    Hide Wikipost
Old 07-22-2016, 06:15 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RZ6
Last edit by: Kraig
Shameless Plug Kyosho RZ-6, the 2015 IFMAR World’s Top Qualifying Car Model.
Find out how Jason Dias lost some weight on his RZ6. Click here.
Editable setup sheets.
Sheet 1
Sheet 2
Shock building, alternative method.
Fill the oil up to the first thread.
Extend the shock shaft so the eyelet bottomed out on the shock bottom.
Place the piston into the shock body but let gravity pull it down into the body.
Once the shock bottom reaches the shock body help align it into the body so that the treads line up.
Turn the shock bottom so that it starts to thread into the body.
Wait for 1 second to give the excess oil time to escape.
Continue to turn, wait, turn, wait process until the shock bottom is tight.
Pump the shock shaft a few times and then bottom out the eyelet to the bottom of the shock and release.
Hopefully you should not have any rebound or maybe just a little bit.
If you have more than you like, loosen the shock bottom, push the shock shaft down, wait for a little bit and then re-tighten the shock bottom.
Jared Tebo shock building video.
+ YouTube Video
2-15 IFMAR Worlds, A-main #1. Jared Tebo TQ using the RZ6.
+ YouTube Video
Print Wikipost
Like Tree2Likes
Old 07-17-2016, 11:08 AM   #46
TravisS27's Avatar
Trader Rating: 25 (100%+)
Ended up qualified 5th out of 9 cars (stock and 13.5 in one class). The car started out with more steering than I've ever had but loose in the rear. After a ton of changes the car was pretty good by the 3rd round. Ended up 4th in the main after a close battle for 3rd the whole race. Can't wait to get it back to the track! I'll post my setup sheet later.
TravisS27 is offline   Reply With Quote
Old 07-18-2016, 10:17 AM   #47
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
I struggled with bad inserts last weekend which made my car very difficult to drive. So time to change to a less aggressive front tire.
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 07-20-2016, 02:41 AM   #48
foampervert's Avatar
Send a message via MSN to foampervert
Default Front motor position
Hiya folks!
Has anyone tried the rz6 in front motor position? Are any extra parts required to do this?
foampervert is offline   Reply With Quote
Old 07-20-2016, 09:02 AM   #49
I had to throw all of the weight rearward as much as possible to get it to work. I doubt the car would get traction at all.
scoobyrs25 is offline   Reply With Quote
Old 07-20-2016, 05:39 PM   #50
Gayosaka's Avatar
Depends of the track. I use mine on a variety of surfaces, and on dry astro as well as indoor carpet, I feel that the front motor position gives a nice balance, with plenty of on-power steering.
RedWorkShop RZ6R / Kyosho RB6.6 / Kyosho ZX6.6 / Nosram power / Some MiniZ
www.rustidesign.com - Awesome custom stickers and cool stuff
Gayosaka is offline   Reply With Quote
Old 07-21-2016, 06:33 PM   #51
TravisS27's Avatar
Here's my setup sheet from last weekend. I'm loving the on-power corner speed this car carries. Couple more times out with it to get used to it and I'll be good to go!
AKA Tires
BOOMrc Graphics
Exotek Racing
RickyRacer Lidz
Jake's RC Topeka KS
Old 07-22-2016, 06:14 AM   #52
Super Moderator
Kraig's Avatar
Shameless plug --> Kyosho RZ-6, the 2015 IFMAR World’s Top Qualifying Car Model.
Old 07-24-2016, 10:19 AM   #53
Super Moderator
Kraig's Avatar
Had a good run with the car last night. I was able to put together some decent runs after deciding not trying to turn the fastest lap and drive within its limits. I haven't changed to much to the setup from what I previously posted but there are some other things that I want to try, such as trying to lose some weight. I ended up qualifying 4th overall and finished 3rd in the main. The other cars where 2 laydown B6 transmission cars and 1 upright transmission who were in front of me. My favorite track is primarily an Associated dominated track with a few Losi's sprinkled in.
Does anyone have any experience with raising the inner rear pivots up on the chassis, both front and rear? I know if you do one end or the other you mess with the anti-squat but I haven't had a chance to do both just yet. Not to many manuals talk about that stuff so that is why I thought I would ask and it is on my list of things to try.
Old 07-24-2016, 03:26 PM   #54
TravisS27's Avatar
My track is primarily B5Ms and a 22 3.0 or two, no B6s yet.
I switched to the long shock ends front AND rear for more droop and it seemed to help on-power steering. I'd have to look if it has the spacer on the arm mounts lol. I bought the car used as an RZ6 roller so I didn't set it up. I do prefer it over my RB6 though
Old 07-25-2016, 03:01 PM   #55
TravisS27's Avatar
Mine does have a very thin spacer under each rear pivot.
Old 07-25-2016, 05:36 PM   #56
TravisS27's Avatar
Will a ZX6 chassis protector fit with minimal trimming on the RZ6 chassis?
Old 07-26-2016, 06:10 AM   #57
nope
Old 07-27-2016, 08:08 PM   #58
GIHOSU's Avatar
The SC6 chassis protector is what I will use even though it is wider than the RZ6 chassis. It will have to be trimmed a bit but it will cover the chassis and let you cut some patches to layer the back end.
Cruizin with RC's in Waldwick, NJ... check it out!
KYOSHO - RB6.6 17.5 Turf ~ RB6 17.5 ~ RB6 ~ RZ6 Turf ~ RT6 Turf ~ SC6 17.5 ~ SC6 ~ SC6 Turf ~ ST-RR Evo.2E
TEKNO - SCT-410 ~ SCT-410.3
GIHOSU is offline   Reply With Quote
Old 07-27-2016, 08:33 PM   #59
TravisS27's Avatar
I bought mine used and it came with a new unused RT6 chassis protector....I'm guessing that would work well also
Old 08-09-2016, 03:12 PM   #60
alexfry's Avatar
Is there a complete list of what parts are needed from an RB6 to complete an RZ6?
I'm just trying to work out if it's reasonable to put it together from spares rather than buying a complete doner car. It's mostly just the front end and the shocks right?
alexfry is offline   Reply With Quote
