    Hide Wikipost
Old 07-22-2016, 06:15 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RZ6
Last edit by: Kraig
Shameless Plug Kyosho RZ-6, the 2015 IFMAR World’s Top Qualifying Car Model.
Find out how Jason Dias lost some weight on his RZ6. Click here.
Editable setup sheets.
Sheet 1
Sheet 2
Shock building, alternative method.
Fill the oil up to the first thread.
Extend the shock shaft so the eyelet bottomed out on the shock bottom.
Place the piston into the shock body but let gravity pull it down into the body.
Once the shock bottom reaches the shock body help align it into the body so that the treads line up.
Turn the shock bottom so that it starts to thread into the body.
Wait for 1 second to give the excess oil time to escape.
Continue to turn, wait, turn, wait process until the shock bottom is tight.
Pump the shock shaft a few times and then bottom out the eyelet to the bottom of the shock and release.
Hopefully you should not have any rebound or maybe just a little bit.
If you have more than you like, loosen the shock bottom, push the shock shaft down, wait for a little bit and then re-tighten the shock bottom.
Jared Tebo shock building video.
+ YouTube Video
2-15 IFMAR Worlds, A-main #1. Jared Tebo TQ using the RZ6.
+ YouTube Video
Print Wikipost
Like Tree2Likes
Old 10-13-2016, 03:38 PM   #76
tobamiester's Avatar
Trader Rating: 275 (100%+)
Send a message via AIM to tobamiester Send a message via Yahoo to tobamiester
Woke up Tuesday and decided I had to have an RZ6
Soooo..Can't see to get to petitRC. Anyone have a good setup starting point in wet/clay high traction indoor surface ? Cheers.
tobamiester is offline   Reply With Quote
Old 10-13-2016, 06:54 PM   #77
thecman26's Avatar
Trader Rating: 98 (100%+)
This will be my starting setup, just got mine as well.
Chris Keen: Viola, Kansas
Kyosho RZ6, TLR 22 3.0, TLR 4.0 SR (soon),& 22T 3.0
"I'm too drunk to taste this chicken!", Col. Sanders
thecman26 is offline   Reply With Quote
Old 10-14-2016, 07:34 AM   #78
Good deal, thanks!
Old 10-24-2016, 12:30 AM   #79
thecman26's Avatar
I have to say I was pretty impressed with the buggy for the first time out with it! The steering was a bit aggressive for my taste but was easy to remedy. It jumps quite nicely and very flat! The shocks are the usual Kyosho perfection. Now if the driver could only have pulled his head outta his... Well ya know...
Old 02-02-2017, 03:12 AM   #80
eper's Avatar
Trader Rating: 14 (100%+)
Does anyone know if the rr and rd mount from the zx5 will mount to the race chassis. I have a db2 that I wore out the rear holes that hold the rear rear block on so I need a new chassis and of coarse rudebits no longer offers the chassis
new milford ct,
WOLCOTT HOBBIES.. TEAM SCREAM..PRO-LINE RACING,,RC Truck Stop, and FTM grip
I CALL IT HOW I SEE IT!!!!!
eper is offline   Reply With Quote
Old 02-02-2017, 06:04 AM   #81
dmcguire's Avatar
Trader Rating: 21 (100%+)
Not sure but can try to check tonight. If you're interested, I have a brand new RZ6 chassis and sideguards. PM if you are.
dmcguire is offline   Reply With Quote
Old 02-03-2017, 08:30 AM   #82
dmcguire's Avatar
Eper, I checked last night with the plastic ZX5 rear suspension mounts and they fit the RZ6 chassis. The aluminum ones will fit as well because the zx5/6 are the same.
Old 02-19-2017, 05:00 AM   #83
eper's Avatar
Thank you dmcmcguire.
Has anyone had issues with shearing the slipper layshaft right were the set screw holds the drive cup on I've sheared 2 of them. I'm running a 6.5. I also noticed my slipper was very aggressive so I readjusted that hopefully that's my cause of the problem. I'm running out of spare parts lol
new milford ct,
Old 02-19-2017, 05:11 AM   #84
eper's Avatar
By the way guys I'm running mine on turf and carpet and really have it working well if anyone needs a starting set up. I'm constantly in the top 5 against some fast guys so cars working good. Off to race it now
tripple likes this.
new milford ct,
Old 02-23-2017, 03:20 AM   #85
eper's Avatar
Has anyone purchased a center driveshaft for this car I can't find part number la3638 anywhere except in the exploded view
new milford ct,
Old 02-23-2017, 04:51 AM   #86
I can't find that number even on the exploded view, LA363 B is a bit easier to locate
Gayosaka likes this.
Kyosho UK RB6.6 & ZX6.6
RogerM is offline   Reply With Quote
Old 02-24-2017, 03:03 AM   #87
eper's Avatar
My mistake on the exploded view I'm looking at it looked like la3638 and it's la363b. I found it thanks though
new milford ct,
Old 02-24-2017, 03:04 AM   #88
eper's Avatar
If anyone happens to know the length of that center shaft and where they measure it from that would be helpful. Thank u guys
new milford ct,
Old 02-24-2017, 06:17 AM   #89
Gayosaka's Avatar
LA363b is 60mm from center of the pin to the center of the other pin
RedWorkShop RZ6R / Kyosho RB6.6 / Kyosho ZX6.6 / Nosram power / Some MiniZ
www.rustidesign.com - Awesome custom stickers and cool stuff
Gayosaka is online now   Reply With Quote
Old 02-27-2017, 03:08 AM   #90
eper's Avatar
Thank u sir.
new milford ct,
