TLR SCTE 3.0 Thread
#1531
Most likely. The SC10 4x4 doesn't go very far at all when "coasting." Truly a night and day difference to the SC10 RS, but of course any 2WD will have far less drag than any 4WD.
I talked to another Finnish driver who uses the 4300kv version of this motor on his SCTE, he said he uses 16t in his and thus suggested a 18-19t for me... I guess that could work as a starting point too. Luckily pinions aren't all so expensive if it does go a bit wrong. It's just that if I go to the race with the SCTE, I likely won't be able to test the car and pinion and prior to going on location, except for a quick test on concrete outside my apartment building, which doesn't say much about actual track speed/performance. Damned weather around here making track days far and few between!
I can't say the pinion gears are cheap. When you get a box of them that fit several rigs and cover range in each pitch you have invested a few hundred dollars. You need to replace them about once a year or two depending on track conditions and luck with the pebbles. When you decide on the gear you use most a spare gear is sure to be next. Nature of the beast.
#1532
Well, my driving hasn't been very active so far for various reasons, probably well under 100 hours total in the last ~32 months since I started, but the only time I've replaced a pinion for "wear" so far was because for some reason on the very first one on my B5M the locking screw threads got shredded. I don't really buy spare pinions generally - I just buy one and stick with it. Though I did "break that tradition" the other day by buying a bigger pinion for the B5M to boost the top speed a bit. But at most it'd be a couple pinions for each of my 3 (well, 4 once I get the SCTE) main cars, and each pinion costs only a fiver. Compare that to the Novak ESC I just fried (for the second time...) and it is peanuts :P
Anyway, two days to go to making the order, I just hope the payment plan gets approved or no new shiny car for me after all!
#1533
Got to test a local driver's SCTE 3.0 at the track today. While a comparison is a bit unfair in that the SCTE was properly race-tuned while mine is basically "it is what it is", it was definitely easier and more stable drive than my SC10 4x4. Especially jumps were much easier to control. After the first lap I was already putting what at least felt like slightly more consistent laps (no timing so can't be sure) with the SCTE compared to the SC10 4x4.
Definitely looking forward to getting one of my own, if the order falls through on Tuesday, then I'll probably have to wait 'til December, but certainly gonna get one regardless.
#1534
Im running hw xr8 sct pro and 4300kv G2 engine and using 16t pinion, so I think You need to go 18t or 19t with that 3600kv engine to get it going anywhere.
#1535
I just wanted to say, that has got to be the most custom shock set up I have ever heard of. At the same time its the most odd ball setup. Is this working for you racing? Faster lap times? Less crashes because it soaks up 1/8 scale track jumps and pot holes?
I think it would traction roll on the tracks I race on with so much uptravel unloading in corners. Even so, I know if you put in the effort you can make just about anything work.
Personally, I have found the 2.0 springs on the 22 style shocks to be the best option currently available. Lap times are down and my long term highly developed 2.0 truck has met it's match.
However, I'm sure there is a little more on the table if I installed the shocks and rear tower from the 3.0 truck to my 2.0 rig. I may do just that in the future to see if the shocks along with the already installed 3.0 front suspension can make the truck worthy of turning the same or faster lap times. My 2.0 truck is lighter by 25g, so they are about the same. I believe if your 2.0 is in good shape, the front suspension off the 3.0 can get you close without buying the new truck. I like them both for different reasons. After so much time and effort on the 2.0 it will continue getting track time and offer backup service if needed.
So the carbon fiber rear shock tower from the 3.0 fits directly onto he 2.0?
Is there any differences or are they the same fit? Looks like there is different amount of camber holes on them. But main thing I'm trying to figure out if the 3.0 carbon fiber shock tower fits directly onto the scte 2.0
#1536
They are the same gearboxes so I would asume the shock tower fitment is the same.....im sure Casper will tune in to verify for ya
#1537
Kit is here... building time!
The part I'm least looking forward to is the vent holes in the body. Man, I really hate doing those.
#1538
Ok thanks yea I thought the gearboxes are the same but yea just wanna know for sure if the shock towers on the 2.0 and 3.0 are the same. The 3.0 ones are actually a lot cheaper. If anyone knows 100 percent let me know Thanks
#1539
See page 99 post 1481. Keep this in mind when shopping parts or needing a spare from someone at the track. Lots of options for parts and I think that makes it easy to find parts.
R/C Tech Forums - View Single Post - TLR SCTE 3.0 Thread
#1540
#1541
#1542
There is only one way to know what works. Test it.
#1543
#1544
#1545
I broke my rear shock tower on scte 2.0. And the scte 3.0 shock towers are cheaper so if I can get away with that I will buy it or would I need to Dremel the holes bigger for the shock mounting bolts?
Thanks again
