    Hide Wikipost
Old 06-20-2016, 06:37 AM   -   Wikipost
R/C Tech Forums Thread Wiki: TLR 22-4 2.0 Race Kit Thread!
Last edit by: Kraig
Here are some good build tips and notes from b1narych0ice (thank you):
Specific build step comments/warnings, including areas I replaced stock parts -- Think of this as a FAQ that answers questions I had from other builders about each step:
A-3: You can instead use TLR Aluminum Servo Mount here.
A-5: Be sure to get the shorter screw in the correct hole.
A-6: Use a 76 or 78T spur if you are running a 13.5T-21.5T motor instead of the 84 in the kit! and...
A-6: The plastic washer between the pulley and the thrust assembly should be oriented so that the flat side goes toward the pulley, and the side with the ring goes towards the thrust assembly's metal washer. Diagram in instructions is correct, you just can't see that this washer isn't flat on both sides from the illustration.
A-7: Be sure the nut holding the Full-Time 4WD assembly is nice and tight, I have seen it get loose in the 1.0 car!
A-9: Put the gears on the jackshaft before the c-clips, so that you don't have to deal with getting the c-clips off to put the gears on
B-2: It seems to be possible to push the outdrives on so tight that they bind when spun, be sure to ensure that they spin freely as the manual notes.
B-7: You're screwing the 1.3mm screws into metal, don't crank so hard you strip the heads on the screws. While this is metal-on-metal, the manual doesn't call for loctite here.
B-8: The rear diff has fewer/bigger teeth, the front diff has more/smaller teeth.
C-3/C-4: TLR Aluminum Bellcranks and Exotek steering rack can be used here to increase durability/reduce steering slop
C-8: TLR Aluminum A/B Horn can be used to increase durability/reduce steering slop.
D-2: Don't worry about the kingpins sticking out the front even when the nut is tight, the bumper will push them in and keep them there.
D-5: Shock tower screws were the tightest plastic part on my kit, look from the side when tightening down the tower at the gap between the tower and the front bulkhead, tighten until this gap is closed.
D-6/D-7: Don't mix up the CVA pins and the hex pins, should be easy because hex pins are black and CVA pins are silver.
D-8/D-9: Use a toothpick to get threadlock in the metal block instead of applying it to the shoulder bolt, so that you don't get it between the plastic spindle and the metal block.
E-1/E-2: Don't mix up the 10mm pins for the rear hexes with the 11mm pins for the rear CVAs! They are packaged together and both silver, so it's easy to think you just have 4 pins that are the same!
G-1: No need to install the post on the right side if you are running a shorty and use velcro to attach the body to the mud guards. You can move the right post up or down a little so that it snugly fits your shorty battery.
G-2: Aluminum Servo Horn can be used here.
G-4: Adjust the length of the link and the servo horn position so that both the servo horn and the horn on the bellcranks are parallel with each other, and perpendicular with the link.
Hope this helps some of you that are putting your kits together, and thanks to Frank and the TLR crew for a solid kit!
Driveshaft Update from Frank - I've reviewed some parts today from stock. The 'issue' part is definitely the rear CVA driveshaft bone. The pin slot is not 90* to the bore for the barrel. We are working to get good parts made and here for CS use ASAP.
Some of the parts I checked were not 100% free, but definitely run-able. Keep in mind that the driveshafts should wear in fairly well, and quickly (within a few packs). If you have a 22-4 2.0 and are experiencing issues with the driveshafts, we won't have good replacements for probably a couple of weeks (no definitive timeline yet), so I would recommend running them on track for 1-2 packs, then rechecking. I think most will free up well.
I am sorry that we are having an issue. Everything was great during samples until production, but we'll make sure to get it right, and make it right for those with the bad parts.
What is the proper level for the diffs...i am used to building 8th scale diffs, i would assume its the same?
Just under level. You need some room for the output gear that is in the cap.
Frank can u explain what is the difference between the a and b horn, TLR331018?
It isn't the horn, it is the ackermann setting. B will have less off power, better mid corner steering. A will have more off power steering, less mid corner.
Print Wikipost
Like Tree131Likes
Old 10-20-2016, 11:01 AM   #691
Casper's Avatar
Trader Rating: 34 (100%+)
Originally Posted by tommynash View Post
How do you like it with a 13.5?
Car is great. I have not done a dang thing to it to lighten it up either. If I stick with 13.5 might put her on a little diet but ran top 3 at Surf City with the car and have had great club race results with it against some stiff competition running it stock so just having fun with the car in the class.
Originally Posted by QDRHRSE View Post
I run my car with a 13.5 and love it. Casper made a comment to my buddy [on the drivers stand] @ a JBRL about how good the 22-4 2.0 is and how my buddy should get one. Unfortunately, my friend is Sponsored by Kyosho and could only share that recommendation with me. I'm glad he did. Although my friend and his ZX6 ended up #1 in the JBRL series this year he loves the 22-4 2.0....he just can't run one. I have not had a single issue yet with mine after 3 weeks of racing. I'm not super fast or aggressive but I do crash like everybody else and, knock on wood, nothing has broken. I don't have any upgrades installed on the car yet. Just like Frank root has said numerous times the book set up is excellent. We're working on a second car now for our winter wet series in a month. We'll see how the 22-4 2.0 does where my XRay use to excel. So far the TLR has not disappointed.
I was just ribbing Eddie (he's a good guy) but glad you took the advice and switched over. The 22-4 has been a great car from the get go and the 2.0 just built on that. I have fun driving the car and have made very few adjustments to it and it drives like a dream. Need to toss in my 6.5 though and do some mod runs with it but 13.5 has been a blast.
TLR/Losi Team Driver
TLR/Losi | Tekin | DE Racing | Spektrum | Exotek | JBRL | Kolor Koncepts | OC/RC |Sticky Kicks | Imagine It Graphics | Casper-RC.com
TLR 22 4.0 SR, TLR 22T 3.0 (laydown), TLR 22-4 2.0, Spektrum DX6R
WWW.CASPER-RC.COM TLR and Tekin setups
Casper is offline   Reply With Quote
Old 10-20-2016, 12:57 PM   #692
Xchange's Avatar
Trader Rating: 10 (92%+)
Hi Gents,
I m wondering if anyone experienced issues with the pulley with premature usure ?
Also does it require a long shake down in order to be perfectly set?
I read that many people upgrade the rear springs with the Kyosho ones or Avid ?
Last question would be what is the best gear to use with a 6.5 ?
Thanks,
Xchange is offline   Reply With Quote
Old 10-20-2016, 01:21 PM   #693
Casper's Avatar
Pulleys last a long time. Set to the kit specifications for tension and you should be good.
After a run or two car is ready to rock. Sets the bone to outdrive bind which is typical for any car and your good to go.
Setups are up to you. I am running it with box stock springs right now and love the car. You driving preference and track conditions will determine if you need or want to change the setup.
Old 10-20-2016, 01:37 PM   #694
Trader Rating: 15 (100%+)
Avid Will no longer make the purple front spring. Just run the kit blues from the 22T.
Gearing is track specific, check the manual.
Daragh Slowey
EB410/SPGT2Pro/Orca5.5/1258TGBlk/Nosram shorty
B6D/SPGT2Pro/Fantom7.5/1258TG/Nosram shorty
EB48SL/RX8/TekinT8i/Hitec7599/SMC4500(4S)
Grasshopper/Tekin FX/Twister 27T/FutabaS9551/Speed power
HeavyD99 is offline   Reply With Quote
Old 10-21-2016, 04:55 PM   #695
Phillip F's Avatar
Trader Rating: 17 (100%+)
Trading in my roller for this buggy. Does the buggy accept Losi wheels? AE wheels doesn't work with it?
Phillip F is offline   Reply With Quote
Old 10-22-2016, 09:02 PM   #696
Casper's Avatar
AE rear wheels would work. Not fronts. The Wheels from the 1.0 are the same for the 2.0.
Old 10-23-2016, 03:45 AM   #697
Default Aluminum front pivot
I have 2 22-4 2.0. Cars both on the shelf with broken front pivots . It is the only part that I have busted on these cars. Multiple times. Why not a aluminum one ? like I have on my 22 3.0.
tlr224 is offline   Reply With Quote
Old 10-23-2016, 08:00 AM   #698
That would be a big heavy part. If you make the pivot out of aluminium, whatever is next inline will break. The force has to go somewhere. The current plastic front pivot is strong enough. For everyone that is breaking front pivots man you must be having some bad crashes. That's not what the car was designed for.
ChrisUU is offline   Reply With Quote
Old 10-23-2016, 11:32 AM   #699
TLRacing
Frank Root's Avatar
Trader Rating: 25 (100%+)
Three reasons:
1. The front pivot doesn't break easily, or unwarranted. It takes a big hit to break one.
2. It would be a VERY expensive part to make, from a huge piece of aluminum and a ton of machining time.
3. With an aluminum pivot, the arms, pin strap and pivot are all stronger, some might start to break chassis... which is an entirely different story... one nobody wants to tell...lol
Frank Root -- TLR Project Manager
Twitter - @FrankRoot FB - facebook.com/FrankRootTLR
Team Losi Racing (TLR) - Team Orion - Spektrum - JConcepts - Horizon Hobby - Stick It 1 - Sticky Kicks - Bradley's Fine Line Designs - liverc.com - OCRC Raceway - Tuning Haus - Pacific Coast Hobbies - RIP
Frank Root is offline   Reply With Quote
Old 10-23-2016, 04:30 PM   #700
Frank , well any idea when the part will be available ? i modified one from a 22-4 1.0 today to get it back on track.
Old 10-23-2016, 04:43 PM   #701
It looks like they will be in stock with most major stockists early November. So looks like it could be as close as 1 week away.
Old 10-23-2016, 05:01 PM   #702
TLRacing
Frank Root's Avatar
Front pivots should be in this week.
Old 10-23-2016, 09:11 PM   #703
dethklok151's Avatar
Trader Rating: 65 (100%+)
This car has been the best 1/10 ive driven. Im runni g pretty close to box setup, only minor changes. The harder i drive it, the faster it wants to go. It begs to be driven strapped. Its like the force, just let go and trust the car.I simply cant say enough, Its friggin awesome, makes me look good.
13.5 is pretty good, but 8.5 is more fun, and just barely faster. No temp issues or breakage issues. Only thing i have broken is the servo linkage ball end.
"hey buddy,ya gonna finish marshalling my car or just lay there and bleed?"
Tamiya euro truck on asphalt
dethklok151 is offline   Reply With Quote
Old 10-24-2016, 08:22 AM   #704
Originally Posted by Frank Root View Post
Originally Posted by tony montana View Post
Frank, what would be the benefit to say running 20k in the diffs versus running the 50k.
The diffs will feel looser, and that diff will rotate quicker and drive less.
So if your car is diving in too hard, and hooked exiting, you would thicken the front diff oil? And if your car is entering perfect, but over rotating on exit, you would thicken the rear diff oil?
TomBODC is offline   Reply With Quote
Old 10-24-2016, 08:26 AM   #705
Hey frank, instead of drilling a hole in the rear arm to run the shocks on the front can I just simply flip the rear arms?
Turning the arms around is the only way I have seen it, the hole is drilled for the
sway bar mounts, stuff moves pretty fast in the setup world so maybe i am behind.
Flipping the arms over but leaving them on the same side? Or flip sides also? I don't know if the left and right arms are exactly the same yet... I just ordered my kit a week ago. It should be at my LHS by Thursday.
