    Hide Wikipost
Old 06-20-2016, 06:37 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Official TLR 22-4 2.0 Race Kit Thread!
Last edit by: Kraig
Here are some good build tips and notes from b1narych0ice (thank you):
Specific build step comments/warnings, including areas I replaced stock parts -- Think of this as a FAQ that answers questions I had from other builders about each step:
A-3: You can instead use TLR Aluminum Servo Mount here.
A-5: Be sure to get the shorter screw in the correct hole.
A-6: Use a 76 or 78T spur if you are running a 13.5T-21.5T motor instead of the 84 in the kit! and...
A-6: The plastic washer between the pulley and the thrust assembly should be oriented so that the flat side goes toward the pulley, and the side with the ring goes towards the thrust assembly's metal washer. Diagram in instructions is correct, you just can't see that this washer isn't flat on both sides from the illustration.
A-7: Be sure the nut holding the Full-Time 4WD assembly is nice and tight, I have seen it get loose in the 1.0 car!
A-9: Put the gears on the jackshaft before the c-clips, so that you don't have to deal with getting the c-clips off to put the gears on
B-2: It seems to be possible to push the outdrives on so tight that they bind when spun, be sure to ensure that they spin freely as the manual notes.
B-7: You're screwing the 1.3mm screws into metal, don't crank so hard you strip the heads on the screws. While this is metal-on-metal, the manual doesn't call for loctite here.
B-8: The rear diff has fewer/bigger teeth, the front diff has more/smaller teeth.
C-3/C-4: TLR Aluminum Bellcranks and Exotek steering rack can be used here to increase durability/reduce steering slop
C-8: TLR Aluminum A/B Horn can be used to increase durability/reduce steering slop.
D-2: Don't worry about the kingpins sticking out the front even when the nut is tight, the bumper will push them in and keep them there.
D-5: Shock tower screws were the tightest plastic part on my kit, look from the side when tightening down the tower at the gap between the tower and the front bulkhead, tighten until this gap is closed.
D-6/D-7: Don't mix up the CVA pins and the hex pins, should be easy because hex pins are black and CVA pins are silver.
D-8/D-9: Use a toothpick to get threadlock in the metal block instead of applying it to the shoulder bolt, so that you don't get it between the plastic spindle and the metal block.
E-1/E-2: Don't mix up the 10mm pins for the rear hexes with the 11mm pins for the rear CVAs! They are packaged together and both silver, so it's easy to think you just have 4 pins that are the same!
G-1: No need to install the post on the right side if you are running a shorty and use velcro to attach the body to the mud guards. You can move the right post up or down a little so that it snugly fits your shorty battery.
G-2: Aluminum Servo Horn can be used here.
G-4: Adjust the length of the link and the servo horn position so that both the servo horn and the horn on the bellcranks are parallel with each other, and perpendicular with the link.
Hope this helps some of you that are putting your kits together, and thanks to Frank and the TLR crew for a solid kit!
Driveshaft Update from Frank - I've reviewed some parts today from stock. The 'issue' part is definitely the rear CVA driveshaft bone. The pin slot is not 90* to the bore for the barrel. We are working to get good parts made and here for CS use ASAP.
Some of the parts I checked were not 100% free, but definitely run-able. Keep in mind that the driveshafts should wear in fairly well, and quickly (within a few packs). If you have a 22-4 2.0 and are experiencing issues with the driveshafts, we won't have good replacements for probably a couple of weeks (no definitive timeline yet), so I would recommend running them on track for 1-2 packs, then rechecking. I think most will free up well.
I am sorry that we are having an issue. Everything was great during samples until production, but we'll make sure to get it right, and make it right for those with the bad parts.
What is the proper level for the diffs...i am used to building 8th scale diffs, i would assume its the same?
Just under level. You need some room for the output gear that is in the cap.
Frank can u explain what is the difference between the a and b horn, TLR331018?
It isn't the horn, it is the ackermann setting. B will have less off power, better mid corner steering. A will have more off power steering, less mid corner.
Print Wikipost
Like Tree103Likes
Old 05-11-2016, 02:51 PM   #16
hotrodchevy14's Avatar
Trader Rating: 106 (100%+)
Originally Posted by Lone Drifter View Post
I Just 22-4 at 3:30 pm central time will there be a conversion kit
Don't worry about it
...oh our lady of blessed acceleration, don't fail me now..
sponsored by:Team lint in my pockets racing...
hotrodchevy14 is offline   Reply With Quote
Old 05-11-2016, 03:01 PM   #17
brian cox's Avatar
Trader Rating: 54 (100%+)
Frank you're such a tease!!
Team Orion---Bradley Fine Line Design---AKA
brian cox is offline   Reply With Quote
Old 05-11-2016, 04:59 PM   #18
gokarter64's Avatar
Fingers crossed for gear diffs and easy access on the belts. I could certantly use a fresh build.
gokarter64 is offline   Reply With Quote
Old 05-11-2016, 05:32 PM   #19
Beau S's Avatar
Beau S is offline   Reply With Quote
Old 05-11-2016, 07:54 PM   #20
losicorey's Avatar
+1,000,000!!
losicorey is offline   Reply With Quote
Old 05-12-2016, 01:43 AM   #21
akimrc's Avatar
New detailed photos and info is on REDRC.
TRF211XM
XFactory X6 Cubed
akimrc is offline   Reply With Quote
Old 05-12-2016, 02:25 AM   #22
You should be happy...
BigReade is offline   Reply With Quote
Old 05-12-2016, 05:12 AM   #23
http://www.tlracing.com/Products/Def...3007#prodMedia
freebird is offline   Reply With Quote
Old 05-12-2016, 06:57 AM   #24
it's basically the same car with the few tweaks everyone wanted...
split drive case
gear diffs (they look really thin, wonder how these will hold up)
otherwise im not impressed. it took 3 years to make those changes?
| XRAY XB8E 16' | XRAY XB4 16' | XRAY XB2 CE 17' |
| New England | RCE | RCM |
lyons238 is offline   Reply With Quote
Old 05-12-2016, 07:04 AM   #25
I like the gear diffs, I wonder if they will hold up to higher power motors. I will be pre ordering tonight.
Bh1989 is offline   Reply With Quote
Old 05-12-2016, 07:07 AM   #26
thecman26's Avatar
Trader Rating: 98 (100%+)
The JR Mitch paint scheme! VERY nice!
Chris Keen: Viola, Kansas
Kyosho RZ6, TLR 22 3.0, TLR 4.0 SR (soon),& 22T 3.0
"I'm too drunk to taste this chicken!", Col. Sanders
thecman26 is offline   Reply With Quote
Old 05-12-2016, 07:25 AM   #27
I have the 1.0 and its a great car but I'll have this new 2.0 ordered next month and will be reading setup tips and tricks right here.
I hope they have designed stronger arms for the 2.0
Exojoe is offline   Reply With Quote
Old 05-12-2016, 07:25 AM   #28
skrichter's Avatar
Send a message via AIM to skrichter
For those who want to convert current car to gear diffs -- will you need to buy the new front pivot and belt covers?
http://www.tlracing.com/Products/Def...odID=TLR231045
http://www.tlracing.com/Products/Def...odID=TLR231043
LiveRC.com | Dirt Heaven Hobby & Raceway
skrichter is offline   Reply With Quote
Old 05-12-2016, 07:31 AM   #29
Pre-order now available at Horizon Hobby
Ffejrey is offline   Reply With Quote
Old 05-12-2016, 08:30 AM   #30
3srcracing's Avatar
Trader Rating: 25 (100%+)
Why the gear diffs? I know a lot of the associated drivers are going to ball diff front and rear and center gear diff.
3srcracing is offline   Reply With Quote
