    Hide Wikipost
Old 06-20-2016, 06:37 AM   -   Wikipost
R/C Tech Forums Thread Wiki: TLR 22-4 2.0 Race Kit Thread!
Last edit by: Kraig
Here are some good build tips and notes from b1narych0ice (thank you):
Specific build step comments/warnings, including areas I replaced stock parts -- Think of this as a FAQ that answers questions I had from other builders about each step:
A-3: You can instead use TLR Aluminum Servo Mount here.
A-5: Be sure to get the shorter screw in the correct hole.
A-6: Use a 76 or 78T spur if you are running a 13.5T-21.5T motor instead of the 84 in the kit! and...
A-6: The plastic washer between the pulley and the thrust assembly should be oriented so that the flat side goes toward the pulley, and the side with the ring goes towards the thrust assembly's metal washer. Diagram in instructions is correct, you just can't see that this washer isn't flat on both sides from the illustration.
A-7: Be sure the nut holding the Full-Time 4WD assembly is nice and tight, I have seen it get loose in the 1.0 car!
A-9: Put the gears on the jackshaft before the c-clips, so that you don't have to deal with getting the c-clips off to put the gears on
B-2: It seems to be possible to push the outdrives on so tight that they bind when spun, be sure to ensure that they spin freely as the manual notes.
B-7: You're screwing the 1.3mm screws into metal, don't crank so hard you strip the heads on the screws. While this is metal-on-metal, the manual doesn't call for loctite here.
B-8: The rear diff has fewer/bigger teeth, the front diff has more/smaller teeth.
C-3/C-4: TLR Aluminum Bellcranks and Exotek steering rack can be used here to increase durability/reduce steering slop
C-8: TLR Aluminum A/B Horn can be used to increase durability/reduce steering slop.
D-2: Don't worry about the kingpins sticking out the front even when the nut is tight, the bumper will push them in and keep them there.
D-5: Shock tower screws were the tightest plastic part on my kit, look from the side when tightening down the tower at the gap between the tower and the front bulkhead, tighten until this gap is closed.
D-6/D-7: Don't mix up the CVA pins and the hex pins, should be easy because hex pins are black and CVA pins are silver.
D-8/D-9: Use a toothpick to get threadlock in the metal block instead of applying it to the shoulder bolt, so that you don't get it between the plastic spindle and the metal block.
E-1/E-2: Don't mix up the 10mm pins for the rear hexes with the 11mm pins for the rear CVAs! They are packaged together and both silver, so it's easy to think you just have 4 pins that are the same!
G-1: No need to install the post on the right side if you are running a shorty and use velcro to attach the body to the mud guards. You can move the right post up or down a little so that it snugly fits your shorty battery.
G-2: Aluminum Servo Horn can be used here.
G-4: Adjust the length of the link and the servo horn position so that both the servo horn and the horn on the bellcranks are parallel with each other, and perpendicular with the link.
Hope this helps some of you that are putting your kits together, and thanks to Frank and the TLR crew for a solid kit!
Driveshaft Update from Frank - I've reviewed some parts today from stock. The 'issue' part is definitely the rear CVA driveshaft bone. The pin slot is not 90* to the bore for the barrel. We are working to get good parts made and here for CS use ASAP.
Some of the parts I checked were not 100% free, but definitely run-able. Keep in mind that the driveshafts should wear in fairly well, and quickly (within a few packs). If you have a 22-4 2.0 and are experiencing issues with the driveshafts, we won't have good replacements for probably a couple of weeks (no definitive timeline yet), so I would recommend running them on track for 1-2 packs, then rechecking. I think most will free up well.
I am sorry that we are having an issue. Everything was great during samples until production, but we'll make sure to get it right, and make it right for those with the bad parts.
What is the proper level for the diffs...i am used to building 8th scale diffs, i would assume its the same?
Just under level. You need some room for the output gear that is in the cap.
Frank can u explain what is the difference between the a and b horn, TLR331018?
It isn't the horn, it is the ackermann setting. B will have less off power, better mid corner steering. A will have more off power steering, less mid corner.
Print Wikipost
Like Tree126Likes
Old 12-05-2016, 11:27 AM   #916
tsair's Avatar
Originally Posted by rhodesengr View Post
Hi guys. I am not new to RC but am somewhat new to RC trucks. I would like to ask for a functional and/or performance comparison between the 22-4 buggy and the TEN-SCBE other than the fact that the SCBE comes RTR. I also understand that one could build the SCTE V3 and convert to a buggy.
Since I still mostly do airborne RC, I am leaning towards the TEN-SCBE but may go the 22-4 route. I'd like to have a durable quality off road vehicle that could be raced but also just for fun. We do have a local outdoor dirt track for 1/10 scale electric.
I have a DX4S to operate with.
The TEN-SCBE is based on the TEN-SCTE short course truck and is more of a 1/8 realistic looking scale off-raod buggy. It should be more durable than the 22-4, which is a 1/0 scale buggy meant for racing only, I don't think people drive it recreationally/bash. It's really low to the ground and wouldn't survive rough terrain.
I think the SCBE would fit your needs much better. It doesn't fit any legal race categories, but if you're just driving it with your friends, no worries.
Razor RC blog:
http://razorrcblog.blogspot.com
http://youtube.com/c/RazorRC
tsair is offline   Reply With Quote
Old 12-06-2016, 02:32 PM   #917
Casper
What did you gear and use for belt settings on your 13.5 buggy for the Top Gun race.
fantomdude is offline   Reply With Quote
Old 12-06-2016, 02:50 PM   #918
Casper's Avatar
Trader Rating: 34 (100%+)
I ran Tekin Gen 3 13.5. I started the event at 26/84 but went up to 28/84. Timing on the motor was slightly over 40 deg (lets call it 42 )
Belt settings are the kit settings.
Could clear the triple the entire race as long as I set up for it properly. If you jumped off that roller before the triple it was not going to make it with a 13.5. Tekin motors put in the fastest 2 lap times of the class. Randy Lathrop with a Tekin powered 22-4 was the only other guy to go sub 15.8 on that layout.
TLR/Losi Team Driver
TLR/Losi | Tekin | DE Racing | Spektrum | Exotek | JBRL | Kolor Koncepts | OC/RC |Sticky Kicks | Imagine It Graphics | Casper-RC.com
TLR 22 4.0 SR, TLR 22T 3.0 (laydown), TLR 22-4 2.0, Spektrum DX6R
WWW.CASPER-RC.COM TLR and Tekin setups
Casper is offline   Reply With Quote
Old 12-06-2016, 03:23 PM   #919
Trader Rating: 15 (100%+)
TLR 22-4 2.0 with the R1 Wurks 13.5 dominated the top gun shootout from start to finish.
This car with a 13.5 is so enjoyable to drive and extremely fast compared to other cars. It /may not be the lightest or whatever but under load there is almost no friction and the suspension is above and beyond any other car out there. 78/25 30 degrees on the can of timing with a fan. I could clear the triple easily from the inside for the first 3 min then had to start to slow down and get a better run at it. Had a battery dump on me in qual 2 which definatly didn't help haha.
kevink123 is offline   Reply With Quote
Old 12-06-2016, 08:58 PM   #920
HomicidalBunny's Avatar
What's the best way to mount a motor fan? Blowing into the motor or sucking air away?
TLR 8ight 4.0 / TLR 8ight-T 2.0
HomicidalBunny is offline   Reply With Quote
Old 12-06-2016, 09:07 PM   #921
Blow
freebird is offline   Reply With Quote
Old 12-06-2016, 09:44 PM   #922
Cheers
Old 12-06-2016, 11:19 PM   #923
Casper's Avatar
Did not need a fan. Motor was running about 130.
Old 12-08-2016, 05:16 PM   #924
Trader Rating: 488 (100%+)
I ordered a bunch of pivots from a shop in Finland a long time ago....they finally arrived. With my luck they're available again. At least I'll probably never need to order one again.
Now that I've discovered the ignore list I plan to use it.....17 and counting!
QDRHRSE is offline   Reply With Quote
Old 12-08-2016, 06:08 PM   #925
tsair's Avatar
I noticed that even if they're not broken, the part that keys into the chassis can develop slop after some hard hits and should be replace anyway. Else, a hard hit can tweak the pivot block to the side a little bit throwing off your trim.
That was one nice thing about the old style steel brace -- it keyed into the chassis and basically made sure your pivot block was always straight.
Razor RC blog:
Old 12-08-2016, 07:11 PM   #926
I've noticed recently that my steering was not re-centering, I thought it was the servo. My front pivot has some play in it and now I'm going to look at it a little harder, thanks for the scoop!
Daragh Slowey
EB410/SPGT2Pro/Orca5.5/1258TGBlk/Nosram shorty
B6D/SPGT2Pro/Fantom7.5/1258TG/Nosram shorty
EB48SL/RX8/TekinT8i/Hitec7599/SMC4500(4S)
Grasshopper/Tekin FX/Twister 27T/FutabaS9551/Speed power
HeavyD99 is offline   Reply With Quote
Old 12-08-2016, 07:22 PM   #927
tsair's Avatar
Yeah, I thought my servo turnbuckle was stripping, 'cause other people complained of that, but I think the pivot block is just tweaking a little bit. It's got 5 bolts holding it in, but the back one doesn't do much. Seem critical to make sure the 5 bolts are very tight. A new block removed about 50% of the potential side-to-side movement in mine.
Razor RC blog:
Old 12-08-2016, 10:01 PM   #928
TLRacing
Frank Root's Avatar
Trader Rating: 25 (100%+)
TLR231045 - Front Pivots
We have checked in a bunch today. We have more in the warehouse now than we've sold in the 6 months the car has shipped. We won't be out anytime soon....
Frank Root -- TLR Project Manager
Twitter - @FrankRoot FB - facebook.com/FrankRootTLR
Team Losi Racing (TLR) - Team Orion - Spektrum - JConcepts - Horizon Hobby - Stick It 1 - Sticky Kicks - Bradley's Fine Line Designs - liverc.com - OCRC Raceway - Tuning Haus - Pacific Coast Hobbies - RIP
Frank Root is offline   Reply With Quote
Old 12-08-2016, 10:38 PM   #929
Phillip F's Avatar
Trader Rating: 17 (100%+)
oh thank you sweet jesus.
Phillip F is offline   Reply With Quote
Old 12-09-2016, 04:21 PM   #930
tsair's Avatar
I posted a review of the 22-4 2.0 on my blog for those interested in an opinion.
http://razorrc.tumblr.com/post/15309...22-4-20-review
Razor RC blog:
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
