Like Tree65Likes
Old 09-26-2016, 09:09 AM   #361
Originally Posted by floyd2810 View Post
it may only be locking when there is resistance/weight of the truck.
deton8er i have to think about this one.
That's true Floyd. One common denominator both times this happened was the tires. I ran holeshots all day practicing with no issues. Ran holshots in the qualifiers
Then I threw on brand new blockades and brand new rims from the kit. Blew the wheels out.
Two weekends in a row, same exact scenarios.
I did tear the truck down Saturday night. When I did I noticed all the bearings in the hubs were "crunchy".
I just ordered all new bearings, aluminum rear hubs, and rims of course....
Deton8er is offline   Reply With Quote
Old 09-26-2016, 09:40 AM   #362
Trader Rating: 65 (100%+)
First all day track day and race. Rear springs are too soft. I get 22mm ride ht with collars cranked all the way down and suspension totally free from bind.
Otherwise, TQ and second in main are strong showing from new rig. It needs suspension work before I can properly adjust other things. Felt like I could swap 2.0 shocks and tower, which is dialed, onto the truck and have a winner. None are perfect out of the box. Rear springs that hold the truck up are first on the list. Right now though, its a close tie with my 2.0 that has years of time on setup. Good out of the box, but needs TLC.
Thunder Trail is offline   Reply With Quote
Old 09-26-2016, 09:57 AM   #363
ya, thats where i would start. keep us posted what you find out.
floyd2810 is offline   Reply With Quote
Old 09-26-2016, 06:18 PM   #364
rdeppen's Avatar
Building a fresh kit today. So far so good. Everything fits great. Wish it came with locking wheel hexs but that was known going in. No binding on any front end parts. Was disappointed I couldn't use the aluminum 15 degree caster blocks I bought for the 2.0. New arms won't allow for them without modification. Looking forward to finishing it up later this week when a few items arrive for it.
rdeppen is offline   Reply With Quote
Old 09-27-2016, 05:56 AM   #365
Trader Rating: 32 (100%+)
I have 15* caster block what i did i flip the bushing and it fit inside the front arm
raved007 is offline   Reply With Quote
Old 09-27-2016, 07:46 AM   #366
Steering issues... I cant find the bind, and there is definitely one. I spent about 15 minutes fiddling with it, I will probably tear it down and refollow the directions. All my measurements are right on the nose. with a quick glance i'm following all the right mounting points.
full right "lock"
full left "lock"
hub side
ankerman side
TLR SCTE 3.0
TLR 22SCT 2.0
Powered by SMC and Tekin
JMURACN is offline   Reply With Quote
Old 09-27-2016, 08:38 AM   #367
The ackerman plate is upside-down. Bearing flange should be on the bottom. That gives you clearance for the bolt heads of the steering rods on the bell-crank. Two screws, flip and good to go. If you still have slight bind back screws out a little until it turns free.
Old 09-27-2016, 09:15 AM   #368
thanks! and i got your PM...
TLR SCTE 3.0
TLR 22SCT 2.0
Old 09-27-2016, 09:23 AM   #369
Welcome. She looks good. Smooth build and will get better after its broke in and cleaned a time or two. Enjoy the build.
Old 09-27-2016, 09:56 AM   #370
Casper's Avatar
Trader Rating: 34 (100%+)
The 3.0 comes with updated +2 caster blocks. The molded these for 3.0 as part of the upgrade. No need for alum caster blocks.
TLR/Losi Team Driver
TLR/Losi | Tekin | DE Racing | Spektrum | Exotek | JBRL | Kolor Koncepts | OC/RC |Sticky Kicks | Imagine It Graphics | Casper-RC.com
TLR 22 4.0 SR, TLR 22T 3.0 (laydown), TLR 22-4 2.0, Spektrum DX6R
WWW.CASPER-RC.COM TLR and Tekin setups
Casper is offline   Reply With Quote
Old 09-28-2016, 08:40 AM   #371
rdeppen's Avatar
I know Casper. I just wanted the durability and I like how open the Aluminum blocks are. just looks cleaner. I may try flipping the bushings
Old 09-28-2016, 12:34 PM   #372
Casper's Avatar
It as never done for durability. Actually the first alum ones were 6061 and bent! LOL
They do look cool but I have had no issues with plastic ones from a durability standpoint.
Old 09-28-2016, 08:25 PM   #373
rdeppen's Avatar
Way to support TLR options factory guy LOL
Old 09-28-2016, 08:37 PM   #374
Casper's Avatar
I am not here to hawk option parts. I do what I can to provide support for products of companies that support me so people have fun with their cars. Not here to empty your wallet.
Old 09-28-2016, 11:57 PM   #375
TLRacing
Frank Root's Avatar
Trader Rating: 25 (100%+)
If you don't feel you need to spend $ on an aluminum version of a part to get acceptable durability, then we've done a better job lowering the "buy-in" price of the kit and increasing the value. The cars with the highest value, tend the be the most popular.
I don't mind aluminum parts that take durability to a higher level for those that want it, or change geometry to give more options or increase performance between vehicle releases. Those are the best option parts for you, the consumer. Not the ones you feel like you "have to buy" to make the durability of your rig "acceptable."
Bildo likes this.
Frank Root -- TLR Project Manager
Twitter - @FrankRoot FB - facebook.com/FrankRootTLR
Team Losi Racing (TLR) - Team Orion - Spektrum - JConcepts - Horizon Hobby - Stick It 1 - Sticky Kicks - Bradley's Fine Line Designs - liverc.com - OCRC Raceway - Tuning Haus - Pacific Coast Hobbies - RIP
Frank Root is offline   Reply With Quote
