting out of shape due to light breeze or even bumping another car lightly in mid air. Then there are durability problems with parts that are not beefed up enough.
Smaller indoor tracks are a different story. The lighter rig seems to be an advantage getting in and out of turns quicker and accelerating faster. Speeds are lower making durability a lesser concern. This will be debated till the end times, but there are certain circumstances that call for a heavy and strong rig.
This truck seems to be the best of the class across the board. Great design that stands the test of time with so little change. I pre ordered this truck even though I have decked out 2.0s now. Look forward to the 3.0 and I'm hopeful lap times make me feel good about owning it. I do wish it came with all the goodies though..... clamping hex, aluminum diff inserts and such. I know, keeping price down and all that crap. Just something else we have to upgrade. Hey got to complain about something
Hope there are some beefed up diff washers hiding in the box? Maybe some aluminum cross shafts in the diffs?
Old 07-23-2016, 04:24 AM   #36
Originally Posted by GettinLapped View Post
Truck should be dialed indoors but the weight is a concern for outdoors. Every track I race is low bite and blown out and the heavier/wider cars seem to be the ticket.
Easier to add weight if you want it rather than take it away.
Callaway is offline   Reply With Quote
Old 07-23-2016, 05:33 AM   #37
Aw11Clown's Avatar
Plus put it where you want it.
Aw11Clown is offline   Reply With Quote
Old 07-23-2016, 05:55 AM   #38
Send a message via Skype™ to Cody227
less weight will ALWAYS be faster, the only real concern here is durability. Even with unlimited motor power a heavier truck could never be as fast because tire efficiency decreases with weight. Of course you have to differentiate between sprung and unsprung weight. Some people at my track have lightened their 1/8th scale buggies to below 3kg and it was very hard to find a decent setup due to the bad ratio of sprung to unsprung weight.
RC8b SC ~ B5m ~ B4m ~ Mini-Z
Cody227 is offline   Reply With Quote
Old 07-23-2016, 06:54 AM   #39
JEFFs SC10's Avatar
Heavier weight is better on outdoor for sure.
I'm surprised the shocks weren't bigger like the Tekno's.
XRAY 2017 T4
Xray X12-17' GT12
Old 07-23-2016, 10:34 AM   #40
The problem for me isn't really weight, it's the lack of stability and travel the suspension has to negotiate large ruts and jumps, especially on blown out tracks. Some of us can't even go a decent lap without the car chassis slapping or wobbling over bumps and jumps.
Old 07-23-2016, 05:32 PM   #41
Casper's Avatar
Trader Rating: 33 (100%+)
Shock bore will not help with this? SCTE has plenty of shock travel as we normally take out droop. Lower CG is always a good thing. Adding weight is always easy as you an just add chunks of brass or lead to the chassis however taking weight out is usually more expensive. I have not run the truck outdoors in wind stiff enough to really mess up this truck. There is a ton more control with the SCTE over the 2wd SC's. If the wind is strong enough for that video weight is not the answer. For rough tracks a shock setup for rough track will need to be developed if that track is that blown out.
TLR/Losi Team Driver
TLR/Losi | Tekin | DE Racing | Spektrum | Exotek | JBRL | Kolor Koncepts | OC/RC |Sticky Kicks | Imagine It Graphics | Casper-RC.com
TLR 22 3.0, TLR 22SCT 2.0, TLR 22-4 2.0, TLR Ten-SCTE 3.0, Spektrum DX6R
WWW.CASPER-RC.COM TLR and Tekin setups
Casper is offline   Reply With Quote
Old 07-23-2016, 05:46 PM   #42
Frank, I see there is a spacer/shim TLR232053 between the diff pinion bearings, like a crush sleeve on full size cars. I use a MIP part this way on my 2.0s and it seems to make bearings last longer. Is that the purpose for these? Are they aluminum or plastic?
Any changes to gear boxes or diff cases? Tighter tolerances?
In your experience with these new trucks do the ring and pinion gears need to be shimmed same as we have done in the past?
Old 07-23-2016, 06:00 PM   #43
Casper's Avatar
They are alum crush spacers just like we use in the hubs of our 2wd cars and same as what MIP was doing. You are correct it is intended to increase the life of the pinion bearings.
Old 07-25-2016, 10:01 AM   #44
TLRacing
Frank Root's Avatar
Trader Rating: 25 (100%+)
Frank Root -- TLR Project Manager
Twitter - @FrankRoot FB - facebook.com/FrankRootTLR
Team Losi Racing (TLR) - Team Orion - Spektrum - JConcepts - Horizon Hobby - Stick It 1 - Sticky Kicks - Bradley's Fine Line Designs - liverc.com - OCRC Raceway - Tuning Haus - Pacific Coast Hobbies - RIP
Frank Root is online now   Reply With Quote
Old 07-25-2016, 10:03 AM   #45
TLRacing
Frank Root's Avatar
He's definitely not running 2.0 shocks. See below... straight of the track from his Q4 TQ run text to me by Jason Ruona....
Currently Active Users Viewing This Thread: 4 (0 members and 4 guests)
