    Hide Wikipost
Old 06-07-2017, 10:46 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Team Associated B6 & B6D thread
Last edit by: RCBuddha
Welcome to the B6 Wiki!
Quick links to all the sections on the first page!
Frequently asked questions - the most common questions you may have answered here!
Aftermarket Parts - parts for the B6 and B6D
Tech Tutorials- tuning guides, ball diff and shock building videos and tutorials
How to's and build-specific posts
Team Associated Laydown transmission conversion for B6D:
Laydown conversion
Instruction Manuals:
B6: B6 Manual and setup sheets
B6D: B6D Manual and setup sheets
How to Sand and Seal carbon fiber:
Sanding and sealing carbon fiber
Sanding and sealing carbon fiber 2
Sanding and sealing carbon fiber 3
Sanding and sealing carbon fiber 4
Charts for Quick reference:
1) put inner bearing in hub
2) slide large shim over axle all the way up to the back of the axle
3) slide axle/bone into hub carrier
4) slide small shim onto axle through hub carrier
5) push outter bearing into hub carrier
using that i'm able to put my normal male silverback gorilla wheel nut tightening job and there's no binding. in the pictures that come with the shims (the pic socket posted) it seems like they want you to slide both shims onto the axle before sliding the axle into the hub carrier and like i said, that doesn't work.
I've traditionally done the diff screw head on the left side (driver's side), but have since switched to the Right side (passenger side) regardless of transmission type (3 gear RM vs 3 gear MM and 4 gear MM).
Kdub (Kurt Wenger, former AE designer) had this to say on the matter:
Originally Posted by kdub View Post
I think I count as an authority on the matter. I always run my diff screw on the right side (when sitting "inside" the car). I take off the tire and pull the outer hinge pin to get to the adjustment screw.
The right rear is the way the AE manuals state (or used to state). It really shouldn't matter since you go around turns both left and right.
B6D 3-gear:
Print Wikipost
Like Tree325Likes
Old 07-12-2016, 09:49 AM   #1366
Originally Posted by michwolv View Post
Is there anywhere to get the B6D?
NorCal Hobbies had a pile of them when I was in there yesterday
https://www.shapeways.com/shops/eriksparts
otter is offline   Reply With Quote
Old 07-12-2016, 10:12 AM   #1367
rvrslt1's Avatar
Trader Rating: 25 (100%+)
Originally Posted by Socket View Post
Gear diffs and 17.5 do not mix. Those things are HEAVY.
Wenger right now is KILLING it in 17.5 with the D car at OCRC.
Is he using the lay down trans? My B6D is showing up today
rvrslt1 is online now   Reply With Quote
Old 07-12-2016, 10:30 AM   #1368
kdub's Avatar
Default B6D indoor clay setup
Here is my OCRC Setup after a few days running the B6D. This is medium to high grip indoor clay.
Chief Engineer, Schelle Racing Innovations, SchelleRacing.com - Team Associated - Reedy - JConcepts - Sanwa - MIP - StickyKicksRC - UpGradeRC - Darkside Designs
kdub is offline   Reply With Quote
Old 07-12-2016, 10:41 AM   #1369
rvrslt1's Avatar
Thank you. So the B5M rear hubs will still work on the B6?
Old 07-12-2016, 10:42 AM   #1370
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 156 (100%+)
Yes, they will work on the B6D, the B6 utilizes a different roll center insert in the hub and the Schelle hubs wont be able accommodate that setting for.
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 07-12-2016, 10:51 AM   #1371
Johnn27's Avatar
Trader Rating: 71 (100%+)
Default Springs
I have not seen any set ups using the kit springs ?
Johnn27 is offline   Reply With Quote
Old 07-12-2016, 10:52 AM   #1372
Super Moderator
The stock setup uses kit springs.
Old 07-12-2016, 11:03 AM   #1373
goehm's Avatar
Trader Rating: 44 (100%+)
I weighed my SRX2 gear vs ball, and gear was lighter. What's the weight difference between the AE diffs?
--GO!
Come visit G's RC Raceway / Shippensburg, PA / www.GSRC.us
goehm is offline   Reply With Quote
Old 07-12-2016, 11:16 AM   #1374
rvrslt1's Avatar
I plan to run the B6D with the lay down trans so does not sound like my B5m hubs will work
Old 07-12-2016, 11:18 AM   #1375
Super Moderator
Try the different inserts in the stock hubs. You may like the std D setting and in that case your schelle hubs would work.
Old 07-12-2016, 11:51 AM   #1376
Suspended
Trader Rating: 61 (100%+)
Stand up.
Best Avatar on rc-tech
Socket is offline   Reply With Quote
Old 07-12-2016, 11:52 AM   #1377
Suspended
Before I start doing homework, had to fire up the lathe
Old 07-12-2016, 11:52 AM   #1378
Suspended
Also got some goodies in...shooting for 1400 grams with a fullsize shorty.
Old 07-12-2016, 01:37 PM   #1379
Trader Rating: 14 (100%+)
I thought i read someplace that gear diffs were actually lighter. It seemed counter intuitive so it stuck in my head.
"Go that way really fast, if something gets in your way, turn"
TLR 22 3.5 SR, TLR 22-4 1.875 vs Tekno EB410, Sanwa M12S, Savox, Hobbywing, Schuurspeed, Protek
DG Designs is offline   Reply With Quote
Old 07-12-2016, 02:24 PM   #1380
fullsyzz's Avatar
Trader Rating: 103 (100%+)
Yokomo green rear spring....Yatabe 1050 green, or A1200 green?
fullsyzz is offline   Reply With Quote
Currently Active Users Viewing This Thread: 6 (1 members and 5 guests)
HeavyD99
