    Hide Wikipost
Old 06-07-2017, 10:46 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Team Associated B6 & B6D thread
Last edit by: RCBuddha
Welcome to the B6 Wiki!
Quick links to all the sections on the first page!
Frequently asked questions - the most common questions you may have answered here!
Aftermarket Parts - parts for the B6 and B6D
Tech Tutorials- tuning guides, ball diff and shock building videos and tutorials
How to's and build-specific posts
Team Associated Laydown transmission conversion for B6D:
Laydown conversion
Instruction Manuals:
B6: B6 Manual and setup sheets
B6D: B6D Manual and setup sheets
How to Sand and Seal carbon fiber:
Sanding and sealing carbon fiber
Sanding and sealing carbon fiber 2
Sanding and sealing carbon fiber 3
Sanding and sealing carbon fiber 4
Charts for Quick reference:
1) put inner bearing in hub
2) slide large shim over axle all the way up to the back of the axle
3) slide axle/bone into hub carrier
4) slide small shim onto axle through hub carrier
5) push outter bearing into hub carrier
using that i'm able to put my normal male silverback gorilla wheel nut tightening job and there's no binding. in the pictures that come with the shims (the pic socket posted) it seems like they want you to slide both shims onto the axle before sliding the axle into the hub carrier and like i said, that doesn't work.
I've traditionally done the diff screw head on the left side (driver's side), but have since switched to the Right side (passenger side) regardless of transmission type (3 gear RM vs 3 gear MM and 4 gear MM).
Kdub (Kurt Wenger, former AE designer) had this to say on the matter:
Originally Posted by kdub View Post
I think I count as an authority on the matter. I always run my diff screw on the right side (when sitting "inside" the car). I take off the tire and pull the outer hinge pin to get to the adjustment screw.
The right rear is the way the AE manuals state (or used to state). It really shouldn't matter since you go around turns both left and right.
B6D 3-gear:
Print Wikipost
Like Tree372Likes
Old 07-11-2016, 10:43 PM   #1351
F18engineguy's Avatar
Trader Rating: 216 (100%+)
Originally Posted by Matt Trimmings View Post
Looks like they are soldered on at an angle.
http://www.reedyrace.com/ae/spotligh...vkin_TacomaRC/
How are they mounting those fans, double side tape?
VA Beach
F18engineguy is offline   Reply With Quote
Old 07-11-2016, 10:57 PM   #1352
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
yes. same as the 4wd cars. the black 3m works great
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 07-11-2016, 10:58 PM   #1353
Originally Posted by 828Army View Post
Hey guys where is the best deal on b6d?
I saw on tower they have coupons for 30 bucks off. Or is the $309 the lowest price everywhere?
45 off at tower with a member ship and free shipping
Old 07-12-2016, 12:16 AM   #1354
Phillip F's Avatar
Trader Rating: 17 (100%+)
fans? is there more than one?
Phillip F is offline   Reply With Quote
Old 07-12-2016, 05:28 AM   #1355
celt's Avatar
Originally Posted by RCBuddha View Post
on a recent jconcepts video, Jason Rouna stated that their turnbuckles for the B6/B6D were a little shorter than the B5 ones.
For reference, I looked the B5M and the B6 manuals and on average, the B5M turnbuckles are about 4mm longer.
B5M: 3inx2.06in=3inx52.324mm
B6: 3inx48mm
One would probably work on the other in a pinch, but for reference, they are of different lengths.
"Soon they will get everything they deserve. This isn't about trite elitism, but the otherwise intellectual and educated classes refusing to think for themselves. I call it situational ignorance, and painfully intolerable."
Stan Garvin
celt is offline   Reply With Quote
Old 07-12-2016, 07:30 AM   #1356
SuperRC's Avatar
Originally Posted by Socket View Post
No. You'll need big bore springs.
I recommend Kyosho's or the Yokomo's.
I think by standard, he was implying standard big bore springs (i.e from the B4.2/B5 buggies).
The link he posted shows big bores. All the same part numbers as shown in the B6 manual.
SS
SuperRC is offline   Reply With Quote
Old 07-12-2016, 08:15 AM   #1357
Is there anywhere to get the B6D?
michwolv is offline   Reply With Quote
Old 07-12-2016, 08:41 AM   #1358
Trader Rating: 55 (100%+)
i saw a few on eBay
Speedychris22 is offline   Reply With Quote
Old 07-12-2016, 08:42 AM   #1359
Edit I was looking at the b6 I'm sure there will be people selling them at a premium on ebay.
rannblod is offline   Reply With Quote
Old 07-12-2016, 08:50 AM   #1360
Go to or get in touch with SDRC. They said on facebook they could ship to someone inquiring.
https://www.facebook.com/SDRC-Raceway-201072183283251/
40yoCaliRacer is offline   Reply With Quote
Old 07-12-2016, 08:53 AM   #1361
Here is a great price on one.
http://www.ebay.com/itm/Team-Associa...MAAOSwAPlXhOPp
Old 07-12-2016, 09:00 AM   #1362
slakr's Avatar
Trader Rating: 28 (100%+)
http://beachrc.com/team-associated-rc10-b6d-team-kit/
TLR 22 4.0, 22-4 2.0, 8IGHT & 8IGHT-E 4.0~XRAY XB2C~AE TC7.1
Tim aka "slakr" ROAR No. 3-119960
slakr is offline   Reply With Quote
Old 07-12-2016, 09:40 AM   #1363
Trader Rating: 488 (100%+)
If somebody really needs one I can spare one of mine. I just can't ship for free. I've got one of my rentals on the market and until it sells I'm on hiatus anyway.
Now that I've discovered the ignore list I plan to use it.....17 and counting!
QDRHRSE is offline   Reply With Quote
Old 07-12-2016, 10:25 AM   #1364
Trader Rating: 14 (100%+)
Anyone in Socal going with the B6 for SDRC and OCRC? I kind of like the thought of the gear diff after running onroad for a bit. Seems like for 17.5 it would be a benefit anyway but then again i have never run them of road in anything but 4wd.
"Go that way really fast, if something gets in your way, turn"
TLR 22 3.5 SR, TLR 22-4 1.875 vs Tekno EB410, Sanwa M12S, Savox, Hobbywing, Schuurspeed, Protek
DG Designs is offline   Reply With Quote
Old 07-12-2016, 10:30 AM   #1365
Suspended
Trader Rating: 61 (100%+)
Gear diffs and 17.5 do not mix. Those things are HEAVY.
Wenger right now is KILLING it in 17.5 with the D car at OCRC.
Best Avatar on rc-tech
Socket is offline   Reply With Quote
Currently Active Users Viewing This Thread: 5 (0 members and 5 guests)
