TLR 22-4 2.0 Race Kit Thread!
#212
my rear cvd's were bindy. One feels like it will be okay after running a pack or two, like Frank mentioned. The other is pretty bad. I going to try to find a real thin file to open the slot up slightly.
#215
What servo would you recommend if I'm looking for a new one?
#216
Has anyone else been having issues with the steering? On impacts the car tends to sway either left or right harder than normal, once you subtrim it out again its fine until another impact. Servo is good. Few guys locally with them have been having the same issues.
#217
Are you using the plastic bellcranks and a/b horn? If so it's probably one or the other about to break, usually the post on the bellcrank on my car.
#218
#219
#220
Tried 2 new servos. Find it hard to believe both servos I have used are bad (they are also brand new) and 2 other peoples servos are bad. We are trying to troubleshoot and the only thing we've come up with is the steering link rod ends are stripping out and getting pushed in further on impacts.
#221
#222
Hopefully it fixes my issue too. Thats the only problem we've been having. The buggy is wicked fast and handles amazing.
#223
Great job TLR. This car was pretty much effortless to pick up and drive. Kit setup is working quite well on TRCR's med-high bite clay with a 13.5. Found a competitive pace first night out and folks were commenting that the car looked really, really good.
Had a little trouble with the outdrives...all my fault though. Cleaned them better and used more loctite (as suggested in Frank's video) and they've been solid for several battery packs.
The gear diffs were pretty gritty when they went into the car, but they are buttery smooth now after 10-15 runs.
This car feels worlds more connected than my 44.2 ever did. Very happy with my purchase!
