TLR 22-4 2.0 Race Kit Thread!
#1636
Aluminum shock nuts saves 2-3g and costs $5-10. Another cheap way to lose some weight up high.
#1638
Random question -- should there be any play between the front and rear wheels turning?
If I lock down the front wheels with my hands (holding them in the air) and then try to roll the car back and forth on its back wheels, I can roll it about an inch back and forth before the slipper is forced to engage.
So basically there is about an inch of roll back and forth when one set of wheels is locked down.
Logically I can't see why it would do this unless the middle or back belts is massively slipping (broken teeth or belts). The front belt is fine.
#1640
OK thanks, I'll check it out.
It actually feels like maybe one of the pulleys is spinning on a layshaft about 20 degrees back and forth rather than being completely locked down on the layshaft. I haven't heard of this before, so was just curious.
#1643
I still it me or does everyone else have a loose front end at the pivot and hinge pins? Mine moves side to side fairly easily vs. my 1.0, which has the Exotek steel hinge pin brace. It's the arms in the pivot, ok, I guess after a while it loosens up but has anyone found a fix? My OCD won't let me let it go, lol.
#1646
Jake Thayer inspired weight loss plan
#1649
Im probably down 50g, Jake mentioned he was closer to 100 but he has done more than i have. I honestly dont think the chassis flex should change because the bottom belt channel is still there.
#1650
