Vision Racing Products (VRP)
#260
Why would you use the 1.4 3 hole on the rear vs 1.6 (all around)with shocks on front of rear arm? Will this give more grip or is this for a higher bite you are assuming because of the shock setup? I've seen many setups with ge 3 hole on the fronts... I'm ultimately looking for more grip. Thx!!!
Thx
Thx
#263
Thank you. I also have an RB6.6 I have the VRP 1.6 pistons and the 1.4 3 hole lying around. I noticed there were no 1.7 when i purchased them. Which would you reccomend for the front and rear for the same scenario? Looking for more grip. Or should i just purchase another 1.6 set? thx again
#264
You mention the B6 running 3x1.4 all around, how about a B6D for medium high bite clay?
I also just got 3x1.3 XV2 for the front and 3x1.4 XV2 for the rear of my SC5M. Running 32.5 all around for oil. Is this a good base to start from, or should I be using different pistons.
#266
#267
#268
On the B6D, it depends on if you are running the rear shocks on the front or rear or the back arms. But in general, a good starting setup for the B6D is either 2x1.6 front/2x1.7 rear or 3x1.4 front/ 2x1.6 rear. Depending on the temps, 32.5/30 or 30/27.5 is a good starting place.
How about the SC5M?
