TLR SCTE 3.0 Thread
#376
my 2.0 had every single ball'n part for the good and the bad... it was mostly for good, but weight came into play "sometimes."
for my 3.0 i want to keep the weight way down... that leaves with titanium to replace steel and CF to replace overly thick plastic... which means i might be out of luck lol. I havent gone to the extreme of buying a spare chassis and hitting it with dimple dies yet
#378
jmuracn, you think the 2.0 is heavy. i have the 1.0, with a lot of upgrades.
it's even heavier then the 2.0 haha. it's feels a lot like the new 3.0. it's just
heavier so it's more like slow motion compared to the 3.0
this truck doesn't need any thing, it comes with everything you need!!!
if you have a wild hair and feel the need to spend money get some shock springs.
#381
I finally got my truck together and was able to get a weight on it.I have titanium screws turnbuckles and aluminum nuts. The truck weight is 2579 grams that is with All Electronics Plus Battery and tires no body
#383
#385
If it doesn't come with the alloy rear diff bearing carriers, then you can't say that. Those are the first things you should replace on the SCTE. The plastics hold up for while, the alloy's hold up for good. Also unless the diff washers have been upgraded as well, you'll find a lot of us tend to run XRay washers since they seem to be hardened to the point of lasting a very very long time. The rear alloy hubs are also nice. Anything that carries a bearing is generally better if it's metal from my experience. Keeps things nice and true without flex.
with the original plastic ones. never warped or got out of shape. only reason
i put them on is because someone gave them to me and thought i would try them.
#387
esc 1st edition black rx8. i power it with a tenshock 1:10 4 pole sensor motor sc411-4600kv. all the power you could possibly need. been running this combo
the last 3 years.
check out the tenshock very powerful motor.
#388
and cases and check the bearings i have a set of diff's and cases set-up for indoor and a set for out door. never had any issues. i understand
bearing are better secured in metal. i just have not had any issue.
probably just jinxed myself too.
