    Hide Wikipost
Old 06-07-2017, 10:46 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Team Associated B6 & B6D thread
Last edit by: RCBuddha
Welcome to the B6 Wiki!
Quick links to all the sections on the first page!
Frequently asked questions - the most common questions you may have answered here!
Aftermarket Parts - parts for the B6 and B6D
Tech Tutorials- tuning guides, ball diff and shock building videos and tutorials
How to's and build-specific posts
Team Associated Laydown transmission conversion for B6D:
Laydown conversion
Instruction Manuals:
B6: B6 Manual and setup sheets
B6D: B6D Manual and setup sheets
How to Sand and Seal carbon fiber:
Sanding and sealing carbon fiber
Sanding and sealing carbon fiber 2
Sanding and sealing carbon fiber 3
Sanding and sealing carbon fiber 4
Charts for Quick reference:
1) put inner bearing in hub
2) slide large shim over axle all the way up to the back of the axle
3) slide axle/bone into hub carrier
4) slide small shim onto axle through hub carrier
5) push outter bearing into hub carrier
using that i'm able to put my normal male silverback gorilla wheel nut tightening job and there's no binding. in the pictures that come with the shims (the pic socket posted) it seems like they want you to slide both shims onto the axle before sliding the axle into the hub carrier and like i said, that doesn't work.
I've traditionally done the diff screw head on the left side (driver's side), but have since switched to the Right side (passenger side) regardless of transmission type (3 gear RM vs 3 gear MM and 4 gear MM).
Kdub (Kurt Wenger, former AE designer) had this to say on the matter:
Originally Posted by kdub View Post
I think I count as an authority on the matter. I always run my diff screw on the right side (when sitting "inside" the car). I take off the tire and pull the outer hinge pin to get to the adjustment screw.
The right rear is the way the AE manuals state (or used to state). It really shouldn't matter since you go around turns both left and right.
B6D 3-gear:
Print Wikipost
Like Tree323Likes
Old 07-13-2016, 03:30 PM   #1456
steelers82's Avatar
Originally Posted by Jmuck69 View Post
Try +1 on axle front and rear axle heights. Refer to Spencer's JC Spring nationals setup sheet. he ran 20.5mm rear and 21mm front with 5mm cup offset
Yeah that's the set up I'm trying to achieve, I know the kit comes with the rear hub inserts to do it, but do you have to buy the different front hat bushings to change the front axel height or can you do it with the ones that come in the kit? And if so do I just put the thicker one on bottom?
steelers82 is offline   Reply With Quote
Old 07-13-2016, 03:30 PM   #1457
TAW
Trader Rating: 18 (100%+)
Send a message via AIM to TAW
So what the consensus to treating the Edges of the CF shock towers with CA glue?
TAW is offline   Reply With Quote
Old 07-13-2016, 03:33 PM   #1458
Trader Rating: 140 (100%+)
sand and ca glue, A MUST, In my opinion
seals, helps prevent splintering, cracking, delamination....
if you ever had a TC with a carbon chassis , You know
been raced and crashed, already went through a front wing,,, towers dont show it..
RC RACING DESIGNS..
slick1 is offline   Reply With Quote
Old 07-13-2016, 04:05 PM   #1459
steelers82's Avatar
Old 07-13-2016, 04:15 PM   #1460
MOmo's Avatar
For those feeling LEFT OUT,
or
who have the desire for your very OWN B6 and B6D but don't have the $$ -
AE Has you covered!
B6
https://www.teamassociated.com/pdf/B6_Kit_FB_85x11.pdf
B6D
https://www.teamassociated.com/pdf/B6D_Kit_FB_85x11.pdf
Get the "D" before anyone else!
MOmo
RACE CARS: B44.1, RC8.2E FT, RC8TE ME, YZ-2T, D08
RADIO: Futaba 4PKS/3PKS. BATTERY: Venom
ESC: SpeedPassion. MOTORS: SpeedPassion / Venom
"Im not a racer, but I play one on the Internet"
MOmo is offline   Reply With Quote
Old 07-13-2016, 05:52 PM   #1461
Silverstonev8's Avatar
What servo do you guys plan on using. I have a reedy 1508 to put in it but was thinking of the new low profile ones look nice.
Silverstonev8 is offline   Reply With Quote
Old 07-13-2016, 06:05 PM   #1462
These cars are lite. My B6 with out of box parts, nothing exotic, full size servo and thin shorty battery is 1465 grm.
sgtlt is offline   Reply With Quote
Old 07-13-2016, 06:16 PM   #1463
Suspended
Trader Rating: 61 (100%+)
Car is slightly under weight.
Edit: this is with a full size shorty.
Best Avatar on rc-tech
Socket is offline   Reply With Quote
Old 07-13-2016, 06:34 PM   #1464
rvrslt1's Avatar
Trader Rating: 25 (100%+)
What is the story with running shocks in front of rear tower or behind? I'm guessing with the lay down trans you can use what works best.
rvrslt1 is offline   Reply With Quote
Old 07-13-2016, 06:41 PM   #1465
Jmuck69's Avatar
Check out page 21 of the B6 manual. Explains it all.
B6D | B64D
Schelle Racing Concepts - www.schelleracing.com
Amain Hobbies - www.amain.com
Jmuck69 is offline   Reply With Quote
Old 07-13-2016, 06:50 PM   #1466
rvrslt1's Avatar
Thanks. I plan to start the build on Friday. Have not opened the box yet.
Old 07-13-2016, 07:27 PM   #1467
RCBuddha's Avatar
Trader Rating: 35 (100%+)
http://www.redrc.net/2016/07/jconcep...s/#more-115972
RCBuddha is offline   Reply With Quote
Old 07-13-2016, 07:32 PM   #1468
Johnn27's Avatar
Trader Rating: 71 (100%+)
Cool Build
I am curious are racers building the B6d stock out of the box first and running it that way or are racers going straight to the laydown trans, laydown trans and long shock tower in the rear , and where are they mounting the rear shocks.
I was thinking go straight to the letdown trans , go long shock tower, and mount the shocks behind the rear arm to start? thoughts? comment? opinions?
Johnn27 is offline   Reply With Quote
Old 07-13-2016, 07:42 PM   #1469
Can we get the shock eyelet length guid from page 82 put up in the wiki at the top of the page?
BruceR. is offline   Reply With Quote
Old 07-13-2016, 07:48 PM   #1470
RCBuddha's Avatar
both charts are there. Anyone can edit the wiki's btw...
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
