    Hide Wikipost
Old 06-07-2017, 10:46 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Team Associated B6 & B6D thread
Last edit by: RCBuddha
Welcome to the B6 Wiki!
Quick links to all the sections on the first page!
Frequently asked questions - the most common questions you may have answered here!
Aftermarket Parts - parts for the B6 and B6D
Tech Tutorials- tuning guides, ball diff and shock building videos and tutorials
How to's and build-specific posts
Team Associated Laydown transmission conversion for B6D:
Laydown conversion
Instruction Manuals:
B6: B6 Manual and setup sheets
B6D: B6D Manual and setup sheets
How to Sand and Seal carbon fiber:
Sanding and sealing carbon fiber
Sanding and sealing carbon fiber 2
Sanding and sealing carbon fiber 3
Sanding and sealing carbon fiber 4
Charts for Quick reference:
1) put inner bearing in hub
2) slide large shim over axle all the way up to the back of the axle
3) slide axle/bone into hub carrier
4) slide small shim onto axle through hub carrier
5) push outter bearing into hub carrier
using that i'm able to put my normal male silverback gorilla wheel nut tightening job and there's no binding. in the pictures that come with the shims (the pic socket posted) it seems like they want you to slide both shims onto the axle before sliding the axle into the hub carrier and like i said, that doesn't work.
I've traditionally done the diff screw head on the left side (driver's side), but have since switched to the Right side (passenger side) regardless of transmission type (3 gear RM vs 3 gear MM and 4 gear MM).
Kdub (Kurt Wenger, former AE designer) had this to say on the matter:
Originally Posted by kdub View Post
I think I count as an authority on the matter. I always run my diff screw on the right side (when sitting "inside" the car). I take off the tire and pull the outer hinge pin to get to the adjustment screw.
The right rear is the way the AE manuals state (or used to state). It really shouldn't matter since you go around turns both left and right.
B6D 3-gear:
Print Wikipost
Like Tree372Likes
Old 04-29-2016, 11:41 PM   #121
Trader Rating: 45 (100%+)
Originally Posted by 190mph View Post
For the Xray crowd.
Someone's gonna claim that bling shaved 3/10s off his lap times. Bet on it.
Pro-Line/Protoform, HRP Distributing, PTRC Racing, Ho B Max
Antimullet is offline   Reply With Quote
Old 04-29-2016, 11:45 PM   #122
Originally Posted by kjohnsiii View Post
Guzzling the cool aid and Pre ordered and subscribed!!
LOL
Yokomo BD8 x 2 , BD7 2016, YRX-12, Tamiya TRF419, Associated B6, B6D, B5M Factory Lite, B64D, B44.3, RC8B3, RC8B3e
My Outdated R/C Car collection:
Associated B44, Associated NTC3, Tamiya TRF415, TRF415 MSX MRE, TRF416X
190mph is offline   Reply With Quote
Old 04-30-2016, 12:05 AM   #123
I need that or more reduction in touring car for the lap times.
Old 04-30-2016, 07:00 AM   #124
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 158 (100%+)
Originally Posted by fredswain View Post
I'd actually be surprised if the fundamental geometry was changed. The arm lengths and shock mounting locations on the arms are the same on the B3, B4, B5, and B44 cars. I'd be shocked if these were changed. The adjustable height hubs front and rear would make a difference and I suspect the top hole results in the same geometry as the other cars. The bottom hole would allow for a lower ride height without the roll center compromise that just running the standard geometry lowered would have. Everything could be different of course but if this is based off of a modified world's B5, I'd doubt it
I was mainly referring to the design of the bellcranks. They are now far forward and opposite of how the b4/5 was, more of how the 22 series cars are.
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 04-30-2016, 07:37 AM   #125
B6 has taken all 3 rounds of EOS qualifying so far! Two to Cragg, one to Cavalieri. Great debut results for the chassis.
andrewcoley is offline   Reply With Quote
Old 04-30-2016, 07:48 AM   #126
Originally Posted by Johnn27 View Post
Tower has a pre-order up saying late June , 30$ coupon will bring it down to $279 and they don't charge your card until it arrives.
I could not find it on tower. But am just out from gull bladder surgery so I am a bit loopy. Prioritys you know
brian6674 is offline   Reply With Quote
Old 04-30-2016, 07:49 AM   #127
Just pre-ordered my B6. So excited! I was impressed with the B5M. I am sure the B6 will not disappoint!
Yokomo YZ-2
Yokomo YZ-4
rbk1115 is offline   Reply With Quote
Old 04-30-2016, 08:14 AM   #128
Super Moderator
Team Associated B6 starts 1-2-3-5 in debut at EOS
http://eos.redrc.net/2016/04/cragg-c...q-on-b6-debut/
Old 04-30-2016, 08:15 AM   #129
cweb's Avatar
Trader Rating: 35 (100%+)
Pre-ordered mine from Amain yesterday, had $10 store credit to use so I pulled the trigger. I really like the B5M and hope the B6D is just as good, get to focus on driving the T5M now till B6 comes out.
Team Whiteknuckle- CW
B5M- viper-rc/Hitec/avid/schelle/mip/protek-rc/lunsford
T5m- viper-rc/Hitec/avid/schelle/protek-rc/lunsford
cweb is offline   Reply With Quote
Old 04-30-2016, 08:20 AM   #130
Originally Posted by RCBuddha View Post
Started updating the first page, breaking up some of the categories to make it easier to find things and easier for me to edit later.
BTW, here's the first B6 hopup:
For those who like to build shelf queens
Buddha, You rule! Thanks for taking the time.
Snap! Those screws are...
dustneyes is offline   Reply With Quote
Old 04-30-2016, 08:29 AM   #131
Default Inline battery
Do you suppose that battery strap allows for an inline set up? If not, I'm certain an aftermarket company will create one really easy. Hello Shape ways!
Old 04-30-2016, 08:31 AM   #132
Silverstonev8's Avatar
$45 coupon 011NE =264.99
Silverstonev8 is offline   Reply With Quote
Old 04-30-2016, 08:56 AM   #133
Trader Rating: 15 (100%+)
getting my preorder on!
Daragh Slowey
EB410/SPGT2Pro/Orca5.5/1258TGBlk/Nosram shorty
B6D/SPGT2Pro/Fantom7.5/1258TG/Nosram shorty
EB48SL/RX8/TekinT8i/Hitec7599/SMC4500(4S)
Grasshopper/Tekin FX/Twister 27T/FutabaS9551/Speed power
HeavyD99 is offline   Reply With Quote
Old 04-30-2016, 11:50 AM   #134
Woulvesbaine's Avatar
wow, this is how you setup a thread!
Buddha, it's a little old, but I also like this simple tuning guide (as well as some of the explanations) from elvo.
Table of Contents; Suspension & Handling Articles (click Setup Guide on left)
http://users.telenet.be/elvo/
|| Team C TM4 || OCRC || SCVRC || Facebook: Squid Ink Paint
Woulvesbaine is offline   Reply With Quote
Old 04-30-2016, 12:10 PM   #135
I might get really silly and order both and use a $100 coupon code.
I am not pre-ordering. Want to make sure both are in stock and time it with an e-cash promo week of the month. Then each kit will effectively cost $230 each, when the certificate arrives for $60 to spend on something else.
As a Super Saver Member. I just renewed 2 years for $10 last week as I forgot in February to do that.
Currently Active Users Viewing This Thread: 4 (0 members and 4 guests)
