    Hide Wikipost
Old 06-07-2017, 10:46 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Team Associated B6 & B6D thread
Last edit by: RCBuddha
Welcome to the B6 Wiki!
Quick links to all the sections on the first page!
Frequently asked questions - the most common questions you may have answered here!
Aftermarket Parts - parts for the B6 and B6D
Tech Tutorials- tuning guides, ball diff and shock building videos and tutorials
How to's and build-specific posts
Team Associated Laydown transmission conversion for B6D:
Laydown conversion
Instruction Manuals:
B6: B6 Manual and setup sheets
B6D: B6D Manual and setup sheets
How to Sand and Seal carbon fiber:
Sanding and sealing carbon fiber
Sanding and sealing carbon fiber 2
Sanding and sealing carbon fiber 3
Sanding and sealing carbon fiber 4
Charts for Quick reference:
1) put inner bearing in hub
2) slide large shim over axle all the way up to the back of the axle
3) slide axle/bone into hub carrier
4) slide small shim onto axle through hub carrier
5) push outter bearing into hub carrier
using that i'm able to put my normal male silverback gorilla wheel nut tightening job and there's no binding. in the pictures that come with the shims (the pic socket posted) it seems like they want you to slide both shims onto the axle before sliding the axle into the hub carrier and like i said, that doesn't work.
I've traditionally done the diff screw head on the left side (driver's side), but have since switched to the Right side (passenger side) regardless of transmission type (3 gear RM vs 3 gear MM and 4 gear MM).
Kdub (Kurt Wenger, former AE designer) had this to say on the matter:
Originally Posted by kdub View Post
I think I count as an authority on the matter. I always run my diff screw on the right side (when sitting "inside" the car). I take off the tire and pull the outer hinge pin to get to the adjustment screw.
The right rear is the way the AE manuals state (or used to state). It really shouldn't matter since you go around turns both left and right.
B6D 3-gear:
Print Wikipost
Like Tree369Likes
Old 07-13-2016, 08:22 AM   #1426
Finalist's Avatar
Originally Posted by Sean B. View Post
Thanks for that
I highly recommend Bubba. Very fast, communicates extrememly well, helpful and quality.
Finalist is offline   Reply With Quote
Old 07-13-2016, 08:40 AM   #1427
PW
PW's Avatar
Send a message via AIM to PW
Bruce...The CVD length is fine, just move your rear ballstud to the center hole on the rear inner camber mount and you should be set.
Originally Posted by BruceR. View Post
Have any of you heard of cvd length issues with the new kits? My cvd's are 96mm. When I set the rear camber links per the manual (27mm between the ball cups) the cvds just barely touch the out drives. Now, I haven't put it on the set up station and fine tuned anything, but I thought this was odd. Here's a couple pics of what I'm talking about. Any down travel at all would have the shafts popping out of the out drives.
Paul Wynn
JConcepts - Team Associated - Reedy - XP - TSR Products - MIP - Stickit1
P1 Brand - "If it's only for fun; then take out the transponder?!"
PW is offline   Reply With Quote
Old 07-13-2016, 08:43 AM   #1428
So I can rip out my B5R's Ti Turnbuckles and fit them onto my B6D? Any issues and reasons why I shouldnt do that?
man1ac is offline   Reply With Quote
Old 07-13-2016, 09:06 AM   #1429
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
the b5 turnbuckles are longer. if you try to run short links you may run into issues.
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 07-13-2016, 09:14 AM   #1430
So if I look at the Lunsford Punisher for the B5m they are listed with:
4x 41,2mm
2x 44,4mm
So they would be a little bit shorter for the B6 and even a big time shorter than the kit ones from the B5?
Old 07-13-2016, 09:17 AM   #1431
Finalist's Avatar
JC B5M Fin ti turnbuckles work very well. Zero stud/cup binding AND zero turnbuckle theeads showing.
Old 07-13-2016, 09:22 AM   #1432
Cant buy em in germany
Or is the J2225 the correct number? Would be cheaper to get the Lunsfords (not a set, I can buy the 48mm ones for 10€ a pair)?
Old 07-13-2016, 09:59 AM   #1433
Suspended
Trader Rating: 61 (100%+)
Camber is drastically wrong.
Best Avatar on rc-tech
Socket is offline   Reply With Quote
Old 07-13-2016, 10:06 AM   #1434
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 158 (100%+)
Looks to be another glitch in the manual. The B6 kit states to install the ball stud into the outer hole like you have but also states that the width between ball cups as 27mm. If you look at that pic it shows the inner ball stud as the middle hole. Once you get everything together and properly set camber you will be fine. Im sure it looks like you have about 4 degrees positive camber right now. I never pay attention to the manual as far as turnbuckle length. It always gets adjusted after I have the car complete.
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 07-13-2016, 11:07 AM   #1435
yes, this was pointed out. the online manual was fixed. it shows the middle hole
Old 07-13-2016, 11:30 AM   #1436
Suspended
I look forward to the days of no manual in the box. Online only...
Old 07-13-2016, 11:54 AM   #1437
When installing the lay down in the B6D, should just stick to the manual for everything else? For example, you don't run the shocks on the inside or set the camber links longer like the B6 manual states for the B6? Correct?
40yoCaliRacer is offline   Reply With Quote
Old 07-13-2016, 11:54 AM   #1438
TheKraken's Avatar
I don't... I prefer to have my manual at my desk when I'm building and no i'm not printing out an online one.
TheKraken is offline   Reply With Quote
Old 07-13-2016, 12:44 PM   #1439
I moved the inner ball stud to the middle hole. Had to go back to the manual and look at a picture with a magnifying glass. So it seems better but probably still a bit of positive camber. Once I get the thing on the set up station I'll fine-tune.
Also looks like I'm missing the 2 outer steering ball studs. Supposed to be 6mm but I have a couple of 10mm ball studs. I can make them work, just thinking maybe some one got in a hurry packing things up to get kits out the door.
BruceR. is offline   Reply With Quote
Old 07-13-2016, 12:56 PM   #1440
Silverstonev8's Avatar
No need to print...
Silverstonev8 is offline   Reply With Quote
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
Nat Maniac
