Old 12-20-2005, 09:22 AM   #1
hi i have a rex p5 turbo and its new i read that it is a good idea to lube the front engine bearing with after run engine oil after a run. is this a good idea or would it damage my engine?
pcr2nv is offline   Reply With Quote
Old 12-20-2005, 06:30 PM   #2
SpeedBump57's Avatar
PCR it is not necessary to lube the front bearing as the bearing gets it oil from the fuel during the time the engine is running. What the person that told you that might have meant is to use after run oil when you are done running the engine for the day. At the end of the day dump all remaining fuel out of the fuel tank and turn the engine over and run it until it is out of fuel and then bump it a few more time just to make sure there is no fuel left in the engine. Then simply put a 6 of 8 drops of ARO down the carb throat and a few down the glow plug hole and bump it on the box a few times and you’re done. I race sometimes twice a week and don't even bother with the ARO, just run the fuel out. If I was going to store the engine for a few weeks then I will use ARO.
Hope this helps
SpeedBump57 is offline   Reply With Quote
os18tz front bearing spudly12 Nitro Off-Road 1 09-11-2008 11:53 AM
how do i remove the front bearing on my nitro engine ? jrwagner Rookie Zone 1 04-18-2008 09:14 PM
Front engine bearing grease or oil???????? sptrtrucker Nitro Off-Road 3 03-12-2008 08:12 AM
How Do I Remove Front Bearing From .12 TZ? Gambelli Nitro On-Road 5 12-07-2007 04:27 AM
Front Bearing Jason Halvorson Nitro Off-Road 12 08-12-2007 04:09 PM
SEO by vBSEO 3.5.0
