Like Tree26Likes
Old 06-26-2016, 12:01 PM   #31
I recently built a new Tlr 8ight ebuggy. And wondering if anyone is running the vrp split Pistons on their 4.0 and would give some feedback on it? Thanks
racing98 is offline   Reply With Quote
Old 06-26-2016, 06:48 PM   #32
Lowe's48's Avatar
Originally Posted by "Smiley" View Post
Anyone who has broke a piston has not been using the provided washers that come in the package with the pistons. On our original X line of Pistons, I personally ran them for 6 months before VRP ever started selling the pistons with zero breakage.
As long as you assemble everything on the shock shaft per the instructions, Your fine.
I'll second that!!
I have them in both of my Tekno sct410.3 and Tekno SL for about a year and a half now with no issues.
Tekno Sct410.3-VRP,HW120 SCT-PRO,Pro4-4300kv,Hitec,LRP 8000/2s
Tekno SL.3-VRP,HW120 SCT-PRO,T8i-1950,Hitec,LRP 5000 4s
Weapon of choice : Airtronics M12
Home track : Coyote Hobbies,Ca
Lowe's48 is offline   Reply With Quote
Old 06-26-2016, 10:36 PM   #33
Hi, I recently bought the XV2's (from AMAIN) for both the B5M and D413. Today I finally got around to installing them on the B5M.
The hole in the piston was too small for the shaft. I wasn't sure if it was a defect or I was supposed to ream it so I just reamed it. However, the washer holes were too small as well. I probably could have reamed them as well but when I was test fitting the piston, it didn't appear the Piston and the washer would fit, and still be able to fit on the e-clip to hold them down. I just left off the washer and kept the e-clip and it seemed fine.
THe D413 one I have yet to open but the shaft is even wider than the B5M's, and it appears the holes are same (too small). Just wondering if this is normal or what?
Edit - Just saw that the tip where you put the piston on is smaller for the D413 then the rest of the shaft, so it probably will be fine. GUess my question is just for the B5M. Wonder if the wrong hardware was in there?
40yoCaliRacer is offline   Reply With Quote
Old 06-26-2016, 10:53 PM   #34
I dont see the game changers listed for the tekno sct410.3, would they be the samr as the eb48.3? I know the piston size is right because they use the same size pistons but a different hole size and configuration?
mikeinsocal is offline   Reply With Quote
Old 06-27-2016, 06:58 AM   #35
Trader Rating: 16 (100%+)
I finally had a chance to try the 8X1.3 V2s in my RC8B3 over the weekend. I could definitely tell a difference through rough spots on the track and a small whoop section that always tripped the car up before. It was a big improvement in those areas. However, the issue I have with chassis slap (jumps on this particular track don't have great landings.) was magnified greatly. The car would just slam down and bounce back up on the edge of control-ability. I think the next move will be going up on shock oil weight to see if I can get them dialed in. If not, I may try 6X1.2s.
MX304 is offline   Reply With Quote
Old 06-27-2016, 07:18 AM   #36
"Smiley"'s Avatar
Trader Rating: 166 (98%+)
It sounds like you may have purchased the V2 pistons, But have the V1 shafts? If you are still using the e-clips, Then you need the V1 pistons.
Vision Racing Products | Team Associated | AKA | Tekin | Sanwa | VP Powermaster Fuel | RC Concepts Engines | MIP | Avid | Boom RC Graphics | Paint By: "Smiley"
Vision Racing Products (VRP)- www.visionracingproducts.com
"Smiley" is offline   Reply With Quote
Old 06-27-2016, 07:19 AM   #37
"Smiley"'s Avatar
What oils are you running? Also, what is the outside temp that you are running in?
Old 06-27-2016, 07:39 AM   #38
I am running the shafts that came with the B5M CE Kit.
Unless I am missing something, there is no place on the website that says anything like that. On AMain, when I typed B5M Piston, the XV2 pulls up, hence why I bought it. I've already reamed em out and installed them, guess I will see how they work.
Old 06-27-2016, 07:45 AM   #39
I started with the oil I had been running which is 37.5 front 32 rear. Racing in 95-105 degree weather.
Old 06-27-2016, 07:50 AM   #40
"Smiley"'s Avatar
The washers are for the V2 shafts that use the screw to hold down the rather than the e-clips. I have listed links for amain and our website to the V1 pistons that are the correct fit for the shock shafts that you currently have:
http://visionracingproducts.com/Asso...Pistons_c6.htm
https://www.amainhobbies.com/vrp-12m...p2h1.6/p450902
Old 06-27-2016, 07:51 AM   #41
"Smiley"'s Avatar
Is this for your ebuggy or nitro?
Old 06-27-2016, 07:52 AM   #42
e-buggy
Old 06-27-2016, 07:57 AM   #43
"Smiley"'s Avatar
e-buggy
Depending on what battery you run, espically in that kind of heat you will need to go to 40/35 or 42.5/37.5. Some of the 4S lipos are soo heavy that you also have to adjust the oils slightly. That's one reason to try and stay somewhere around a 5200-5400mah or smaller to help keep weight down, and closer to the weight of a nitro buggy.
Old 06-27-2016, 08:03 AM   #44
Thanks. That's in the range of what I was going to try. I do keep my lipo weight down using 5000mah packs for 10 minute mains and 4500mah for 7 minute mains.
Old 06-27-2016, 08:06 AM   #45
"Smiley"'s Avatar
Gotcha! Yea, Just go up slightly in oil and you should be just fine.
