Like Tree59Likes
Old 09-30-2016, 11:30 AM   #391
Originally Posted by rdeppen View Post
listen pinhead It was sort of tongue and cheek till you piped up. I simply said I was hoping to use the option part I already HAD from my 2.0 kit where it was a needed option. Christ I remember why I gave up on forums. dumbasses like you.
Your forgetting the part where you were telling Casper he was basically just sticking up for TLR because he is a "factory guy".
I'm the dumbass? Your the one that failed to realize what he was telling you was actually being honest and not go telling you to buy alum upgrades for the 3.0, he was doing the exact opposite of what you accused. Not like he has control of them changing C blocks. But I'm the dumbass...also says the guy that calls me a "pinhead" what is this 1988?
Leave the forum's buddy, no one's too concerned.
| XRAY XB8E 16' | XRAY XB4 16' | XRAY XB2 CE 17' |
| New England | RCE | RCM |
lyons238 is offline   Reply With Quote
Old 09-30-2016, 02:07 PM   #392
Trader Rating: 65 (100%+)
Default Updated CVD bones
How do you know if you have the updated CVD bones? The New one has a flat spot on the diff cup end. Old one is rounded. They provide for sharper turning because the bone is smaller under the CVD ball end where it would rub the inside of the stub axle. Small change = improved steering.
Thunder Trail is offline   Reply With Quote
Old 09-30-2016, 02:21 PM   #393
Originally Posted by JMURACN View Post
are you using the protek screw kit? when we get back from vacation i'm going to put this thing on a diet
I used the protek kit for the 2.0 pretty much worked for the entire kit except for 4 of the diff to chassis screws (2.0 used 1/4" iirc and the 3.0 uses 3/8")
same with the Ti turnbuckle kit
username1 is offline   Reply With Quote
Old 09-30-2016, 03:23 PM   #394
Casper's Avatar
Trader Rating: 33 (100%+)
Knock it off please. This entire conversation is not needed in this thread.
Thanks.
TLR/Losi Team Driver
TLR/Losi | Tekin | DE Racing | Spektrum | Exotek | JBRL | Kolor Koncepts | OC/RC |Sticky Kicks | Imagine It Graphics | Casper-RC.com
TLR 22 3.0, TLR 22SCT 2.0, TLR 22-4 2.0, TLR Ten-SCTE 3.0, Spektrum DX6R
WWW.CASPER-RC.COM TLR and Tekin setups
Casper is offline   Reply With Quote
Old 09-30-2016, 03:41 PM   #395
He will need another pack of 4 - 40 by 5/8 button head screws for the body post that tie onto the shock Tower also the protek it also does not have the two lower screws to tie the rear gear box case I had to get those screws from Lunsford and I could only get them an inch and three quarters instead of an inch and seven eighths
r schowengerdt is offline   Reply With Quote
Old 09-30-2016, 03:47 PM   #396
Also used a turnbuckle that goes between the Servo arm and Servo saver it is a Lunsford 3.5 millimeters by 24 millimeters I had to sand a millimeter off of each turnbuckle end
Old 09-30-2016, 10:30 PM   #397
sykemike's Avatar
Originally Posted by Casper View Post
They are alum crush spacers just like we use in the hubs of our 2wd cars and same as what MIP was doing. You are correct it is intended to increase the life of the pinion bearings.
Is there a part number for the anti crush spacers? If so, I'd like to put some on the new scbe. Thanks in advance.
sykemike is offline   Reply With Quote
Old 10-01-2016, 12:40 AM   #398
See post 42 in this thread. TLR232053
Old 10-01-2016, 12:47 AM   #399
Default Bad springs on SCTE 3.0 shocks
Spring mystery solved. 3.0 kit springs were sagged out. I put the new Red springs on and immediately could see it was better. Collar at the bottom of threads, but ride height is at 27mm RTRace. Plan to use the +4 spring cups if needed to maintain ride Height.
I thought about this for a while and devised a crude way to compare springs using a digital scale. I compressed the springs to 45mm and took a reading in grams of spring pressure. See results below:
Compressed springs to 45mm
Kit Springs
#1 720g
#2 670g
Replacement springs
#1 820g
#2 830g
Just bad springs. Look forward to track day. Now I can make other setup adjustments.
Old 10-01-2016, 04:30 AM   #400
sykemike's Avatar
Does anyone make them for the outer axials?
Old 10-01-2016, 06:04 AM   #401
Kit Springs
#1 720g
#2 670g
Replacement springs
#1 820g
#2 830g
Wow I should try the same thing I guess. Sucks that the collar have to be so low. Can't get anymore ride height out of it. What are the +4 spring cups?
Deton8er is offline   Reply With Quote
Old 10-01-2016, 06:21 AM   #402
Trader Rating: 75 (100%+)
I finished my kit on Wednesday of this week and ran a few practice laps with it last night. My kit has the same issue with the low ride height on both ends. I'm at the very bottom of the shock body threads and I'm getting only 25mm of ride height. No worries though, the stock rear red spring is too soft for indoor clay anyway, so I'm going to pick up a set of orange and silver springs for it. The stock red spring may be good for a looser outdoor track, though. Other than that, the kit set-up was really good on my local clay indoor track. It wanted to jump a little nose down at times, but I think that is also an issue with the rear of the truck being sprung too soft. The nice thing is that unlike my old Tekno SCT410.3, I can pull the nose back up with some extra throttle. This kit seems to be very responsive to throttle in the air, very controllable.
Associated (2x)B6D, B64D, T5M, SC5M
TLR 22-4 2.0, SCTE 3.0
Mugen Seiki MBX7R Eco, MBX7R Nitro, MBX7T Eco, MBX7TR Nitro
XRAY 17 XB4
Yokomo YZ-2 CA
Wease is offline   Reply With Quote
Old 10-01-2016, 01:18 PM   #403
No, but you should not need them for axle. I have made some for a different scenario. Only time I needed spacer for axle was using Tekno axles with aluminum carrier on rear. Tekno axle kit does not work well with aluminum gear box inserts or rear hubs. Don't need Tekno stuff on this truck now and don't need aluminum hubs or uprights either. both have been updated and so far proven strong.
Old 10-01-2016, 01:26 PM   #404
The kit comes with two of these taller +4 spring cups. They are 4mm taller. Use on front for more a arm clearance. Use on back for more preload.
Old 10-01-2016, 04:35 PM   #405
sykemike's Avatar
Thank you very much. I probably screwed up. I bought the scbe, and look on here for setups. Diffs, shocks and so on. I'm up grading this scbe with 2.0 chassis, carbon shock towers, all rear hubs and rear all Insets. With the twins universal shafts. Dog bone in center shafts. All front carriers and all spindles. Now I hear this news. Did I screw that bad? Lol
