    Hide Wikipost
Old 06-07-2017, 10:46 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Team Associated B6 & B6D thread
Last edit by: RCBuddha
Welcome to the B6 Wiki!
Quick links to all the sections on the first page!
Frequently asked questions - the most common questions you may have answered here!
Aftermarket Parts - parts for the B6 and B6D
Tech Tutorials- tuning guides, ball diff and shock building videos and tutorials
How to's and build-specific posts
Team Associated Laydown transmission conversion for B6D:
Laydown conversion
Instruction Manuals:
B6: B6 Manual and setup sheets
B6D: B6D Manual and setup sheets
How to Sand and Seal carbon fiber:
Sanding and sealing carbon fiber
Sanding and sealing carbon fiber 2
Sanding and sealing carbon fiber 3
Sanding and sealing carbon fiber 4
Charts for Quick reference:
1) put inner bearing in hub
2) slide large shim over axle all the way up to the back of the axle
3) slide axle/bone into hub carrier
4) slide small shim onto axle through hub carrier
5) push outter bearing into hub carrier
using that i'm able to put my normal male silverback gorilla wheel nut tightening job and there's no binding. in the pictures that come with the shims (the pic socket posted) it seems like they want you to slide both shims onto the axle before sliding the axle into the hub carrier and like i said, that doesn't work.
I've traditionally done the diff screw head on the left side (driver's side), but have since switched to the Right side (passenger side) regardless of transmission type (3 gear RM vs 3 gear MM and 4 gear MM).
Kdub (Kurt Wenger, former AE designer) had this to say on the matter:
Originally Posted by kdub View Post
I think I count as an authority on the matter. I always run my diff screw on the right side (when sitting "inside" the car). I take off the tire and pull the outer hinge pin to get to the adjustment screw.
The right rear is the way the AE manuals state (or used to state). It really shouldn't matter since you go around turns both left and right.
B6D 3-gear:
Print Wikipost
Like Tree327Likes
Old 07-13-2016, 12:29 PM   #1441
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 156 (100%+)
Originally Posted by BruceR. View Post
Also looks like I'm missing the 2 outer steering ball studs. Supposed to be 6mm but I have a couple of 10mm ball studs. I can make them work, just thinking maybe some one got in a hurry packing things up to get kits out the door.
Outer rears should be 10mm. They should be able to put a locknut on the back to secure it better.
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 07-13-2016, 12:44 PM   #1442
I'm stuck at work till 5 and my b6 is on my front door at home!
dsms4ever is offline   Reply With Quote
Old 07-13-2016, 01:00 PM   #1443
I meant the front. Steering ball studs. Page 7 of the manual, goes on the steering block arm. I don't have the 6mm, but DO have 2 10mm left. I can make the 10 work, might just need to demel off any excess length if I get any interference.
BruceR. is offline   Reply With Quote
Old 07-13-2016, 01:07 PM   #1444
Originally Posted by myself
Originally Posted by Finalist View Post
JC B5M Fin ti turnbuckles work very well. Zero stud/cup binding AND zero turnbuckle theeads showing.
Cant buy em in germany
Or is the J2225 the correct number? Would be cheaper to get the Lunsfords (not a set, I can buy the 48mm ones for 10 a pair)?
Anyone please?
man1ac is offline   Reply With Quote
Old 07-13-2016, 01:07 PM   #1445
Super Moderator
Originally Posted by man1ac View Post
Anyone please?
What? The correct JC part number is 2580.
http://www.jconcepts.net/shop/b6-b6d...turnbuckle-set
Old 07-13-2016, 01:17 PM   #1446
Silverstonev8's Avatar
I went with the Lunsfords. The tuner kit has 4x46mm and 4x48mm $26
http://www.lunsfordracing.com/mm5/me...egory_Code=NEW
Silverstonev8 is offline   Reply With Quote
Old 07-13-2016, 01:36 PM   #1447
rvrslt1's Avatar
Trader Rating: 25 (100%+)
Sweet deal! Just ordered a set. thanks
rvrslt1 is offline   Reply With Quote
Old 07-13-2016, 02:10 PM   #1448
steelers82's Avatar
I'm having trouble getting low enough ride hight in my b6d I put a laydown in it and I'm trying to get 21 mm ride hight and I can only get it down to about 22 at best with the rear shock collars all the way up on the shocks???
steelers82 is offline   Reply With Quote
Old 07-13-2016, 02:20 PM   #1449
Trader Rating: 140 (100%+)
what offset do you have in rear hubs.
if you have all the way to bottom, you are at the tallest setting
should be the 1/2 insert with tab up, this is the +1 setting
should be 5mm offset spring collar
RC RACING DESIGNS..
slick1 is offline   Reply With Quote
Old 07-13-2016, 02:32 PM   #1450
steelers82's Avatar
i have everything built to box stock set up with 5mm spring cups
Old 07-13-2016, 02:39 PM   #1451
Can't be bought in Germany, i posted the B5s Set which should work fine...if I posted the right set of turnbuckles (these are the only ones i could buy here)
Old 07-13-2016, 02:40 PM   #1452
AZJP's Avatar
Trader Rating: 20 (100%+)
Use Yatabe Arena springs, or try using the 0 offset cups. I ran 16mm with the Yatabe Springs no problem.
AZJP is offline   Reply With Quote
Old 07-13-2016, 02:43 PM   #1453
Super Moderator
Run the 0 offset spring cups. This will allow you to get to a lower ride height
Old 07-13-2016, 03:15 PM   #1454
Jmuck69's Avatar
Try +1 on axle front and rear axle heights. Refer to Spencer's JC Spring nationals setup sheet. he ran 20.5mm rear and 21mm front with 5mm cup offset
B6D | B64D
Schelle Racing Concepts - www.schelleracing.com
Amain Hobbies - www.amain.com
Jmuck69 is offline   Reply With Quote
Old 07-13-2016, 03:28 PM   #1455
Yup, same here, i have no issues
RC RACING DESIGNS..
Currently Active Users Viewing This Thread: 11 (1 members and 10 guests)
jct108
