Sworkz S35-2E 1/8 eBuggy >
Like Tree1Likes
Old 06-03-2016, 03:20 PM
Trader Rating: 23 (100%+)
Default Sworkz S35-2E 1/8 eBuggy
Link to webpage
http://sworkz.com/cars-2/electric-cars/sw-910024
Link to manual
http://sworkz.com/pdf/S35-2E_Manual_Final.pdf
The S35-2E is the ultimate SWORKz 1/8th electric buggy at the moment. Its new rear suspension design and front ackerman steering system came directly from the 1/8th S350 EVO II Limited nitro buggy. A totally brand new center transmission system provides all round improvements to the S35-2E.
The S35-2E includes higher quality parts, many option parts and a refined shock system with optimized suspension geometry.
The SWORKz S35-2E Pro Kit comes standard with many SWORKz Factory Team Option Parts that gives strength, performance and value to the car.
SWORKz utilizes only the highest quality materials and industry leading manufacturing processes resulting in a faster, stronger, and more reliable vehicle. The S35-2E Pro Kit from SWORKz has been designed to out perform the competition while offering amazing performance to drivers of all levels.
S35-2E Kit Features:
* S35-2E 7076 B.H.C. ( Black Hard Coated) Aluminum Chassis.
* S350 Series Competition Rear Lower Arm Set
* S350 Series Competition Aluminum Rear Hub Carry
* S350 Series Competition Steering Plate
* S350 Series Competition Carbon Steering Knuckle Plates
* S350T series Long BBS Pro Shock System Set
* S350 Series Front Pro Shock Tower for Longer BBS shocks
* S350 Series New Wheel Hub(L4.5mm)
* S35 Competition Aluminum Rear Changeable Lower Arm Holder
* New LDGS (Lightened Drive Gear System) gear system with 5×11 mm ball bearings.
* Full Front and Rear LDS (Lightened Drive System) cross drive shaft system.
* New Center Diff transmission drive shaft system.
* Aluminum upper arm holder.
* Aluminum front lower arm holder.
Specification
* Length: 530mm
* Width: 308mm
* Height: 220mm
* Ground Clearance: 65mm
* Wheelbase: 325-330mm
* Track: F:306mm /R306mm
* Gear Ratio: C(45~47)/14T, F/R 43/13T
* Weight: 3650g
hawks is offline
Old 06-03-2016, 06:33 PM
MeasuresMicrons's Avatar
I like it.....looks like a Moog.
MeasuresMicrons is offline
Old 06-03-2016, 06:59 PM
losicorey's Avatar
I love my be1 and this one looks even better. Nice job sworkz
losicorey is offline
Old 06-03-2016, 07:09 PM
werner sline's Avatar
nice tekno/mugen hybrid ! I like it ! i have to check what ball bearing they choose
Now we got the answer to the millenium dilema : eb48.3 or mbx7r eco ? S35-2e !!
werner sline is offline
Old 06-03-2016, 08:54 PM
I have added a link to the manual in the first post.
hawks is offline
Old 06-03-2016, 09:02 PM
they choose some tiny 11x5x4mm ball bearings fomr the bear box : it might be Ok for racing, but for more power and bashing, they will quickly wear out... I had some similar 12x8x4 on my hobao hyperstar and those died way too quickly...
what is that strange part surrounding those 11x5x4 bearings ?
Old 06-04-2016, 09:01 AM
Trader Rating: 29 (100%+)
do you think that single 4s lipo battery packs will fit on tray ?
taztal3 is offline
Old 06-04-2016, 09:04 AM
when it is available and price ??
taztal3 is offline
Old 06-04-2016, 09:34 AM
dont take this the wrong way but most guys, and I emphasis on MOST, won't be buying this buggy to bash to it. Its purely race breed, I haven't seen a bash buggy since the OFNA Violator lol.....with the exception of yours of course.
I do believe it will, if my memory serves me the Mugen 6Eco had a tray like that, I may be wrong. I ran a single 4s.
Old 06-04-2016, 10:18 AM
http://site.petitrc.com/setup/sworkz...orkzS352E.html
Arn0 is offline
Old 06-06-2016, 01:14 PM
Tech Legend
Cain's Avatar
Trader Rating: 294 (100%+)
the tray looks like it has adjustable stops so that stagger setup can be removed if you aren't running dual lipos.
I have to say on face value I like the looks of the buggy. I don't know anything about sworkz parts quality, but if its up there and they have a race team they support, watch out. Every company has to start somewhere.
I would love to see them expand on this setup to make a 4x4 SCT version.
Cain is offline
Old 06-06-2016, 02:59 PM
Trader Rating: 21 (100%+)
Parts quality is not an issue with the SWorkz stuff. Very durable.
MX304 is offline
Old 06-06-2016, 03:16 PM
hey guys... yes car is very very good... we have put a lot of thought into this one.. its super easy to drive fast... we took time and tried several versions and this one just does everything great. I haven't had any durability problems at all and have been running it for several months now. The kit setup should be a good starting point for a lot of different tracks... and its super easy to adjust and tune if you should need.
and yes the battery tray can adjust.. I run the single 14.8 in my car...
car is on way to states and may already be in customs... its already at sworkz euro and should be available for europe..
rickster is offline
Old 06-07-2016, 05:55 AM
Tech Legend
Cain's Avatar
some questions:
- This layout looks reminiscent of a Tekno as far as how tight things are to the center line. I have always liked this layout, however, the car at times (at least the version I had prior to the EB48.3) could be a bit lively in its response on rough tracks. On the sworkz vehicle what have you guys found on your design that provides for a very stable ride on US tracks that have large jumps and are loose and blown out?
- can you provide measurements (length, outer diameter, inner diameter) of the springs that come with the vehicle and if known, what other manufacturer springs work on the vehicle? (ex- Kyosho, losi, etc)
- Are the kit pistons machined or off of a parts tree?
- What are some common gearing choices for the vehicle running say a 4S lipo and a 1900kv motor (example: 19T pinion, 46T spur ,etc)
- Other than Amain, what other major US distributor / seller carries the vehicle?
Thanks beforehand for any answers you are able to provide.
Cain is offline
Old 06-07-2016, 06:54 AM
losicorey's Avatar
I have the original ebuggy from them and have yet to break anything on it. Last season, I broke the track record with it and after the race, everyone was coming up and asking what brand it was and telling me how good the car looked.
I actually prefer it over my 8ight-E 3.0
