What kind of spur gear should I get?
Wrecked my stock RC10GT, and it looks like a tooth on the spur gear really took a beating.
Should I get an alluminum one or just another stocker?
Do I need 64t, 66t, or what?
Thanks. Also, if anyone has one for sale let me know.
http://dubisteinspundloch.com/DSCF4530.JPG
Need a quick reply. Trying to place an order for some stuff on towerhobbies.
They sell Kimbrough and Robinson Racing spur gears, the Robinson being a few bucks more.
Originally Posted by tazz888
Go with the kimbrough's. I've used both and they both are great. Save a few bucks and get some extras or different sizes.
Edit: I'm an idiot. I took the stocker off and it says 66 right on it. Should I stick with stock size or go lower? Would I get better acceleration with a smaller gear?
I always used the 66t when I raced mine. I also had a 64t in my box incase the track called for a gear change. If your racing I'd keep one of each in your box. If bashing is your thing stick with the 66t.
One more quick question.
What size nuts do I need for the axles? Took the front wheels off and lost one of the plastic nuts.
http://www2.towerhobbies.com/cgi-bin...?&I=LX2525&P=M
http://www2.towerhobbies.com/cgi-bin...?&I=LX2472&P=7
http://www2.towerhobbies.com/cgi-bin...?&I=LX2471&P=7
Get a few variations of the Kimbrough gears, they are very tough. Also, try to stick to plastic gears unless you HAVE to have aluminum. Aluminum and steel gears are tough, but they put a lot of stress on the plastic gears in the transmission.
Just a thought...........If you wrecked and it ate your spur gear, you might check the motor mount ( if its got one I dont know much about assoicated.)to see if its broke. I dont remember which one of my cars that did that. I wrecked and it broke the motor mount on one side and sheared the teeth off half of the spur gear. I have never had that problem with the MT2, primarily because the motor was bolted to the chassis with no mount. I probably will now that I put a 2.5R on it.
Mostly everything looks ok. I superglued the suspension part that broke and it seems to be holding very well just from bending it with my hands. When it breaks, I'll get a new one.
